Swallowtail
Posts posted by Swallowtail
Two coats of varnish looking great.
Fore mast tapered and shaped. It's sitting a couple of degrees too much rake when just slotted in, so I'll straighten it slightly.
The instructions seem to suggest doing some of the standing rigging before inserting and gluing the mast, which seems odd. My instinct tells me to fit and glue the mast at the right rake angle and then do standing rigging to the fitted mast... but it's my first model so my instinct could well be wrong! What's the best way?
- Oldsalt1950, ccoyle and Paul Le Wol
3
- Paul Le Wol, ct mike, clearway and 2 others
5
2 hours ago, E Z Breeze said:
She's a beaut!
I guess you know this already but multiple well thinned coats of varnish will avoid the toffee apple/candy apple look. Sorry, I just had to remind you about that because that wood looks so good!
Yes.... And no need to apologise
This is my first ship build!
That's next, I've just fitted the rudder, and I'm working on the bowsprit.
- Paul Le Wol and ccoyle
2
- Jeddahbill and GrandpaPhil
2
- Matt D, sziggy8, Jeddahbill and 1 other
4
- Jeddahbill and Matt D
2
Steady progress... Bulwarks on, one now lined. I've planed it down to be 3 x planks tall, and it flows nicely. Interesting to see that the stern transom is narrower than the kit by about 8mm once the bulwarks are nicely fitted and flowing. I've gone with it, and she'll have a narrower transom.
I've also packed the sternpost so it sits out a little, will have to see if that bites me later!
The bulwarks needed trimming on the bottom edge to fit to the top plank, and are also about 10mm too long at the front, so will need shortening.
There seems to be a bit about this kit which is make it up as you go along...
- Jeddahbill, Scotty W, Keithbrad80 and 1 other
4
- Jeddahbill and WalrusGuy
2
Well aren't holidays great... :)
Did the other side this last week, much easier than the first - lessons learnt. Having ends to match and measurements to compare certainly sped things up!
Planking is now done, and first sanding roughly complete. There are a couple of low spots to fill and then resand, then on to the next steps!
- WalrusGuy and Jeddahbill
2
- WalrusGuy, Cabbie and Jeddahbill
3
- Cabbie, WalrusGuy and Jeddahbill
3
I posted this in the Member's intro section, but on suggestion there will start this log...
I bought the Swift kit a few years ago as a first ever timber ship kit, but put it down after constructing the frame and half-planking the deck, when I realised I wasn't happy with the planking I had started. This last week I picked it up again and decided that no-one else would ever realise that some of the planks didn't quite look perfect! So progress since then has been to finish the deck planking, fit the deck to the frame, and start planking...
I ended up clamping the deck down pretty hard to get the curve to the bulkheads, but it looks really good so I'm pretty happy with it.
One thing I have noted is that I was not happy with the hull curve generated by bulkhead 6 (it really pinched in and didn't flow well at all) so I have packed it slightly - it can be seen in the last photo as the bulkhead with an extra pin in it near the keel.
I've been reading a lot on planking techniques - and reading through @stripehunter's build log - some excellent advice all round.
I daresay this will go through stages of modelling energy, but I'll get there eventually
2
More progress planking this evening, with even a stealer and a drop plank making an appearance... But I'll start a build log tomorrow or Friday and post some more pics.
Thanks everyone for the welcome.
- Ryland Craze and mtaylor
2
I bought Swift a few years ago as a first ever timber ship kit, but put it down after constructing the frame and half-planking the deck, when I realised I wasn't happy with the planking I had started. This last week I picked it up again and decided that no-one else would ever realise that some of the planks didn't quite look perfect! So progress since then has been to finish the deck planking, fit the deck to the frame, and start planking...
I've been reading a lot on planking techniques - and reading through @stripehunter's build log - some excellent advice all round. So the planking is now going to pause while I review what to do next...
I'm generally more of a railway modeller than a ship modeller - but I've always had a soft spot for ships, so we will see how this turns out. With my modelling I tend to do spurts of activity then stop for a few months, so I daresay this will go through stages as well, but I'll get there eventually.
- GrandpaPhil, ccoyle, Ryland Craze and 1 other
4
Swift 1805 by Swallowtail - Artesania Latina - 1:50 - first build
Thank you. Good tips on the jig and drilling the holes first - both will help!
