Everything posted by mtbediz
Hi, your ladders look great. I'm building the USS Constitution too, but mine isn't a kit. I used the kit plan from Model Shipways to cut the bulkheads and bulkhead former. I am making all the remaining details using the ship's photos and videos on the internet and US Navy plans. I also added the gun deck details, just like you. Since I'm a further along in construction than you, you may want to take a look at my build log to get ideas for your build.
mtbediz replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
I used plywood for the bulkheads and bulkhead former and used basswood for the planking. I covered below the waterline with self adhesive copper foil. In addition, the use of hornbeam and pear wood in the details on the decks. -
Congratulations! This is an excellent build.
- 562 replies
- vanguard models
- alert
I'm not too particular about measurements. If it were me, I would divide the deck into sectors, just like we did in the hull of the ship, and cover each sector independently of each other. Since you glued 11 rows, re-measure the remaining space as a separate sector and taper the planks according to this measurement,
I can't work much these days because my shipyard is very hot in the summer months and I don't have access to cooling. I think this situation will continue until September. I don't want you to think that I've given up on building the model. -
Hello Peter. Since I will plank the spar deck to a minimum (only the center of the ship and possibly the areas under the guns) there will be no need to taper the planks. But if I were to completely cover the spar deck, I would taper the planks at the aft because it would be more realistic and look better. -
I don't try to get a very smooth surface in wooden models because in real life, wooden ship surfaces are not as smooth as a metal surface. Especially the lines at the junction of the planks are evident, making the model more realistic.
- 184 replies
- Bluenose
- Model Shipways
Thank you Greg. -
Thank you Nils, I haven't decided yet whether to add the rigging or not but I'll keep building as if I will. -
I was away from my shipyard for a while because I had other things to do. I'm happy to be back again. I completed the assembly of the commodores cabin walls and doors that I started before. -
Thank you my friend. I have very useful machines, they make my job easier. -
Thank you so much my friend. -
You are right, Peter. My model is a little larger than yours, but not by much. I did some research, actually I should have done this at the beginning, Conny's length according to Wikipedia is 63 m from billet head to taffrail. When I measure my model I see that it is 89.7cm. Accordingly, the scale of my model is 1:70, not 1:76. Dear friends, please accept my apology for this. I would be grateful if an administrator could revise the scale in the title accordingly. -
Hi Peter. Unfortunately, I do not have a scale plan. I will ask you to measure the length of the spar deck of your model for me. If you can do this and let me know the measurement, I will calculate the exact scale of my model and let you know. Thanks in advance. -
The fine details on all the white walls of the commodores cabin will be made from 0,5 mm pear strip. The walls will be painted white before gluing in place
