navarcus
Everything posted by navarcus
  1. What kind of fiberglass and epoxy did too get such a smooth finish?
  2. Very well done and well painted. Wish I was half as good as this shows you are. Visiting this ship in NYC with my father in 1956 (?) was when I got the ship modeling virus.
  3. One of the responses had this pictured design. Since I had the huge shiny brass prop in my stash from long ago.... And since the deadwood was already drilled for the shaft, I went with hard cherry for skeg's strength. Procrastination probably beats cavitation as my biggest problem -- like McClellan, I have a bad case of the slows.
  4. So I remade the pinewood skeg with hard cherry. Steam engines love big props. No longer trying to bend hard brass. First step of many.
  5. A while back you mentioned 17th century. I know you designed the HMS Prince, but I hope it will lean towards a smaller nicely ornamented 6th rate. There are some simple plans from the Maritime Museum of these I've liked for many years.
  6. I was hoping to use brass (in a simpler form) for this instead of pine.
  7. I have a 10" piece of 1/2" by 1/8" hard brass as a skeg for a Hartman Bunker Boat. And it needs to be 3/4" lower at the middle to clear the prop -- sort of a short in height, but long in length "Z". Is there a trick to how I bend it?
  8. I have built the Nonsuch many times and the pre-formed/sawdust/glue/heat-moldable cookies for the carvings were light, accurate and solved many problems that 3d printing 're-solved' 40 years later. Search MSW for 'Nonsuch ketch 1650' to see how wonderfully Aeropiccola exploited this technology. Here is a sample from this link labeled internally as 'Album created by chas.'
  9. A 17th century kit -- something Sam Pepys may have sailed in? Something single-footy with ribs showing and gold gilt? Still no kits out there now for a duffer to do this.
  10. What about a lift version of this model as seen in the Speedwell book? The sweet smell of Alaska yellow cedar while carving and sanding the shape. And the sure knowledge that no supernatural talent is needed to get to the finish line.
  11. When I look at a book about the replica Nonsuch built by the Hudson's Bay company there is a picture of the captain sitting in front of a very substantial rudder trunk in his cabin. The picture below gives a hint that this area of the Sultana replica may also have a rudder trunk.
  12. Portia Takakjian ignited the single-foothook HMY Fubbs fire (as rebuilt 1724) 33 years ago. Romero wrote a great book a little later and Bob Hunt made 30 nice kits after that. Some kit-maker needs to step up and make the WW guys a worthwhile offer.
  13. If I remember correctly, part of the genius of Art Montgomery's POF America was that the company got two kits from one loaf of bread. Every other slice of the carved hull was in one kit and vice versa. Lovely kit to build.
  14. Bluejacket had a carved-out tug hull model that was fun to build. The yellow box Fair American (solid hull) was good and I think better than the present one. Aeropiccola's thermo-plastic wood-dust-waffles for carvings and sterns were and are still the best solution. Sometimes the good old days were better.
  15. The yellow box Fair American was the best hull I ever worked on.
  16. I can't see in my mind's eye what exactly frame 29 needs to be shaped like. Do you have a couple of pre-glued pictures? Very much like the wood only approach.
  17. Thank you for the framed hull pictures; and wow aren't they something! The Franklin book is really great and I like how page 91 illustrates simple cannon carriages. Makes me think I don't have to do coils on my next Nonsuch, just focus on the goldleaf stuff. Aeropiccola did such a good job with their waffle-like wood-dust cookies for the mermaids and its fully formed stern. They are light, feel like wood, are easy to glue and thermoplastic to boot -- what was not to like?
  18. Would the bitts which the anchor cables are wrapped around come apart when the anchors need to be dropped?
  19. Not fiction, but reads like Tom Sawyer crossed with Tom Swift with turrets and shell-guns.
  20. If I were any good at this, this would be pretty. OTOH it was pretty simple - the bow hawse part is just solid wood. Built 'rack of eye' almost in mid-air but with plenty of meat to sand down - more to do! Single-foot-hook can split if not seasoned, but Fubbs kit worked up pretty well with LSS 2009 CNC cutting.
  21. Looking at pics of Navy Board ship models, many don't have cant frames. Did you ever consider this option for less skilled modeler?
  22. Water soluble and extra can be rubbed off planking with wet tissue after gaps are filled.
