The curved ledge or rail at the bow in front of the fore stay mountings, could indeed be an elevated bow rail for pins used for the jib stay sail downhauls. The shadow indicates such a rail. Rob
- 3,560 replies
- clipper
- hull model
I think the structure that forms the curve of the splash rail base, could be a bow rail for pins. I need to figure this out. It looks like another mod is in store. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
I have period dry transfers that I will use to redo the stern name and the name boards……just haven’t got to them yet. No…I don’t mind. That will be a whole project in of itself. Was my spelling correct? Rob
- 3,560 replies
- clipper
- hull model
Why not simply cut the wire so it simply terminates at the futtock band and just glue it there? When you glue the wire in the hole of the cross tree, you will have snug secure deadeye to lanyard up to the upper shroud. Then simply paint over the glue joint. In this scale you can get away with that. Rob
- 481 replies
- Cutty Sark
- Revell
- 3,560 replies
- clipper
- hull model
I’ve come to an empass. Normally the downhauls for the jibs would be belayed at a fife rail on the forecastle. However, all my research doesn’t seem to validate that Glory had one on her forecastle. I don’t se any evidence of one………but logic dictates one had to be there…..or something similar. Maybe Rich will add some insight? Rob
- 3,560 replies
- clipper
- hull model
I had the time and I took it. I eliminated 4 regular days sessions. Just that much closer…… Rob
- 3,560 replies
- clipper
- hull model
It amazes me at the extent of rigging I’ve chosen to tackle. Short of any stunsl’ rigging and the shortage of stay and jib sails(which they removed during long stints in port), I’m not sure if I left off any required rigging. I’ll finish off the jib stays and their hallyard and dowhauls tomorrow. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Adding the forstay. Now that the main yard for the foremast is hung and rigged, I can go ahead and add all the jib stays at this time…..because all of their halliards and downhauls need to belayed aft of the fore mast. No better time to act now then to wait till all the backstays are installed and in the way. Rob
- 3,560 replies
- clipper
- hull model
Now the real work comes….. adding the bunt lines, rigging and belaying them , along with all the other rigging. Need to finish the starboard lift and lower topsail sheet. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Thanks Nic. That would have worked. I also recall EDT using tissue paper. I just didn’t like how the paper I used, crinkled as it folded around the hull, unlike your straight example on the stays. So I simply “opted out”. Rob
- 3,560 replies
- clipper
- hull model
Pat , good observation. Those chains would most likely be encased in a canvas sleeve. I tried several attempts, but none were acceptable or truly convincing, so I opted to leave the chain virgin. Knowing the issue was an extremely minor one. Rob
- 3,560 replies
- clipper
- hull model
That’s a good solid way….but if the eye bolt was horizontal, you could easily fit another next to it. With the eyebolt vertical the futtock shrouds will have to lay upon one another, creating a tight situation. Rob
- 481 replies
- Cutty Sark
- Revell
- 3,560 replies
- clipper
- hull model
Finished rigging the halliards and their purchases. And added some rope coils. Things are getting pretty complex and busy. Rob
- 3,560 replies
- clipper
- hull model
Worked on finishing up the starboard shrouds and ratlines. Then I rigged the bunt lines through their fair leads and to belay pins. Still need to add road coils. Next will be to rig the gin block lifts and their purchases…..before I begin the backstays. Rob
- 3,560 replies
- clipper
- hull model
It appears many of us on these pages juggle many hobbies. I too work on my HO power and rolling stock....along with machining and building telescopes...and of course in the shipyard working on my clippers. Gardening and building miniature lighthouse dioramas rounds out the major hobby list. I need more hours in the day.....how to do that without giving up my 8 hours of sleepful bliss.....? More power to ya. Rob
- 481 replies
- Cutty Sark
- Revell
Its a wonderful carving and it took great skill.....I have nothing but respect for the carver....but.....(In all aspects), she's has a very disproportional body. I'm sorry to say. I posted updates last night, but somehow my post never materialized. I finished up the starboard shrouds/ratlines and added the fairleads and ran all the buntlines and belayed them. I'll repost those images when I get home. Rob
- 3,560 replies
- clipper
- hull model
Doing your proper research is important if not more so, if you want an accurate model. I have 12 years of personal research coupled with that of my cohorts and a lifetime dedicated by my friend Michael Mjelde....before I tackled fully scratch building my Glory of the Seas. I have been building clippers for over 50 years and the Revell CS 4 times.......and I had to begin at a steep curve, such as yourself. Study pays off and it will for you. Understanding the function of each line, brings greater accuracy to your build and greater confidence in your own skill, not to mention how a sailing ship as complex as a clipper functioned. Good luck. And enjoy and apply what you learn. Rb
- 481 replies
- Cutty Sark
- Revell
