Everything posted by mtbediz
mtbediz replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
The gun deck hatches and ladders have been installed, I think it is time to install the gun deck planking now. -
Thank you Phil. -
Most of the modelers who built the kit for this model mentioned the incompatibility of the stern frames in their build logs. I had to modify the outer frames on both sides, which was really incompatible, and align it with the others. Meanwhile, the inner planking of the deck side walls has been completed. -
I painted the gundeck waterways green. The color looked different in the photos due to the lighting, but it is actually a darker green. I started doing the inner planking of the gundeck side walls. First, I cut the planks to the same size, paint them white and glue them between the gun ports. -
The openings on the gun deck (gratings, hatchways, and ladders) were constructed but have not been glued in place yet. -
Thank you Gerson. -
In my previous post, I mentioned that I made the gratings in a different way. This method gave both easier and more satisfying results. Of course, I am not the inventor of this method. I also saw it in another modeler's build log and I am sharing it here for my friends who do not know about this method. There is only one tip. The depth of the slots in the South-North direction and the depth of the slots in the East-West direction should be different so that a depth can be achieved. -
Hello friends. After a long summer break I feel happy to be back at my shipyard. Continuing the construction of Conny. The gun port frames on the gundeck are complete. The stern frames have been prepared but have not been glued in place yet. Since I'm going to make the captain's cabin visible, I modified the stern middle frames by going out of the plans. The filler blocks were made for the stern and bow. They have not been glued yet either. By the way, I tried making the gratings in a different way. I am quite happy with the result. It is also very simple to make and I will show you how I did it in my next posts. -
I am in neighbour city Antalya right now. Normaly I live in Mersin, Turkey -
Thanks for stopping by Sjors. I will be away from the model until the end of August as I am out of town due to the Summer season. -
An extraordinary beautiful work. I also admire the way you use the electrical tools. I have a question if you don't mind. What kind of milling cutter is in the photo and what is its advantage? I apologize if this question has been asked and answered before. Thank you in advance.
- 589 replies
- le gros ventre
- cargo
Gunport sides had to be prepared in a parallelogram shape to fit perfectly. Using the extensions of the gunport spacer as a template, I marked the side strips and shaped them with a disc sander. -
I started the assembly of the gunport headers on the gun deck by completing the waterways. Like other modelers, I used spacers to keep the headers at the same height. I will add the cannons with full rigged carriages instead of dummy cannons on the gun deck. -
Thank you my friend. Do you have a build log? It would be interesting to follow for me.
