Ondras71
Everything posted by Ondras71
  1. Thank you for your support. So after five years and three months it's done. Created a wooden board under a glass case .. ..Model placed on an honorable place in the dining room .. figurines of sailors built as a "scale" next to the ship .. Already starting a new construction...
  2. Placed label on stand .. Latest photos before placing in a glass cabinet ..
  3. https://upload.wikimedia.org/wikipedia/commons/9/94/Vasa_mid_weatherdeck2.jpg http://www.modelships.de/Museums_and_replicas/Orlogsmuseet_Copenhagen/Sophia_Amalia.htm
  4. Thank you dutchman2 Laying a cannonboard made of plywood 1 mm thick..
  5. The first plating of the submerged part is laid and ground.. The hull inside is reinforced .. The construction is solid, waiting for the second plating ..
  6. Thank you all and I greatly appreciate your positive reactions, which really encourage me to continue my work. Ondra Before finishing, the last important thing is the glass case ... ..and a label with the name of the ship, inspired by the original ship ...
  7. Very nice ship. I also decided to build a Dutch ship from the same period - Roter Löwe, I will keep track of your construction !!!
  8. Laying the first plating of the bottom of the hull ..
  9. Thank you Backer, I try to work honestly.. The correct shape of the plank hips is formed.. Bow and stern filled with balz..
  10. The frame placed on the base plate .. I painted the inner edges of the ribs, which will be heavily bevelled, black so that I did not tear off the edge when grinding.. A glued frame .. Added base plate of the bottom mirror.. After the bevels, it's time for the 5x2mm spruce strips planking..
  11. Thank you marsalv!! The coarse skeleton of the hull..
  12. I still do not want to believe it's your first scratch build ... Your job is totally professional. I look forward to more photos.Ondra
  13. I stuck the paper ribs on the plywood and started to carve .. Grinders are also prepared ..
  14. I agree to assign cannon ports according to the Chapman plan.. The last rope of the driver is in place, so there is no longer just the lantern, the boat name and the glass cabinet..
  15. Hello Bill. I'm just like you looking for the original of my model, and I actually found it among Chapman's plans. Unfortunately, I found it too late to get closer to it, I was a long way into building. The kit is really very much simplified, the original has a total of 18 cannons .. According to the hull's shape, I guess it really was a merchant ship. digitaltmuseum.se/011024789732/ritning?aq=&i=22
  16. The last rope on the boat - Sheet, Tack.. Finishing the build is a bit slow, as I have already begun building a new model ..
  17. I got the planks and wood for construction from the Czech model maker Petr Šimek. Light cherry, dark cherry, maple ..
  18. Working with paper plans isn't exactly easy, but in the days before computers it was as well the only way.. The paper ribs really needed adjusting, making the radius accurate.. I transfered the modified shapes back onto the ribs. I transfered the heights and the shape of the deck and then deducted future planking.. I thought about a way of gluing the body of the galeon's hull, so that it wouldn't twist. I decided for a reversed variant, where the ribs stand in exact height on removable parts.. Finished paper ribs and keel are now ready for gluing on 6mm plywood and carving it..
  19. Hello. Golden Hind is my favorite galeon, but Roter Lowe has won, because it is bigger .. I'm looking forward to building and watching all the similar buildings, including yours .. Only the Holad boat is a bit different from English, which attracts me ..
  20. Thank you for your welcome here. I have books ready to support the construction : Wolfram zu Mondfeld - Historic Ship Models Rolf Hoeckel - Risse von Schiffen des 16. und 17. Jahrhunderts Herman Ketting - Prins Willem Wolfgang Quinger - Wappen von Hamburg Beginning "from scratch" is a bit different than a modular one, there is a lot to save and spoil.. As I said, I first created a paper half of the hull.. When laying a rail, some ribs really do not fit.. So I varnished the edges of the rib and there will be more grinding and adjusting . So treated ribs will be a template for plywood ones ..
  21. My previous construction of a kit.. ..is coming to an end, so it's time to start with a new one... Another construction I'm starting is scratch build, I've decided for a ship from the 16th century, a galleon, which I always liked, specifically 1597 Roter Lowe.. I've had the 1:60 plan at home for many years, it's a copy of a well-known German plan.. The scale is close to fifty, still very detailed and mainly the ship hasn't got much decoration, which I do not dare make yet. I'm leaving 3D aside, I hope paper plans will do.. Right from the first comparison of copies of the two side elevations, I came across different front ligament shapes.. That's also why I decided to create a cardboard half of the hull and check the crossing of the ribs, and then do the plywood frame..
  22. I clamped the last control ropes of the mizen mast sails and the main yards tackle .. Again I have to pause over the functionality of the rigging. Everything works and after tying, "it" doesn't move a bit... Further measurements with harder currency ..
