TOM G
Everything posted by TOM G
  1. Check out, "Law of asumption Neville Goddard" on youtube. You can over come this... no matter what the doctors say.
  2. Go to you tube...... type in herbs to improve eyesight...... you can find these herbs on ebay. I use herbs and they work.
  3. Look's like what is happening is the air brush needle point tip is loading up. ( this reduces your volume output making a dryer coat ) This will realy hapen bad when you set the air brush to the side, waiting for flash time between coats. Take the front end apart clean it, and if your going to set the brush to the side for flash time.... spray Windex through it. Also make sure you have the right needle in the brush, you want the one for a high volume cause your covering a large area.
  4. You can use , Pledge floor care in a air brush and get a good shine.
  5. I always get amazed at how you can cut your stock at such high tolorences.👍
  6. I made a model back in my 30's.......... But she dump'd me for a rich guy. 😟
  7. Great looking build ! I have this kit, and the first thing i noticed was that life boat..... ( went in search of ) and found the prize. I think in time the vinyl strips will loose their grip and start to curl. I've built models where i had to drop the ball on...... But it haunts you, every time you look at the model you see that one area that is not in perspective. These life boat kits are plank on frame, they have the length you need. Get them at model expo type in life boats in the search box. 🙂
  8. spray slow dry lackuer thinner over it..... you might have to do it 2 to 4 times you will see it slowy disapear . don't flood it , one pass at a time, and wait between passes till the surface is dry to the touch.
  9. If you sand & re paint..... the hull will look like the bottom is a fiberglass hull. Best way out is to mix up a black wash ( 2 tsp of india ink into 1 pt of 91% alcohol ) put the wash over all your bright colored paint'd area's using a brush...... you can re coat the wash after it drys if you prefer. The result will be a weathered hull witch will give a more real look to who ever views it.......... When you get to your sails soak them in tea and they will match up with the rest of the vessel.🙂
  10. Hull planking for beginners. https://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf
  11. I like your setting of the sails....... shows action taking place....... be nice if you could find some figurines that are pulling rope, that would put the icing on the cake.👍
  12. I know it's going to be a well detaild build......... I'm going to enjoy watching the progress.👍
  13. That's going to be a fantastic model when done, a sure one of a kind.👍
  14. Yes, it's worth your time to make it "ship shape".
  15. Some guy's dip the sails in tea. Once dried dip again to get darker. Brew up some and test it on simular material.
  16. You want to pay attention to the garboard plank........ check this out https://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf
  17. Try this link https://thenrg.org/resources/Documents/articles/LiningOffYourHullPlankingTutorialAndFan.pdf
  18. Look at page 20, then read up on the garboard plank..... you have to make a new one. https://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf
