Posts posted by architectnavalis
Okay, I think I didn't get the planking pattern right, but at least it starts to look like a ship's wooden deck and it has some kind of pattern. For the first time I am doing this, I am happy.
About the margin plank I feel a bit "anxious" to start, but I think I will take a first try next week. Until then, this is my current building progress:
- GrandpaPhil, Ryland Craze, Dfell and 4 others
- 7
Hello together,
I made some progress the last three weeks, planking the inner bulwark and painting it red.
Next step will be the outer shell planking and the deck. Regarding the deck I am thinking about the treenails, if I should try it. On the one hand it really looks great, on the other hand I should keep it simple for the first wooden model.
I also saw several models, which had nibbed planks, but also found this thread: 1760s Royal Navy deck planking and waterway nibbing patterns .
I will try the pencil method regarding the caulking of the plank as I like the subtle look of it.
As you see in the picture, I tried to mark the way of the main deck beams, as I found them on a plan from NMM, but I think I should try using AutoCAD to make a more correct plan of it. Maybe I just should start and think about the treenails later.
Regarding the deck planking and the outer hull planking, how accurate is the pattern, which is shown in the Mondfeld? At least I want to do that the right way, that planks always end on the beam and so on.
Regarding the red colour of the inner bulwark, it was right. glue stains all over the places. So I have to make a second and maybe thirs layer.
Best regards
Thanks for your reply, Tony.
Yeah, I might have overdone it with the PVA glue. I think I will sand the parts, that received to much of it. In my first attempt I wanted the planks to be fixed quickly, as I was eager to see results. Maybe I should try myself in patience and classic wood glue
Yeah, I already have seen a lot of the build logs, but then I have to remind myself, that it is the first wooden kit and I should not reach for the stars, seeing all those little master works.
As the master studies finally reach an end (have to bring in the thesis next week) and I will have more time for the numerous hobbies, I have taken up the work on the cutter Sherbourne again, which I bought 3 years ago as a reward for the finished bachelor studies. Now, after three years of ripening I started the kit. It is my first wooden model, and I thought Sherbourne might be a good start, as it is not too expensive.
As I forgot to take some pictures of the earliest building steps, I will just show you the current progress. During the first planking of the hull, I built some of the equipment (anchor, gun carriages and the gratings), but I have to admit, that I don't really like those gun carriages. It will possibly happen, that I do them all over again from scratch, as soon as I made a little CAD-drawing.
The sanded hull. There are some errors in the 1st planking, but I hope the 2nd planking + whitening the underwater hull will hide them sufficiently.
A lot of glue marks on the stern... Will be hidden under red colour I hope.
Some pre assembled equipment. As already mentioned, I dont like the gun carriages. Regarding the anchor, I decided to fair the stock on the ends, as found in "Historische Schiffsmodelle" by Mondfeld.
So far. As this is a weekend project, I hope I can provide you with more photos of new progress every week. I am looking forward for tips, maybe some encouraging words for a newbie in wood. Most of my modelling experience is strongly limited to plastic/resin kits.
- Jonny 007, tkay11, KARAVOKIRIS and 3 others
- 6
Ahoy,
as I promised I will start my first building log after the Easter holidays, so here we are. It will be my first Sailing ship kit after almost 10 years. My first kit was the Airfix HMS Victory at the age of 14 and it went right to the scrap yard. I already bought this kit another time for a second try, but til then it will be the HMAV Bounty.Excuse my photos, because they are taken with my mobile phone. Hopefully my new camera will arrive til the end of April. Anyway you can see my progress until now. First step was getting rid of the multiple layers of dust. After that I decided, that the deck will be repainted with oil colour on an ochre base, because I think it is much too dark. This does not apply to the colour of the hull. There it looks quite nice in my opinion and just needs some adjustment.
Here I have my first question: What colour would you paint the gratings. I think it would look good if they are a bit darker then the deck itself?
Next step will be the rudder and its hinges. Unfortunately I do not know the English word for the pieces where the shrouds are attached, but these also will get their edges rounded.
I hope you have some advice what I could do better.
Greetings,
Manuel
- GrandpaPhil and Steve 12345
- 2
I was registered at this forum a long time ago, but back then I was way younger and had a lot of other nonsense and sense in mind. Now I finished my studies in Naval Architecture and think I found some time to start modelling ships again.
I look forward to a fine time modelling and hope for some tips from you. My first project will be the HMS Bounty by Airfix that I already started. After that there's a lot of other stuff in my stash.
- EJ_L, CaptainSteve, mtaylor and 3 others
- 6
HM Cutter Sherbourne by architectnavalis - Caldercraft - Scale 1:64 - First wooden model
Hey together,
it is a long time ago, that I posted some progress on this build logs, but today I made it and finished the wooden deck for HM Cutter Sherbourne.
I wanted to plank the deck in some kind of pattern, as I thought it would not look right, if the planks go from stem to stern without seams. At several places I think I lost the pattern and the distances between the planks isn't completely correct. The outer plank of the deck was also my first try to fit that one in, but It seems to be to wide. Will definitely change that on my next model.
But I am happy, that I have found the time to finish the upper deck planking and the gratings.
Next stop: completely planked outer hull and outfitting.
