Thanks Johnny, I think my selection best matches #32 and #28 for sure. It's clean and crisp, but not over expressive. Perception is truly everything. Rob
- 3,560 replies
- clipper
- hull model
Magnificent. Mine are so small, it's tough to get in all the detail. I need to make some mods and correct some issues and clean them up. Glad I only made one first. We’ll see. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Worked a bit on several things. I cut out the base material for the two skylights. Simple approach really. Rob
- 3,560 replies
- clipper
- hull model
Thanks Vlad. It took a couple of hours of focused uninterrupted work. I just hope all that detail will be able to be seen and appreciated after the boys house, gangway and boat skid are added. Rob
- 3,560 replies
- clipper
- hull model
Thanks Rich and tell your wife thanks as well. The corner brackets took some doing, since they are roughly only 3/8ish in length and have ample carving relief on them. The windows are all made from hand cut parts.....crown, sides and sashes. The windows are roughly 3/8 in height as well. And don't talk to me about the doors...they consist of way too many parts. I opted on the color blue that I did, solely based on age represented.....limited photographic evidence, and preference. I struggled with the idea of sucha dark blue. It seamed so un characteristic of the simple color schemes typical of clippers. Though some extreme color combinations have been written about. I'm also striving to retain what I gather as the colors of her after her major refits and good weathered use. The image of her from astern with one of her cabin boys, demonstrates the extreme weathering she saw....by way of paint chipping and scuffing. It is clearly evident on her cabin doors and walls.....not to mention her boats. And this was in her heyday. Rob
- 3,560 replies
- clipper
- hull model
Thanks Pat. Yes I've read about that practice......plus the constant shuffle through the doors made a real scuff. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
First coat of paint on the front of the carriage house. It looks muddled……….cuz it is. It will all look good when dry and a second coat is applied. I’m working on the corner brackets, they go on after the painting. Rob
- 3,560 replies
- clipper
- hull model
Mikes original model builder painted all the houses *Except* the carriage house, with the waterway color. It looks nice. Rob
- 3,560 replies
- clipper
- hull model
Rich from what document can we arrive that the trim was painted the same color as the Waterway...or painted blue at all? B/W photographs are poor providers for definitive colors...though shades can be determined....but not true colors. Is the blue trim an assumption or based upon actual McKay practice? I'm not convinced either way. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Over the last few days I have been struggling with the notion of painting the lower edge of the houses with the same blue the waterways are painted. To be honest, Glory has gone through many changes at the hands of many captains and through sheer neglect. Many clipper builders or modelers like to use bold colors to distinguish these *trim* colors. Usually a bright blue. I'm not convinced. I prefer a more subdues blue and with that said not sure it was used to highlight the building base trim. On the other hand there is some evidence indicating there was some trim color. Notice the shaded difference in this image of the aft skylights on Glory.
- 3,560 replies
- clipper
- hull model
I’m out of state this weekend so very little to report. Maybe when I return tonight I’ll do a bit of work. Rob
- 3,560 replies
- clipper
- hull model
Oh…..I’ll tell ya if you are becoming a rivet counter. This is my second Glory build and I started it with the intention of seeking aid from other sets of eyeballs. You’re all 😊 Rob
- 3,560 replies
- clipper
- hull model
