Everything posted by Robert Taylor
ROYAL LOUIS - 1/200 HELLER WIP UPDATE. Improvised on poor kit Rigging instructions, Standing rigging now done, finished with all Walnut Heart blocks, Deadeyes, single and double blocks. Next stage will be the Running rigging, again which I will need to improvise on. I will also work as I have done before per mast, regards to Running rigging then Shrouds and ratlines for that particular mast then move on to the next mast and so forth. Happy modelling everyone 🤺🤺⚓⚓
- 22 replies
- Heller
- Royal Louis
Thanks for those kind words, yes the plastic ones that came with the kit were really poor, to thin, and soft and weak, they would never have stood up to any rigging whatsoever. I will need to develop both Standing and running rigging by myself, as the rigging instructions in the kit are pretty simplified if not basic, such is the way with a lot of kits. Thanks again and hope you are keeping well, #staysafe. Happy modelling 👍🤺🤺⚓⚓
- 22 replies
- Heller
- Royal Louis
ROYAL LOUIS - 1/200 Heller WIP update. All Masts,Yards,Bowsprit and Flagstaff measured, cut, built, painted, weathered and mounted. Deadeye platforms mounted with supports. Fighting Canopies/Crowsnests altered for rigging. Next stage Standing rigging.....
- 22 replies
- Heller
- Royal Louis
ROYAL LOUIS ARMED & READY update - HELLER 1/200 Decks all fitted and weathered along with Capstan, Stairs, Rudder and fittings. 120 Cannons now mounted with tiebacks on all 5 Decks. 74 Cannon port Arches mounted as is 66 Cannon Hatches. Royal Louis Figurehead and architecture fitted and weathered. Transom and side Galleries all fitted and Weathered. Bowsprit cut and mounted, modified from Dowels. Next stage will be to Measure, cut and modify dowels for All Masts Yards and Flagstaff.
- 22 replies
- Heller
- Royal Louis
Update on my ROYAL LOUIS 1:200 Heller kit. 32x 36 pounder Cannons (Main Battery) 34 x 32 pounder Cannons (2nd Battery) All loaded. Main Deck weathered and installed. 60 Deadeye straps installed. Next stage assembling 32x 24 pounder Cannons with tiebacks and installing onto the main deck. All in all coming together slowly, reading between the French and English(Download) instructions, as of yet no real problems at all apart from having to wash every part due to mould release so as to give proper paint application first time around. Still swithering whether to paint waterline same light wood colour as Upper Hull then weather it, albeit the waterline does not have any wood grain mould effect on it, but I have lightly sanded it down to give a Matt finish rather than painting it white. Long way to go, an enjoyable build taking my time. Happy Modelling Everyone Staysafe 🤺🤺🤺⚓⚓⚓.
- 22 replies
- Heller
- Royal Louis
Starting my New Build of 2021.... The "ROYAL LOUIS" 1/200 - Heller. The Drawing of the Hull, the distribution of the artillery and rigging were drawn from a description of the ship's lines by Comte d'ESTAING dated 25 September 1772. The building plans were prepared by the famous Naval architect MR, OLLIVIER. The ROYAL LOUIS was a first rate ship, it was armed with 120 cannons, including 32 x 36 calibre guns each weighing nearly 5 Tonnes. In 1779-1780, ROYAL LOUIS was a lead ship of the Blue-White Squadron, which was part of the so-called "Comte d'ESTAING" America Squadron. Prep work done to Hulls inside and out to make the paintwork more applicable. Cannon carriages started, 4 different sizes, 40 done only another 80 to go, then on to the Cannons themselves. This will be the most time consuming painting within the kit itself, even more so than the stern gallery architecture. 648 parts plus alterations, Big job ahead, quite probably replacing the masts with wooden ones as well. Happy modelling everyone Staysafe and take care 🤺🤺🤺⚓⚓⚓
- 22 replies
- Heller
- Royal Louis
It's been another Labour of Love... The "Santa Catarina Do Monte Sinai" Pyro:1/144 Scale FINISHED My depiction of the "Santa Catarina do Monte Sinai" in full Royal Regalia while saluting the marriage party of Beatrice, Portuguese Infantas marriage to CharlesIII, Duke of Savoy on the April 8th 1521. Adapted from the painting by Joachim Patinir. Happy modelling everyone ⚓⚓⚓🤺🤺🤺
Tbh, it was more out of curiosity regards different Manufacturers across the board, be it Lindberg, Revell, Airfix etc... Guess I just wondered if there was or should be one standard levels of skill ratings across all Plastic model ship building or should it stay the same regards different Manufacturers interpretations. At the moment I am nearing the completion of my First Pyro Kit: The Santa Catarina Do Monte Sinai, to which you can find a log on here. I also have a couple of other finished logs in Revell's 1:96 English Man O'war and Airfix 1:72 Golden Hind. These really are my first 2 Kits in nearly a 40 year hiatus, so I am bk learning again. I will say this though the Santa Catarina do Monte Sinai kit even though smaller is imho the same levell as most of the Airfix Classic ships series and better mouldings than quite a few other too. I suppose that's when I first started thinking about level ratings on model kits as I never really took much notice before and definitely wouldn't let it restrict me from buying a particular kit.
Question: Regards Lindberg kits. I know they issue theirs with a skill level, I have only seen levels 1-3, is there a higher level with lindberg kits? If not how would their skill levels compare to say Revell who have a level of 1-5? Just curious as i couldn't find any real information on Lindbergs Skill level ratings. Maybe some of our American modellers could shed light on this? Thanks in advance Robert
Santa Catarina Do Monte Sinai almost done, Sails are Hand sewn and rigged, weighing Anchors and Scratch making my own flags.
Hi there, Yeah I used 5mm deadeyes from caldercraft.
- 165 replies
- english galleon
- revell
"Santa Catarina Do Monte Sinai" Pyro 1:144 scale. Starting to take shape... Everything has came to a halt these past 6weeks due 12hr shifts and of course Christmas. Standing rigging & blocks done, next started rigging the deadeyes for ratlines and running rigging for each corresponding Mast. Looking forward to getting on with this and to finish her off with hand sewn sails, long way to go, but thankfully off work till the 7th January. Hope Everyone had a Merry Christmas, and Happy New year to you all when it comes. Happy Modelling ⚓⚓⚓🤺🤺🤺
Hi Bill, Still working on my Pyro 1:144 "Santa Catarina Do Monte Sinai" Everything ground to a halt these last 6 weeks with Christmas and 12hr shifts at work. Just finished the standing rigging, now onto the running rigging and ratlines per mast mate.
- 35 replies
- english man o war
- revell
Great additions Bill, 1 I've built obviously the other 2 are in my stash too. Which kit will you be starting next ?
- 35 replies
- english man o war
- revell
Well done Bill, a beautiful finish, she stands tall and proud, great work my friend. 🤺🤺🤺⚓⚓⚓ What's up next on your bench ?
- 35 replies
- english man o war
- revell
Next stage being the rigging, this is not looking good, as I only have these 2 b&w photos at the end of the instructions to go with, I guess this could be a bit make shift, but will try and make it authentic looking as best I can, especially on this size of kit, as I am not used to working on fine detail on this scale without proper instructions, but I have to persevere and see this through the on coming storm. Happy modelling everyone Rob. ⚓⚓🤺🤺
Oh, I understand that, but I would also like to point out, that I to, have the same drawing in a book I have called Galleons and Galleys, but this is a modern drawing and not from the time period, that's why I preferred to go with paintings from a similar time period, not to say they are right or wrong, but there must be something in it. I guess in the end we will never know truly whether this carrack and many others used spritsails for definite or whether drawings or artists impressions were added to or taken away during the course of history.
