TOM G
Members-
Everything posted by TOM G
Go to you tube...... type in herbs to improve eyesight...... you can find these herbs on ebay. I use herbs and they work.
F-84G by Javlin -Tamiya - 1/48 - PLASTIC
TOM G replied to Javlin's topic in Completed non-ship models
Look's like what is happening is the air brush needle point tip is loading up. ( this reduces your volume output making a dryer coat ) This will realy hapen bad when you set the air brush to the side, waiting for flash time between coats. Take the front end apart clean it, and if your going to set the brush to the side for flash time.... spray Windex through it. Also make sure you have the right needle in the brush, you want the one for a high volume cause your covering a large area. -
You can use , Pledge floor care in a air brush and get a good shine. -
I made a model back in my 30's.......... But she dump'd me for a rich guy. 😟
Great looking build ! I have this kit, and the first thing i noticed was that life boat..... ( went in search of ) and found the prize. I think in time the vinyl strips will loose their grip and start to curl. I've built models where i had to drop the ball on...... But it haunts you, every time you look at the model you see that one area that is not in perspective. These life boat kits are plank on frame, they have the length you need. Get them at model expo type in life boats in the search box. 🙂
- 46 replies
- Mayflower
- Artesania Latina
Milky patches under lacquer coat
TOM G replied to Clive's topic in Painting, finishing and weathering products and techniques
spray slow dry lackuer thinner over it..... you might have to do it 2 to 4 times you will see it slowy disapear . don't flood it , one pass at a time, and wait between passes till the surface is dry to the touch. -
If you sand & re paint..... the hull will look like the bottom is a fiberglass hull. Best way out is to mix up a black wash ( 2 tsp of india ink into 1 pt of 91% alcohol ) put the wash over all your bright colored paint'd area's using a brush...... you can re coat the wash after it drys if you prefer. The result will be a weathered hull witch will give a more real look to who ever views it.......... When you get to your sails soak them in tea and they will match up with the rest of the vessel.🙂
Planking Book?
TOM G replied to BWDChris's topic in Building, Framing, Planking and plating a ships hull and deck
Hull planking for beginners. https://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf -
Mayflower by tj456 - 1/19 scale
TOM G replied to tj456's topic in - Build logs for subjects built 1501 - 1750
That's going to be a fantastic model when done, a sure one of a kind.👍 -
Yes, it's worth your time to make it "ship shape".
You want to pay attention to the garboard plank........ check this out https://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf -
Planking Help Needed
TOM G replied to JDillon's topic in Building, Framing, Planking and plating a ships hull and deck
Try this link https://thenrg.org/resources/Documents/articles/LiningOffYourHullPlankingTutorialAndFan.pdf
