Thanks Bill, that means a lot. I hope I’m staying true to my subject matter. Rob
- 3,560 replies
- clipper
- hull model
Thanks a lot Michael. At this scale I surely didn’t want bulky. Tightly furled sails are not easy to pull off convincingly. Thanks…..your approval is worth millions. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Thanks everyone for the fine comments and compliments on the progress. line has all kinds of variance in its diameter, the lifts are larger than the buntlines and the chain sheets . The downhaul on the upper /lower topsail is even of a different size. Here are a few more progress images. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
See Keith...you're doing as I do...with that workmate. It's sweet huh? Off model work for the masts/yards is the only way to go if you want to keep from breaking everything. Just sit at your bench and easily reach and work on all the rigging aspects. Great job for sure. The scale is far too small to tie knots for the ratlines....just glue them on. They will look great. That's all l do, then I paint the glue marks black. Looks like scale tar. (Given up secrets) Rob
Thanks Ian. I worked this design out with lots of experimentation. It is tiny metal work, but it pays off. Again, thanks for commenting. Rob
- 3,560 replies
- clipper
- hull model
Just remember...many of his drawings represent the larger steel ocean carriers. You will need to focus on the wooden structures and familiarize yourself with the rigging practices used on Glory. They are quite similar to those of the big Iron boys, but are slightly different. Good luck. Rob
- 3,560 replies
- clipper
- hull model
I hope I wasn't implying that tedium was in any way unpleasant? It simply means slow, detailed repetitive work...generally associated with long moments of pleasantried reflection and elevated endorphins. Like I said...I'll finish up the mizzen and then rightly move to rig the bowsprit. Rob
- 3,560 replies
- clipper
- hull model
Thanks Vlad. I’m just getting started, months…..many month…….of tedious detailing rigging to do. I’m glad I’ve devised a methodology to it all, to make it pass without me losing my mind. Rob
- 3,560 replies
- clipper
- hull model
I’m just now rigging the sheets. Once the bunt lines are added too and the lifts……it will get really busy. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Adding the top gallant and royal. Now rigging them will take lots of work……so much to still do before this mast is ready to be set in place. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Finished up the mizzenmast shrouds. Now onto the ratlines and some minor drilling for the tye access holes. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
TBD......might look like...the Black Pearl swirling on the edge of a large maelstrom......? Rob
Problem with common rubbing alcohol is the additives. In my experience it reacts poorly with the India ink and never gives the good results I found with 98%+ It surely doesn't burn well...not clean at all. Thusly...evaporation is not as clean and the ink suspension is poor as well. Experiment and see for yourself. Rob
- 444 replies
- Cutty Sark
- Revell
Fortunately for me I use dental isopropyl alcohol and I believe it is higher grade and burns much cleaner. I'm sure 90% will work fine. Test it to see. Rob
- 444 replies
- Cutty Sark
- Revell
The skill and tenaciousness of the Carpenter and his apprentices.......is amazing. Not to mention the blacksmith who set up forge on deck in inclement weather to refashion hardware for the refashioned masts/yards.....JUST Amazing Grit under the worst conditions. All the while the captain is watching the hourglass. Time is money....did I mention that....? Rob
- 3,560 replies
- clipper
- hull model
