Everything posted by Ondras71
MONTAÑES by Amalio
Ondras71 replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
I'm getting more and more like your beautiful and clean work. I'm losing my hat. O. -
Roter Löwe 1597 by Ondras71
Ondras71 replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
I've finished pinning the lower mirror. There's no pins at all in the plan. I was looking for a suitable pattern, I found it in the Prins Willem monograph.. I altered my pins a bit in a way they would look on a smaller ship.. -
Somewhere I read that the pins are like Braille... I guess it is true, I quite enjoyed reading these lines .. The polished left side.. After waxing the pins are well noticeable.. -
Pandora by marsalv - FINISHED - 1:52
Ondras71 replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Your work still rises upward Marsalv. I admire and support .. Ondras71 -
Thank you Vivian!! I started with the installation of pins .. The first piece is polished. After waxing the pins will be beautifully seen .. O. -
Thank you Srodbro!! I marked the whole left side with a spike and immediately started drilling 0,65 mm holes. There's cca 1600 of them on one side, but it's going unexpectedly well.. -
Thank you Michael Mott. I started measuring and painting lines for placing the pins .. Before drilling, I decided to use a spike to get the accurate spacing of the holes.. -
The banner with the name of the ship is amazing as well as the entire ship. Very inspiring building !! Ondras71
- 487 replies
- ship of the line
- 80 guns
Thank you very much Backer, Ferit KUTLU.. The planking continues, difficult places at the stern under the mirror already done.. Bow closed and ready to install pins .. -
Thank you very much, I know it will be a long work. However, it is the result that's important. I created about 3,700 pcs of pins, it is stereotypical but quick, about 500 pcs in an hour.. Pinning the hull test, the dark cherry pins are nicely visible in the light cherry! I'm planning to smear the surface of the hull with restoration wax, testing it .. -
Thank you Mirabell61 I continue with the hull tiling .. I started making 0.65 mm diameter pins for the hull, only at the bottom there will be about 3.300 pieces.. -
Continue slowly in the hull tiling. The first hook on the bow has already been created .. Current condition after rough grinding .. -
Placed top wales made of 5x3 mm strips.. Bending it into an arc created an unsuitable shape at the stem .. The end of the strip adjusted.. The result is satisfying .. planking started.. -
Thank you honestly zappto, Backer, HubacsHistorian..!! I placed the keel, stem, stern post .. According to the instructions I found on the Internet, I have created a tool for accurate ribbing.. And it works .. And it works .. When ordering wooden strips I forgot to order 5x3 mm strips for wales, so I was forced to make them on a saw ..
