Bill97
Everything posted by Bill97
  1. They are going to look great displayed together some day!
  2. Today I applied gold leaf to the freize and hatch enhancements on the starboard upper bulwark. I then dry fitted it in place while I work on the port side upper bulwark.
  3. Thanks guys for your comments! Very much appreciated.
  4. Well unfortunately I have been struck with the Covid virus. I guess I picked it up on my trip out west even though I wore a mask on the planes. Fortunately I have not been real sick from it. About two rough days and then steady improvement since. As a result I am quarantined to the house for bit. What better time to work in the “ship yard”! I got the starboard UB painted and the enhancements I molded for the hatches glued on. I am going to gold leaf these enhancements along with all the other ornamentation on the UB. I put a coat of gold paint on all the items that will be gold leafed as well. That way if any little specs are small pieces of leaf chip off it won’t be noticeable with the gold paint underneath. As I may have mentioned before I intend to display my SR from the port side. This painting of the starboard UB will rarely be seen by anyone unless I move the display case the ship will eventually go in. My goal in how I position the ship in the case is to accentuate the stern when people first see it. The same idea I had for the Victory. With this being my plan, the painting and adding the enhancements on the starboard side allows me a little practice and fine tuning of my methods before I start the port UB which will be in full view for all to see any blemishes.
  5. Henry after getting your recommendation about the knee I decided to go back and move the eyebolts I already installed on the port side next to the knees and put them all uniformly in the knee on the side of the hatch. Now both sides match and all eyebolts are in the knees. Had to putty the previous holes. Will sand and touch up those spots. Turned them over and just looking at all the gold painting and gold leaf in my future! 😳 Will be a slow gradual labor of love. Henry you may notice the little purple blobs at the top of a couple of the pictures. That is the Easy Mold you recommended. I am casting the hatch enhancements 8 at a time.
  6. Installed the eyebolts to rig the visible cannons on the port side UB. I counted 14 cannons that will be visible. Installed 4 eyebolts for each. At the front I did not think the eyebolts would have been installed in the rail for strength reasons so I placed them in a straight horizontal line. Per Henry’s recommendation, where the eyebolt came in contact with the support knee I put the eyebolt straight into the knee. Will need to go back and touch up the shinny CA glue spots once thoroughly dry.
  7. Blackened a whole bunch of my brass eyebolts and getting ready to install them along the UBs at the hatches and openings where visible cannons will be. I immediately notice at the lower deck where there is the knee shaped supports for the walkway above, these supports are flush with one side of the hatch. I assume the eyebolts go into the bulkhead on the other side of the support? There is only one where this will be tricky.
  8. Have the upper bulwarks painted red on the inside and my blue on the outside. They are dry fitted in the picture. Now to begin the process of painting the lines and the gun hatches gold, and applying gold leaf to all the enhancements and ornamentation. I am having an inner debate on when to do all the gold leaf. Do I want to do it while I have the UBs off the ship and laying flat on my table? Same time I paint all the gold? Or do I want to paint the gold, install the UBs, and then do all the gold leaf? I know the gold leaf application would be easier with the UB’s off the ship. However I also know they will get an abundance of handling and clamping when attaching them to the ship. Handling and/or clamping that could damage the gold leaf. If I lay the ship on its side after the UBs are attached to do the gold leaf I will have to be concerned about all the cannons protruding that could break off and be lost forever inside the ship, and deal with the hull wanting to rock while I am trying to apply the leaf. It will take me a while to get all the gold painted so I have time for the internal debate.
  9. Back from California and in the shipyard again. Painted the inside of the upper bulwarks red and set them aside to thoroughly dry. I will then begin the task of preparing the front side to be painted blue. I have a bit of tedious work around the balusters with getting a sharp blue on the sides and front, and red on the back. In the meantime I have begun making a bazillion eyebolts for rigging the cannons that will show. I want to put the eyebolts into the side of the upper bulwarks before I eventually glue the bulwarks in place. Doing this now should make the task of drilling and gluing a bit easier. From what I can make out in the photos I see, an authentic rigging of the cannons requires 4 eyebolts in the upper bulwarks at each hatch or opening. Two on each side. I will be making many more that will be later attached to the cannons and n the deck behind the cannons to complete the cannon rigging.
  10. While I have been away from the “ship yard” I have been thinking about my future painting of the upper bulwarks. I know the color scheme I am going to use. I would really like to be able to airbrush the red I am going to use on the inside and the blue on the outside because I get a much better looking coverage than I do with a brush. I know if I want to airbrush I will need to do some tricky masking. I also have to guard against the blue going through and getting on the red inside and vice versa. I will be painting the rails, circular openings, and lines gold. I will also be applying gold leaf to the decorations. I know I will need to use a very tiny brush for some of the work. This is going to be fun working out the logistics of this painting.
  11. Thanks Marc. Appreciate your nudging me to finally get it right, or at least acceptable! They will ultimately be gilded with gold leaf once I cast a bunch of them.
  12. Ok I think I now have the upper enhancement I am going to use! The blue color on the UB is just Vallejo blue surface primer that will be under my blue paint later.
  13. First attempt is not terrible but does need refinement! Will continue to hone it in or decide to just skip this added enhancement! 😀
  14. Kevin the epoxy is not brittle at all. The product I have produces a casting the consistency a gummy, maybe a little firmer. It picks up all the details of the mold and very easy to trim away excess. However I would not think it would be conducive to sanding or a file.
  15. Before heading out of town I finished my first satisfactory hatch enhancement. Glued it to the end of a piece of wood and pressed a series of molds. I will cast a few of these and see how my effort pays off.
  16. Same here Marc! Since I was a teenager and things like Nintendo were available to play I have been familiar with electronic games. In later years I was aware of people playing video games with other online gamers. But to now know it is a recognized sport and you can earn an income doing it is, as you said, mind blowing!
  17. Not much to report in recent days. Have been pretty busy with grandson’s sporting events that keep me out of the “ship yard” 😊! But I have to admit I absolutely love watching them play. Basketball, indoor soccer, and archery shoots are the current involvements. There is also a sport that is fairly new to me but I am assuming has been around a while. Have you heard of Esports? If not, it is a recognized sport where high schools and universities have teams that compete with others in video games! State, regional, and national championships are crowned. The field of play is the internet instead of the court or field. It is amazing the skill and intensity involved in these competitions. As grandparents we are able to log into the internet sight to watch the matches. Two of my grandsons are on the team for their high school and their team was crowned the state champion a few weeks ago! The oldest of the two, a senior, has signed to play for a university next year with a scholarship, just as a football player might. Never heard of such a thing until they got involved. In the ship yard when time permits I continue to work on my prototype for the hatch enhancements, and other upper bulwark details. Nothing really much to photograph. I have to leave the ship yard behind for a bit. I am flying out to California the first of the week for several days. As always when I am away from my SR I will enjoy what I am doing but will be anxious to get back to it.
  18. Thanks Henry. I will refer to the rigging instructions to see if I can determine how much space I need.
  19. Ok so kept the evergreen there and just sanded it thinner to make a little extra room for lines? I had the full .030 width there and just now cut it out. I think I will now return a piece of .020 in place and blend it smoothly to .030 next to it. Or should I replace it with a piece of .010? Hummm, will have to see which offers the best option for rigging the lines. Thanks again Marc. Biill
  20. Marc speaking of the cap rail, what did you do in the section I am pointing to in the picture? I had evergreen there. But when I put the rigging apparatus (sure it has a nautical name) in it pressed up against the added evergreen. Had to remove that short piece to get a good fit.
  21. Jeff would mind adding my Heller Soleli Royal to the index? Would greatly appreciate it.
  22. That will be an impressive read Marc. Currently I find myself thinking “what was it I remember Marc did there?”, and then scrolling through your 70 pages until I find it. I have started making notes of particular pages I want to be able to refer back to for specific tasks.
