Posts posted by Moab
As a tool nut I'm always checking out various sites. In my other life I built guitars and the best online site for luthier tools is Stewart-MacDonald (stewmac.com).
I've been using sewing needles glued in a dowel rod to apply ca glue. On the Stewmac site I found "Glue Loppers". I've used only one of the smaller size for about a month cleaning it with a lit match when needed. In my opinion they're great. They may be better than needles because they are very thin. They cost about $14 for 12. A bit pricey but I'm hooked...Moab
- thibaultron, kurtvd19, lmagna and 4 others
- 7
Tony; WOW! Really beautiful. If you're looking for some reference on masting and rigging you might want to check out the Panart Armed Launch. I think there's a build on this forum or go to Google Images and input "Panart Armed Launch...Moab
- tkay11, aviaamator and mtaylor
- 3
Can someone point in the direction of how to bend planks across the grain. ...Moab
Really looking excellent. The transformation from the early stages
is amazing..Moab
I may be the last to know about this. I purchased the Dremel Chuck Adapter and like it. I no longer need to change the internal collet adapter when I use a different size bit.....Moab
Can't say I disagree with anything above. I use Titebond whenever possible but I guess too often I want to get things done more quickly.
A couple of suggestions which I know have been mentioned elsewhere:
I use a sewing needle with the top cut off and the other end placed in a short dowel so it looks like a pencil. I dip the needle into a small container of
ca and carefully place the glue where I want it. I think a toothpick can also be used.
No matter how careful I am some ca always ends up where it's not wanted. I've found that if I carefully place some debonder on the ca and let it work
into the nasty ca it will soften and can often be scrapped off.
But in the end I admit ca can be evil evil stuff.
First, a happy, healthy and peaceful new year to all.
i just tried my first bottle of Mercury Brand ca glue (medium). The glue itself works as well as any other glue I've used.
What sets it apart is the material used for the closuer...it works "incredibly" well!!! I used the entire bottle and never had any clogs, etc. They offer the basic range of products plus epoxy and have a website for more info...Moab
I use glue sticks (Elmer's, Scotch, etc) 80 percent of the time. Inexpensive, clean and I've never had a glue-up problem with them...Moab
- thibaultron, Seventynet, mtaylor and 1 other
- 4
Thanx to all. If I move ahead I'll do a build if possible. Thanx again...Moab
- mtaylor, lmagna and thibaultron
- 3
I'm considering building the BlueJacket "Spray" kit. I've built other BlueJacket kits and am always impressed with the quality. Does anyone have any information about this kit or better yet building the kit?...Moab
Fantastic! Please give us some updates as you begin working with it...Moab
- mtaylor, Canute and aviaamator
- 3
Guys and gals; my apologies for the last post. Not sure what I did wrong. Perhaps indenting doesn't work...Moab
- Canute, thibaultron and mtaylor
- 3
Beautiful knife.
I'm not sure I have a top four but:
-Lee valley low angle block plane.
-Violin makers plane. These are very small and rather expensive but fantastic. Not
sure what type of steel they use but the blade remains very sharp for an
extended period. I think Lee Valley sells them.
-I get a great deal of use from my digital readout caliper. I've tested it and it's very
accurate.
-I consider glue a tool. I use Loctite gel glue (not the gel in the black applicator) for
many applications. To achieve a bond it only requires a "very small" amount. A tip I
learned somewhere is after you can't squeeze out any more glue cut off the exterior
plastic housing (very carefully...try not to puncture the inner tube). The remaining
tube extends the amount of usable glue. This technique yields almost twice the amount
of this "pricy" glue.
- mtaylor, Canute, pontiachedmark and 1 other
- 4
GL; the progress really looks great. I've tried many methods of prepping wood for planking. I haven't tried the ten minute in boiling approach. Is this your "go to method" when you do planking? Does it work for those tough bends?...Moab
Fécamp herring lugger by Javier Baron - FINISHED - Scale 1:200 - Lougre harenguier
Thank you for posting your this project. A true work of outstanding craftsmanship.
Where can I get more information on miniature scale building...Moab
