Tonphil1960
  1. I’m just amazed by the quality Mark. I can’t believe you turned that brass for the cleats with no tail stock !
  2. You need a punch and die set. MicroMark has them. Its a slow process.
  3. Mark, you’ve made great progress. The quality of your work remains excellent !
  4. Excellent work. I am looking into building a Oneida. I cant seem to find much info on her at all. What plans are you working from ? Do you know where I can get scale plans and rigging plans ? Thanks
  5. Good progress. Move slowly and carefully and you'll be fine. Not as easy assembly.
  6. Very interested in this. Im trying to find a great price. Is the ZHL kit a knock off of this kit ? Following. Thanks
  7. Yes understood. I can see doing it but I’d didn’t work out for me. Good luck
  8. I used the Hahn method for frames and have spend many hours on my LeRo and in the end I’m going to scrap the entire project. I made serious mistakes in haste because I didn’t want to cut each frame piece individually. The joints of the frames keel and keelson are very very critical. I succeeded with my Blandford section by doing the frames piece by piece and the correct way. I didn’t want to spend the time doing it on this model with bad results. By all means glue up the frames over the template leave them all larger all around and sand to shape. I’d hate to see you in the position I am in.
