Everything posted by Tonphil1960
You need a punch and die set. MicroMark has them. Its a slow process.
I used the Hahn method for frames and have spend many hours on my LeRo and in the end I’m going to scrap the entire project. I made serious mistakes in haste because I didn’t want to cut each frame piece individually. The joints of the frames keel and keelson are very very critical. I succeeded with my Blandford section by doing the frames piece by piece and the correct way. I didn’t want to spend the time doing it on this model with bad results. By all means glue up the frames over the template leave them all larger all around and sand to shape. I’d hate to see you in the position I am in.
I'm interested in how you found the instructions. Were they detailed enough that many questions didn't have to be asked or were they lacking ?? Great work.
I think the larger scale would be much more impressive when done also easier to work with the larger parts. Yes though, where to put it when done is an issue.
- 1,132 replies
Hi Mark, Haven't checked in for quite some time. I've been busy building and flying balsa planes. Your progress is really is fantastic. You're maintaining the exacting accurate work you started with. Your work will continue to be my major reference. Hoping to get back on mine in a couple months. Love your shop ! Tony
