Everything posted by Ras Ambrioso
Work continues. The rigging of the davit for the small boats required a double block rig. I had purchased miniature blocks to keep the scale. These blocks were so tiny that I could not feed feed the lines through the sheave's holes. The plans called for a double line set up but I decided to simplify it to a single block. To this effect I stropped the mini block with very fine copper wire Then I made a jig to fabricate the hooks that worked perfectly Then I fabricated miniature cleats The results were satisfactory Last but not least I tried to make a decent looking Brazilian flag. I found a source that had the printed flag to the right size on a a very fine cloth (chiffon) which permitted seeing both sides of the flag. I tried several ways of making this flag to look alive but failed. Then I just just opted for the commonly shown rigid look. Please forgive me. And that completed my presentation of the model of the Amapá, a 1907 Brazilian Customs cruiser. Following this post are the pictures that will also be posted in the gallery of finished models.
Progress continue.Previously I have worked on the louvers for the skylights on opted to simply draw them up. This was shown in my post #98. I was not very happy with this and kept searching another solution. I found it while browsing a model RR web site and found HO scale clapped siding that at my scale fit perfectly for the louvers. And here is the latest look of the skylights Completed the ship's boat and installed in in their respective mounts. Also finished the stern railings The work left is the erection and rigging of the boat's davits. For this I ordered miniature wood blocks that arrived today. They are minuscule (2mm) and I am now trying to figure out how to thread the line through them. But that is the fun of this build. That will complete this model on time for display at the end of the month in the lobby of my building.
When we think we have seen it all, you come back with an incredible answer to the small scale boat building. WOW, WOW, WOW
I expect to complete Amapá by the end of August and get started on this project. My experiences with Amapá have given a lot more confidence in my builds and this model has the advantage of starting as a kit. I expect to have a lot of fun with it and to share it with y'all.
Talking about boat building, I went back to my ruined dinghy mold and refitted it for another try at resin molding. First I reworked the damaged mold. Following Valeriy suggestion I formed the stocking under pressure using making tape. I placed a layer of resin and, while still sticky, added another layer of stocking material and resin 24 hours later I tried the removal of the hull from the mold. The results a beautiful strong small hull. I followed all the hints and suggestions by the forum: seal the mold with lacquer, cover the mold with saran (plastic) wrap, apply the stocking material over the plastic and lock it in place under pressure. Then I applied the resin and a second layer of stocking material and resin. I am more than pleased with the results. But, I have been advised by the art coordinator in our building that the displays in the lobby will be changed by the end of August. This will mean I will have my old Fifie back and an empty space in the display is available for new models . So, as it has been in my old career as a construction engineer, the deadline is on. Amapá is almost finished so I decided to use the other two ship boats molds as solid models and presented them as covered boats in their respective supports. The photo shows my intent. I got a lot of suggestions for the material to use on the cover and tried the tissue with no good result. Finally, I decided to use fine linen from one of my old handkerchiefs soaked in watered down PVA glue. I will post the result shortly. Continuing with the build, I completed the standing rigging on the mizzen mast. And finished the work on the forecastle. The work remaining now is to complete the ladders to the midship deck, the dinghy details and the boat's davits. Finalizing the show with the remaining railings aft.
After I completed the fabrication of the ladders I was still trying to figure out how to transition the ladder handrails to the deck rails. The other night, while watching an old movie named "Away all Boats", I noted that the ladder handrails were independent of the deck rails as seen on the following screen shot. I made a jig to bend the wires and decided, again, to try my hand at soldering. I have read a lot of articles and suddenly had an epiphany. What I was doing wrong was to heat the joint and then tried to melt the solder into the joint. One of the comments I read was to set the solder on the tip of the welding gun and then transfer it to the fluxed joint. Worked like a charm. The jig: The finished product: The same procedure was used to make the fantail flag staff.
Well, well well. I am thrilled at the response that y'all had on my ships boat building. I want to thank each and everyone of you for your support. To mcb: Yes, the material I used for the fairways was 1/4"X1/16" brass bar available at Ace's hardware stores. My biggest problem on this item was to get four of them the same size. Later I realize I could have made the fairways easier with an elliptical hole as shown in the photo. To Bob: good advise. Will try the tissue paper route and the saran wrap ideas. As a matter of fact, my first thought for these boats was to make them out of "papier-mache". Besides, this, being my first scratch built, is a testing and learning project. To Valeriy: again thanks for your comments. The photo of the stocking under tension is great. To Wefalk: I have been following you "ships boat" building and found it fascinating. Your idea to show the boats under cover is very accurate in the real boats and saves innumerable hours of detailing for the interior at small scales. I will probably do it on the two large boats on Amapá and detail the little dinghy. To Roger: again thanks for you comments and I will be looking for your tutorial on NRG. Like I said before, this model is my scratch build education.
Glad to hear you are well. Your little boat is precious. I am close to that to doing a similar job on my Amapá.
I proceeded with the idea of making the ships boats out of reinforced resin. I made the molds and and finished them with three coats of shellac with fine sanding in between. When properly dried, I applied carnauba wax to the mold in two layers. Then using the hose stocking's material, provided by the Admiral, I applied the resin. I tried to smooth it out the best I could and left it to dry 24 hours. Then catastrophe!!! As I tried to remove the hull from the mold parts of the hull where still adhering to the mold and I could nor get a clean casting. I will rest for a while and figure it out. Initially I think that my mold release was not sufficient, that I should have trimmed the cloth more around the mold and that, perhaps should use two layers. I would appreciate your comments and suggestions. But still more remains to be fabricated. The finished bollards need their fairleads. Following is the method I used: After drilling two holes in line I carved the fairlead shape with jewelers files And this is the result. Success All I need now is to make the other three I need, reduce their height a bit and glue them their bases. Now the cold beer is waiting. Another day in the life of a model boat builder.
Glad to hear you are Ok. The cutter looks great. Saturday I epoxied the little dingy for. Amapa. Hope it comes out well.
My next challenge were the ship's boats. Three of them. Today I stated picking out what to use for the mold. I had oak, mahogany and balsa. After much though, I figure that balsa would be easier for the carving so I cut a block of balsa, pasted the top and side plans of the first boat, a whaler. Then I proceeded to cut out the shapes and following is the results I sealed the mold with polyurethane and added a small tab to the bottom to allow holding the mold in the vise. Now I have to wait for the Admiral (she is out of town) to get a used panty hose to make the first boat. I can't believe that I did all this in one morning while it took me close two weeks to complete the ladders. More to follow.
Francis, Thanks for the tip. Unfortunately I live in Florida quite far from Ontario. But your model looks awesome and I have wondered the same thing about the figures. I would love to know where you got them. My scale is 1/24 which is a little larger I have very little information on the cockpit details. My plans only shows to big hand levers at each side of the helm. It also appears to have no partition into the engine room. I have not done any work on this model yet, other than purchasing the hull. I am still completing my other project: Amapá, a Brazilian custom cruiser scratch built in 1/64 scale.
For the last two weeks I have been struggling with the ladders. After listening to Kevin Kenny's video I ordered a new tilting arbor saw that also permitted controlling the height of the blade. The saw that Kevin uses is a Byrnes and it is quite expensive so I went for the Microlux from Micromark. Unfortunately, the fence has to be relocated by hand and eyeball every time. Regardless, I managed to get the ladders built as shown in my previous posting. Once I tried in the model it looked awfully out of scale. I decided to tinker around and build a double draftsman "T" fence. This one worked a little better but I still had trouble accurately cutting the groove while advancing the fence by hand. Then I went back online to Micromark and found they have a fence attachment called "accuriser". As you can see in the photo it is a sliding fence that holds parallel to the blade. Can be adjusted in 0.005" increments. It also has a draftsman T lock end. This did the job an I was able to cut the and groove the sides of the stairs closer to scale. I used a jig to assemble the stair and proceeded to install the steps using a super thin walnut veneer. All was going well until I decided to challenge the saw and try to get the sides thinner. The catastrophe stroke as the saw very cleanly broke all the steps. If you notice on the picture the grain of the veneer was running by the short sides. LOL. Back to the drawing board. I redid all the stairs now using paper stock for the steps and this did the job. I have to say that it still has a fews booboos but for it looks acceptable to me. Next I will be tackling the masts rigging and build the ship's boats. I have been thinking about making a solid wood mold and use dope and tissue to make the hull. Something like papier-maché. Thanks for watching.
Amazing. With my +/-0.5 mm tolerance I’ll never make it. I have struggling trying to make my ladders (1/64 scale) more to scale but haven’t got it right yet.
Valerie you are a genius. One of my future projects on Amapa is the boat davits. I cannot get the details like you can but I’ll try my best.
Progress continues. To fabricate the stairs I found that they were too small to use the same method I used on the Fifie. So I did a web research and found the videos by Kevin Kenny on the building of the steamer Naparima. HIs videos are excellent "do-it-yourself" guides. Using his methods I completed the sideboards for my midship ladders. The steps are minuscule and I will be installing them tomorrow but I was so excited about my success that I wanted to share it with the forum. On the top of the picture is the method used. I think that the secret lies in using large wood stock, cutting the grooves on both sides by reversing the miter guide and then slicing the sideboards. The result is a bit over-scaled but I have a limit on how small I can make stuff.
Well I am back. These last few weeks I have been busy on a "volunteer" project at my building. Now that is done, I am back at Amapá. It is taking a considerable amount of time do some of the miniatures, specially, when I got to figure how to do it. Having seen what people like Valerliy and Wefalk can do with soldering I have tried to emulate them. Following is my first attempt at the cross bracing for the bridge Not too Not bad but, I am not sure I can do a clean job while working directly on the model. My hands shake too much. Therefore ,I think I will leave soldering for the next project once I practice a little more. In the meantime AC glue is doing the work. Next I fabricated the spider webs for the masts rigging. . Another fitting for the bow's stay ends. And finally completed the bridge railings and awning frame and the forward jack staff. A few things are still left to do, specifically the the railings, the boats , the ladders and the rigging. Thanks to all of you for your support and example. This model has been quite an education and, even though there are many mistakes in my work, I am satisfied and eager to complete it.
Again an excellent performance at micro scale. I will follow your conclusions when I get to build the boats for Amapa. Originally I planned to use some scale plastic boat hulls and build the interior structure on one of them. now I am going to do two of them covered like yours and for the small one I will try to plank against a mold and detail the interior. Fingers crossed!
