mtbediz
Everything posted by mtbediz
  1. Sorry for the late reply, Peter. I don't actually remember why I installed the pin rails before the carronades. It would probably have been more appropriate to install them after the carronades.
  2. Yes, this is the right approach. In my Essex model, I frequently encountered this question: "Well, didn't the sailors fall through these gaps?"
  3. I only faired the first bulkhead in the bow before gluing it in place, because that one had a lot of sanding to do. I used my sanding macine to do it.
  4. Not really! Just sitting by the pool, sipping my vodka and watching my grand daughter Bon appetit to you too.
  5. For sure it is hot! but not where I am sitting down right now
  6. I hate to say it, but your garboard planks are unfortunately incorrect. They've climbed too high, which will cause plank congestion in the bow later. If you want to plank your ship correctly, remove the garboards now and remake them as shown in the photos. If your ship has a second layer planking, take this into consideration when making the second layer planking. Other than that, everything is going great so far.
  7. I'm so sorry if I'm bothering you, Peter. I'm just trying to understand and help. I know you won't remake them all over. If you used pre-made eyebolts, it was even easier. All you had to do was to bend the hooks perpendicular to the eyelets. Just keep that in mind for future hooks.
  8. I make the eyelet first, then bend the hook part perpendicular to the eyelet so I don't need to twist the hook. I know it's too late to tell you this, but keep that in mind; you'll want to try doing it like this on your next build.
  9. Welcome to the forum. The result you've achieved so far with limited hand tools on this challenging model is truly impressive. There are a few other modelers in this forum, including myself, who are building the same model and sharing insights. You might find inspiration by joining us and seeing how we tackle various challenges.
  10. Sorry, Greg. I've been away for a while and didn't realize you'd started building the Constitution. I used a scroll saw to cut the gun-deck curves on the bulkheads.
  11. Greg, I have a reversible hand drill like in the photo. I use it when necessary.
  12. Peter, when drilling soft and thin woods before, turning the drill in the opposite direction helped me drill without splitting the wood. This information may come in handy in the future.
  13. Let me also point this out, I cut the pieces a little larger and do fine tuning with sanding machine.
  14. Drilling first and then cutting usually gives better results and reduces scrap. That's how I usually do it."
  15. Your model looks great Peter. Just curious, did you ever consider leaving the gun port lids open?
  16. My mistake, sorry. When I said "I will remove them" I meant "I will remove the entire channels". Because I will cut the slots on the channels. These pins will also be there when the channels are permanently glued in place
  17. Based on the US Navy plans shared by Jon, I calculated the widths of the fore, main, and mizzen channels scaled to my model. These plans showed that all three channels have different widths. Accordingly, the fore channel is 16 mm wide, which is significantly wider than the main and mizzen channels. I don’t know the reason for this, but that’s how it is. I calculated the main channel to be 12 mm and the mizzen channel to be 11.2 mm. These measurements do not include the strip that will cover the chain plate slots. I cut the channels from 2.1 mm thick basswood sheet and temporarily attached them in place with pins. After marking the positions of the slots where the chain plates will be attached on the channels, I will remove them.
  18. Thanks for your efforts, Jon. The navy plans will be sufficient for me to calculate the correct dimensions. Thanks again.
  19. Next Wednesday, I’ll be shutting down the shipyard again until September, Peter. I’m guessing you’ll catch up and surpass me easily.
  20. Thank you Jon. I've reviewed the plans again, and yes, there are some details, but I couldn't find any information or drawings regarding the width and thickness of the channels, which is what I need. I’d be grateful if anyone who can see these dimensions could let me know.
