Posts posted by Moab
Steve; great build!! I got some awesome tips for jigs. Thanx for all the great pix...Moab
Are diamond files overkill?...Moab
FYI; a few months ago I started building the Dušek COG. I became interested in the COG after seeing a model at the Maritime Museum in San Diego. It's a great museum!!! I was corresponding with Daniel and asked if he'd do the kit in walnut. He was very accommodating and great to work with. He produced the custom kit for me. I'm not sure he wants to do this regularly but it's great to work with someone who went out of his way to do this.
Excellent video. Thank you for posting...Moab
- Canute and thibaultron
2
I use many different ca glues but my "go to" ca is Loctite gel (in the gray bottle not the black container). One thing I learned over time is to use a "very small" amount. I also learned (on a airplane forum) that when you can no longer squeeze out any glue you can "carefully" cut apart the plastic outside and use the glue remaining in the tube.
Cristi; thanx for sharing!! The building and results process are VERY impressive.
The "scratch building" discussion will probably have voters on both sides. I belong to a few other sites and "I think" most members would consider using 3D printed parts part of the scratch process especially when they develop the cad files for the process. One parallel that comes to mind is that most scratch builders probably don't cast or turn the cannons they use in the scratch building process. I can't vote on this since I'm as far removed from being a scratch builder as possible...Moab
- mtaylor, thibaultron, lmagna and 2 others
5
Agree. The extended rip fence and miter extension are important. I also found the micrometer adjustment very helpful.
A lot depends on what you will use the saw for. For example if you want to cut planking from expensive wood you might want a zero clearance insert and a slotting blade.
Whatever you purchase the Byrnes equipment is awesome...Moab
I recently moved into a codo so my large shop and scratch building days are over. My "shop/office, etc. is about 6' x 12' (next to the kitchen). I call it "the cave". Not much room for a vacuum system. I recently purched a ShopVac Micro. It has plenty of power and so far seems to meet my needs....Moab/Allan
- thibaultron, lmagna, mtaylor and 1 other
4
Love it!!!!!!!!
- cog, thibaultron, mtaylor and 3 others
6
Yup. Those look like the little red cups I have in my safe. Thank you, thank you!!!!!! Moab
Wow!!! Lots of replies in a very short period of time. It seems like CA has lots of fans and detractors.
I often use it but obviously need to be very careful. I've used the cut off sewing needle approach for years and it works well. After the needles get gunked up with glue I use a small candle and burn off the glue. After I've used the glue I tap the bottle against my bench and this usually keeps the bottle open. If not I use T-pins
to open the nozzle. Years ago I purchased small red plastic cups (about 1/4" x 1/4") from one of the woodworking suppliers. They were great. I put the ca in the cup and dunked the needle into the cup to load the ca. I've gone online but can't finds these cups anywhere. I have about fifty cups left and keep them locked in a safe.
I’ve had great success with his slitter blades. You might want to call Jim. He’s been very helpful in the past....Allan/Moab
- Canute and genericDave
2
I've been looking for s "small" grinder/sander. This may fit my needs. Thanx for posting...Allan/Moab
- Canute, thibaultron and mtaylor
3
Dan’s needle idea works great.
What I’d like to know is where to get “really great quality” tools. Most of the online suppliers offer good stuff but not great stuff. For example the tweasers you get from most of them are good but not great. I’m sure a great pair from a good jewelry supply store would cost more but I’d like to have choice to buy great products.....Moab/Allan
- mtaylor, thibaultron and Canute
3
As many have said it’s all about the quality of the “steel” (and you can’t go wrong with Veritas or Nielsen) and “sharpening”. However it doesn’t matter how good your steel is if you don’t know how to sharpen. For me learning how do “great” sharpening is the key. Using a well sharpened chisel is an incredible experience (in my opinion).
- grsjax, thibaultron, Canute and 2 others
5
Thanx for passing along Bob. I've used them and they are excellent. The only problem I have with them (not really sure this is the brand it might be Norton) is that the they don't allow you to cut small pieces and glue them to a small piece of wood for sanding in small places etc. It has a backing that doesn't seem to allow this. I usually use white glue to do this since some of the pieces are relatively large and using ca doesn't seem to be cost effective. Not sure if anyone else has this problem and like I mentioned I'm not sure it's this brand....Moab/Allan
Tweezers anyone
in Modeling tools and Workshop Equipment
I found a couple of excellent tweezers a Sally's Beauty Supplies. They cost about $10 each but the quality was much better than the ten tweezers for $11 found
on many sites. You can also find a range sanding sticks.....Moab
