Everything posted by ClipperFan
Vladimir, great observation. You are of course correct, interior moldings are even more ornate than exteriors, which is amazing. I will try to sketch them from the enlargements you've shared. As for the Pinrail, it strikes me that it would run across the Bulwarks of the main deck, starting at the Bow just behind the end of the Quarter Deck and terminating at the beginning of the Poop Deck. When you think of it neither of those other decks have need of belaying pins as much as the main deck would. Rob can correct me if I'm wrong.
Rob, per your confirmation of Glory's Pinrail location, submitted here for your review is my revised bulkhead cross section with appropriate Pinrail included. I also cleaned up some of the dimensional call outs to be less confusing. And.... wouldn't you know it, as soon as I posted this sketch, I spotted an error. So it's been re, revised to indicate more accurately that from the exterior, the Planskeer Molding is actually 8 1/2" above the deck line, since the Waterways are recessed 3 1/2" into the Deck Beams.
George, placing tiny scale flat plates on a curving surface has got to tax your patience for sure. I don't envy you but the results of such practiced tedium will certainly be worth it.
- 602 replies
- Flying Fish
- Model Shipways
Rob, there are two illustrations of pinrail mountings. Detail F: continuous carved panel (clamp?) between Main Rail Molding then Pinrail is mounted inside to Intermediate Rail. Is that the same as Sheerail? Detail J: pinrail is mounted inside directly below Main Rail Molding. Did Glory have both styles or just the one? From photos it looks like she had detail F style. Your thoughts?
Vladimir now for something completely different. Since you mentioned doing the Sheerline moldings, I thought you might appreciate seeing this. Here, as best envisioned by me, is a cross section of Glory's Port side bulwarks looking Foreward, with interior dimensions on the right and exterior on left. I tried to incorporate every visible molding as can be determined by many photos available. Interestingly enough, when the 3" wide Main Bulwarks strakes are counted, there are exactly 8 visible between the 2 6" wide shelfs (for lack of a better description) which mirror each other top and bottom. All dimensions are, as usual taken directly from MacLean's 1869 highly detailed specs most likely supplied directly by McKay's Shipyard.
Tony Hunt when you describe "GLORY of the SEAS" as massive grace you are really capturing one of the most defining characteristics of Donald McKay's vessels. They were huge in comparison to their contemporaries. Yet as you so astutely pointed out, while these were enormous Ships, they were incredibly graceful and beautifully finished too. Many contemporary newspaper accounts describe that whenever Glory sailed into Port she was one of the most popular Clippers to be seen. Rob and Vladimir are both being very faithful to McKay's longest lived final Clipper.
- 3,560 replies
- clipper
- hull model
Rob, she does indeed resemble the San Pedro scene. More visual confirmation that your reconstruction of Glory is spot on!
- 3,560 replies
- clipper
- hull model
Rob, I seriously doubt anyone will notice it. Only annoying perfectionists like myself, which fortunately isn't a large percent of the population! Meanwhile, though I bet most Sailing Ships would have something similar. It makes sense not to have either spar able to rotate in strong winds or heavy seas.
- 3,560 replies
- clipper
- hull model
Rob this is definitely an improvement for the Bowsprit dimension. I'm going to highlight another fascinating feature of the inner Jibboom, which you might like to incorporate too (or not, if it's too much of a bother). Like the Bowsprit below, the Jibboom transitions from round to oblong a few feet before it enters the corresponding rectangular slit in the monkeyrail Bulwarks. I think we discussed this finding a few months back. Note the arrow shaped shadow at band 3 above Goddess 'Athene's' head? That's where the inner Jibboom is squaring off. In the 1911 Seattle bow close up, it also appears to slant down gradually from that same location. This is tougher to see since it's hidden by the jib sails resting on it. Since the monkeyrail height is 18" and this spar is at least 19" maybe even 20" that would be necessary to accomodate the smaller opening.
- 3,560 replies
- clipper
- hull model
Rob, no problem. Meanwhile I'm just amazed at your single piece Bowsprit Cap!
- 3,560 replies
- clipper
- hull model
Rob, when looking at your proposed new spar I immediately see a scale problem, which I hope my observations can help you identify and correct. The flattening of the top part of the Bowsprit on Glory is about 18" (3/16ths") from the top of the main bulwark Rail, then Band 1 is about 1' (1/8th") of that distance. Your new spar doesn't allow for that, so where you've sketched your first band is too close scale wise. From your measurements, we know that 7 bands are 3' (3/8ths") apart, center to center, it looks like the distance from the center of band 7 to inside the Cap is 18". The Cap itself also appears to be 18" since it seems to match the distance from band 7. That would make your Bowsprit a minimum of 3 3/16ths" to comfortably include a mounting point for the Cap. You might want to sketch out the entire Bowsprit on paper, leaving extra length to accomodate the entrance into the Bow. I hope this helps.
- 3,560 replies
- clipper
- hull model
Rob, great catch to see that relatively slim detail. Initially I was so impressed with the overall look that I completely missed it. In the future, if you'd like me to 'backstop' your calculations (you or Vlad) I would gladly give you the most accurate calculations I can generate. As carpenters always say "measure twice, cut once." Of course, this is in no way my attempt to interfere in any way on either of your plans but only to offer my assistance.
- 3,560 replies
- clipper
- hull model
Rob, when the two combined are complete, the upper Jibboom will fit neatly into the 18" monkeyrail with the cut down area joining the top evenly. As the Jibboom sits now on your model, it is just slightly below the joint of the monkeyrail. When your Bowsprit is scaled to 34" this should move your Jibboom up properly to match with the top of the monkeyrail, as seen in this 1911 Seattle Bow close up.
- 3,560 replies
- clipper
- hull model
Rob, Vladimir according to Duncan MacLean's description from 1869 the Bowsprit's dimensions were 24' inside of the Cap and 34" wide. While the Jibboom isn't described by width, I measured the dimensions of the 1911 Seattle Bow close up, I got 7/8ths" for the Bowsprit & 1/2" for the upper Jibboom. Dividing 4/8ths (1/2) by 7/8ths or simply 4 ÷ 7 =.57 x 34" = 19". In 1:96 scale, 34" = apprx 10/16ths" & 19" = about 7/16ths". Here's my sketch of the Bow at 1:96th scale 1/8ths" = 1'.
- 3,560 replies
- clipper
- hull model
Vladimir, the gap between your Bowsprit and Naval Hood profile below hopefully should be closed by the time all your rigging is done. We see this space in numerous pictures of Glory after her long Jibboom is cut off. If you look at the scenes of Glory when she's fully rigged, there's almost no space between the Bowsprit and Naval Hoods, as it was cinched tight for seaworthiness.
Vladimir I'm honored that you value my input so much. Just to set the record straight, I am continually in awe of the natural skills you and Rob display in crafting these glorious Clipper Ship models. As for my abilities, maybe someday I'll consider attempting one of my own and boy howdy will you know an amateur at work when, if you see one! What astonishes me about your work Vlad is that, not knowing this is a miniature replica, there are some close ups that make it seem like you're actually staring at a real ship under construction! I agree fully with Rob's observation too, you have managed quite nicely to follow the challenging complexity of Glory's Hull which even Duncan MacLean described as transitioning smoothly from concave to convex. Again, especially as I see both of your impressive ships come to fruition, it becomes ever more clear to me that Donald McKay did indeed meld lines of his famous Extreme Clippers "Stag Hound" and "Flying Fish" with the largest, flattest cargo carrying capacity imaginable combined with an incredibly lofty and powerful sail plan. As for your lovely Cutty Sark model, is that 1:96th scale?
Rob, the Bowsprit, Jibboom combination are just beautiful while being faithfully accurate to the original herself. Probably one of the most exciting developments in our examination of Glory's true dimensions was when Michael Mjelde shared that crystal clear close up of her Bow and Figurehead. You, I and others were able to precisely count very specific measurements that have allowed accuracy that simply wasn't imaginable before. To see it recreated in miniature in such meticulous detail is constantly thrilling. As much as she impresses in these photos, your model must be even more stunning in person.
- 3,560 replies
- clipper
- hull model
Rob, as I just said a moment ago, it's rapidly becoming more and more of a challenge for me, who usually doesn't lack for words to continue to express my sheer amazement at the progress you demonstrate. This Glory is just so beautiful. It so closely resembles the scene of Glory at the Seattle dock that it's just uncanny. As you continue to develop her lovely, very sharp Clipper form it really justifies my suspicion that what Donald McKay achieved was an enormous cargo carry capacity vessel melded with the very sharp Clipper entrance and exit of the Extreme Clipper "Flying Fish."
- 3,560 replies
- clipper
- hull model
Rob, it becomes a challenge how to continually acknowledge your ongoing achievements with your miniature ship. I am just so thoroughly amazed at how much your entirely scratch built vessel so accurately resembles Glory herself. By the way, Michael Mejelde sent a very brief reply to my latest share of your series comparison to scenes of Glory herself, he said "I am impressed." High praise indeed from the author of now 3 books on "GLORY of the SEAS!"
- 3,560 replies
- clipper
- hull model
Vladimir, it's remarkable how you have reproduced Glory's very graceful Stern and Counter so beautifully. Between you and Rob, I do believe we have two of the most impressive "GLORY of the SEAS" Clippers ever built so far. That includes the one sitting in the Kennedy Library and examples I've seen in Mystic Seaport's collection of sailing Ship models.
Snug Harbor Johnny WOW! You are a genuine Renaissance Man! That is quite a list of accomplishments. If you don't mind clarifying some points on your first prize award winning 16" mirror. Is the small circle you're holding in your hand the prize or a component of the telescope. I see an identical pattern in the center of the very thick circular object on the table, which by educated guess is the 16" mirror. Are the white swirls part of the mirror or do they get cleaned off later? That telescope looks massive and potentially heavy, it must have been a bear to transport. Were you able to take pictures through it?" Finally you mentioned that you modified a harpsichord kit which you handcrafted. I have to believe you probably designed and sewed the entire 17th Century costume yourself too. Oddly enough, as soon as I saw the pic of you at the harpsichord, I immediately thought of impish 'Trelane' from "The Squire of Gothos!" Except you had the more challenging job. He could just snap his fingers to make his fantasies real.
- 3,560 replies
- clipper
- hull model
