Everything posted by Egilman
The first patent on the aileron control system was granted to the British scientist and metaphysicist Matthew Piers Watt Boulton in 1868. He introduced the concept of three axis control in his 1864 paper "On Aërial Locomotion". He was the first to conceive an aileron flight control system... 39 years before the Wright Brothers used wing warping.... (the brothers had a copy of his paper in their library covering the engineering history and theories of heavier than air flight, they knew all about it) Yep, they took the wing curvature pressure table from Lilienthal, (and corrected it) The wire braced Pratt Truss design from Chanute, (and modified it) The wing control method from Boulton, (combined with their own inspiration to make it work mechanically) Then built upon those contributions with their own experiments narrowing down the engineering and applying their inspirations from said experiments in making what they understood actually work... So yes they were the first systems integrators as well as being scientists, a very unique combination of engineering and creative thought.... Not bad for a couple of bicycle mechanics...
Handley Page Heyford by RGL - FINISHED - Matchbox - 1/72
Egilman replied to RGL's topic in Non-ship/categorised builds
More like tempting god in this case, (or the Admiral, if she finds out first) -
Actually, it is the branch of science called Fluid Dynamics, something the Wright Brothers were the first to actually understand applies to gases/vapors under pressure as well as liquids.... Live Tails, (or as they are commonly called today Stabilators) are the result of a long period of trial and error relearning something the Brothers knew instinctively from observations of a simple wing profile in a wind tunnel.
I just grabbed Sunwards last G1, resistance was futile..... -
US 6” gun by RGL - FINISHED - Panzer Concepts
Simply Outstanding.... Very impressive piece as well... Will be even more impressive when the complete train is together... (gun tractors and lorries) Nice work... -
Hey Brothers, I've been doing some research into this tailplane issue.... Yes the ledge is there, it was there on all Blackburn Bucs.... The Horizontal stabilizer is a live surface, fully moveable, It never had an elevator, and the round fairings moved with the livetail... Those surfaces that look like elevators are flaps, they are designed to provide uplift to the nose of the aircraft at low speed as the aircraft at low speed tended to pitch down... The flaps were automatic and moved as aerodynamics dictated.. The flying tail also had boundary control as well as hot air deicing... There was no need for downward deflection flaps on the aft edge of the tailplane so they were designed to remain neutral when not active and the ledge in the aft fairing made it mechanically sure to never go into a pitch down situation.... Not my opinion brothers... Will provide references if desired....
It's a live tail.... The whole horizontal stabilizer turns up and down.... And yes, it is to effect better control and eliminate leading edge compressibility issues at high speeds... The trailing edges are a throwback to when the aircraft was first designed with conventional elevators... (much like the F-86 was) On the F-86, the former elevators became the new trim tabs.... I suspect much the same happened here, probably saved them several millions of development pounds/dollars....
Just my opinion, in the images of the completed bike that were posted above, it has to be an oil tank.... The reason I say this is it is the only way it makes sense and the line from the tank goes to the rocker assembly.... Since the oiling system on all these early bikes was gravity flow or hand pump fed, this has to be an early form of oiler.... The large tank feeds the crankcase, the small tank feeds the head... On the opposite side rising from the crankcase to the head is the drive tube for the camshaft, I see no other provision for getting oil to the camshaft journals... Harley used a similar system on some of it's very early bikes....
it's almost become a lost art..... Of course I would be one foolish enough to try it.... {chuckle} -
There are references my friend... See if you can find a copy of... Thomas, Chris and Christopher Shores. The Typhoon and Tempest Story. London: Arms and Armour Press, 1988. ISBN 0-85368-878-8. Thomas, Chris. Hawker Typhoon (Warpaint Series No. 5). Husborne Crawley, Bedfordshire, UK: Hall Park Books Ltd., 2000. Shores, Christopher and Chris Thomas. Second Tactical Air Force Volume Four. Squadrons, Camouflage and Markings, Weapons and Tactics. Hersham, Surrey, UK: Ian Allan Publishing Ltd., 2008. ISBN 1-906537-01-1 Chris Thomas is the guru of everything Typhoon and Tempest, there is no better source.... I'm currently looking thru my library brother to see if I have a copy of Warpaint #5.... If I do I'll let you know...
Well your correct, it was designed as a 400kt+ interceptor to counter the FW-190 which was kicking Spitfire tail when it was introduced... and once the aircraft was proved, the air ministry pre-ordered 1,000 craft... but that order was never completed they were the Typhoon Mk 1A's... It's issue were engine and structural related which made it's fighter role problematic... The aircraft was redesigned with improved engines and cannons rather than machine guns and structural improvements which weren't completely successful... (the Typhoon Mk 1B) The typhoon had a bad reputation for shedding its tail in flight... Although they got that issue down to acceptable levels, it never completely went away... During '42, the Germans developed a new tactic using the FW 190 as fighter bombers launching low level harassing raids on the southern english coast... the Typhoon achieved it first small run of success during this period where it managed to intercept and shoot down many of the fw-190's, but I believe this was because of the 190's overloaded condition.... After that partial success, it was decided because of it's low level flying characteristics, fast and heavy armament load... They decided to try it out as a fighter bomber.. so mounts were installed in the wings to accept bombs or rockets, the rocket launchers and bomb racks used the same mount and firing circuitry... the intention was to field mixed units of rocket and bomb armed aircraft to do low level sweeps over enemy territory... In practice though, this idea was found to be impractical, as both dropping bombs and firing rockets on target took completely different skillsets, so they broke the bomb and rocket aircraft into separate squadrons flying form the same airbases... In this role the Typhoon Mk1B was a huge success... (although is still had the structural issues that were never fully resolved, and an engine that was underpowered and not completely reliable which was also never fully resolved) But yes all typhoons (except for a few early Mk1A's remaining) were bomb and rocket capable, and both types, bombs/rockets, used the same electrical firing circuits, so yes they all would have the stencil... (even the Mk1A's that were brought up to Mk1B standards) it didn't matter if they were a rocket or bomb equipped typhoon... (By D-Day, the RAF's 2nd TAF fielded 11 RP ("Rockphoon") squadrons and seven "Bombphoon" squadrons. I can keep digging up more, but British aircraft are not my strong suit.... You are correct brother, it was not designed as a fighter-bomber, I though it was... But it became very clear that ground attack was it's very best role... (and it became the basis of the Hawker Tempest, which was the best Fighter Bomber of the war bar none... (with all due respect to the IL-2 and P-47 crowd {chuckle})
Ras, I've owned and rode two cycles in my younger days, the first was a Harley M-50, loved that motorcycle... from back in the days when Harley made some of the best dirt/trail bikes around... Got a little older and built a 650 Triumph Bonneville, tuned engine, extended springer fork etc. etc... Had a very distinctive sound.... Classic chopper when building a harley chopper was way to expensive for a teenager and Triumphs were cheap and easy to work on.... My brother still has his 650 Maico Modena.... (and will never part with it).... Wish I still had either of mine today..... I don't have any pics of it wish I did... Your classic is going to turn out beautiful.... Early Protar kits had their issues just like any of the early manufacturers... You will do this one justice I think my friend....
AS well as being the last biplane bomber, it was one of the last open cockpit bombers as well.... (it was replaced by the Whitley & Wellington) One of the last missions it was given was testing an early application of down looking radar in 1940... It was definitely a technology transition aircraft... By the end of WWII most strategic bombers on the allied side all had very good down looking radar for bomb aiming making them all weather bombing aircraft, The Heyford led the way... -
Thanks for putting up with all of our noise brother... The cacophony of keypunchin is something to behold... I find it a pleasure to see that others do it in the mind just like I do... Sometimes it is just best to say it out and let the back -n- forth flow carry the idea to fruition... The ideals are the best thing shared, anyone can learn the skills, but the ideals of modeling, they develop over time and association with like minded builders... It's why I've made this my modeling home.... no other place like it on the net...
Nice! Another version I’ve seen involves painting the standard desert camo, then over spraying with a thin coat of EDSG. Done well, the underlying camo comes through as a two-tone blue. Yep, they were all over the place on colors at Malta, like anything they could get their hands on was used to try and break the the aircrafts silhouette... (although they pretty much stuck with various blue shades underneath, you will find some with aircraft grey undersides as well) AS I see it, it is an open canvass... Enjoy, I know I will your rendition of it...
Your absolutely correct, My source is apparently wrong.... Thank you for the link, the sad thing is that he was eventually separated from the service for disciplinary reason, By late '43, the RCAF was concentrating on unit teamwork tactics and his lone wolf style of flying was becoming a liability.... , He survived ten crash landings during his career as a fighter pilot and was shot down I believe five times... But to those that flew with him, he was one of the deadliest pilots in the air.... A shame there isn't more pics of him and his aircraft....
Well he was stationed there early '43 to mid '44... 30 victories while there... His assigned Spit Mk Vc, is likened to green over gray in most of the documentaries, but there is B&W photography that shows it is various contrasting shades that some have interpreted as Green/Grey, Green/Brown or Brown/Brown... Unfortunately, I have never found any record of what his recollections were of his color schema.... (much less the pattern) Most go with the Green over Grey in a right to left pattern and they were able, like you mention, to scrounge the grey from the Mossie squadrons.... Difficult one to nail down.... But it would be a beautiful build....
