Everything posted by KORTES
- 306 replies
- schooner
- la jacinthe
As I had to work under a constant supervision, I forgot to post photos at the time. Although the process of lath bending has been highlighted many times, I would still like to share my experience. I think it could come in handy in the process of covering of the overhang and taffrail. I tried different modes, but decided to use the one that consists in bending the steam-treated plank on the pattern. This complicates the process a bit, making it more time-consuming, but when setting in place, the further work is much more comfortable. The lath I used is no less than 1,5mm thick, if it’s thick it can be refined using marking gage.
- 306 replies
- schooner
- la jacinthe
Yes, you're right, the bunny was my partner in the building process. So I can say I was working under his supervision. Concerning the caulking - I was using the plastic tape. I posted the process in the theme Friech Boeir Yacht SPERWER by Kortes - 1:30 scale on the page
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
Yes it is. I’m very touched by your attention to my work.
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
Until I haven’t gotten around to make the hull, - I have made a quarter boat. The technology is standard . Firstly I have constructed a mold.
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
After taking measuring, I had to fix the outlines in certain places, glue some extra laths, and then finished up with rat-file. In this case asp was a good choice – the wood is not too siftproof and can be nicely processed with sandpaper.
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
The covering was made out of the asp laths 1.3:12 mm in two layers, afterwards retouched by sand paper, and then I proceeded with the deck.
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
- 306 replies
- schooner
- la jacinthe
Dear Colleagues, please let me present my first model made from the ground-up – the model of French military schooner «La Jacinthe». From the drafts of the monography Jean Boudriot. I used pear tree and painted hornbeam. Scale 1:42 Technical characteristics of the model: length 895 mm, width 285 mm, height 670 mm. In the process of building I have used as example the works of Dmitriy Shevelev and Slavyan Snarlev. I finished my work on the 23 of September 2016. I had a photo report of the work, I decided to post it, maybe it could useful to someone. My best regards, Alexander.
- 306 replies
- schooner
- la jacinthe
Before starting to work on the rigging, I had to make some preparatives, for example temporary dust prtoction.
I fully agree with the opinion of my colleagues, - jewelry work. The example of outstanding mastery. My best regards.
- 2,215 replies
In the period of going from carpentry to rigging work - I built a stand, while it's still easy to manipulate the hull.
The next step. Inserting the block into the shell of the block. Marking and drilling a hole for the “axis of a sheave”. After that - the shell is taken off and the profile of the shell is being formed, using the same mini-drill and broaching file. The next step - making the axis of the sheaves from the wire 0,8mm, this is easy. After that blackening of the shell of the block and assembling. I ve done it like that. I hope my explanation is comprehensible. If there are questions I’d be glad to help.
After that the shell of the block is being soldered to the end of the hook. I used the the clamp as seen above. After the soldering, the extending points of the ends are cut off with broaching file and mini-drill. On this stage I also made the final shape of the hook using the same equipment. On some blocks, apart from the hook it was necessary to solder “half-circle”. It is also bent separately and soldered to the end of the block.
The making. Unfortunately, I didn't document all the steps, so i’ll try to explain in words. I made blocks of the required form. Cut the stripes of brass of the required width. Adjust the shell of a block individually, using each block as a pattern, which guarantees push fit after soldering. Hooks are bent separately out of the wire 1,0 mm. After the bending, we cut the end with a thin saw used for metal works. and make the shape on which will be soldered the ends of the shell of the block.
