Everything posted by Danstream
F-86F-30 Sabre by Egilman - Kinetic - 1/32nd scale
Danstream replied to Egilman's topic in Non-ship/categorised builds
Although clearly we have never met, your post stroke me. I hope everything will go well. Give credit to what the doctor said and try to keep up your spirit. Anytime you want playing with our toys, we will be here to have a good talk and to listen to you. I want to see your handsome silver Sabre finished! Take care, Dan -
AVRO Lancaster by Papa - FINISHED - Airfix - 1/72
Danstream replied to Papa's topic in Non-ship/categorised builds
Nice and clean build. About the decals, the shining effect of the decal carrier is called 'silvering' in the plastic model community. It is caused by air trapped between the film and the roughness of the matt paint. I am afraid it will not go away with a matt coating. At this stage what you can do if that really disturbs you is: - paint over the obvious film with the colors of the camo (least invasive). Or: - With patience, if you have not sealed the decals with a varnish, remove the decal with repeated application of decal liquids (or warm water); once removed, you can: - cut and remove the biggest carrier film portions and reapply the remaining parts with decal liquids, or - brush a product like 'Future' over the paint of the decal areas and reapply the decals with liquids; at this point surfaces will show a variation of finishes which will need to be made uniform with a layer of matt coating. Perhaps all this is too cumbersome and not worth the effort, but this is up to you to decide. The model has anyway its own character of an 'old school' model and I would leave it as is. Best regards, Dan -
Good fix of the dihedral angle. About that large gap, that needs to be filled with a styrene strip, any other filler will crack with time. Good luck, Dan -
Good steady progress, looking forward for more. By the way, speaking of a good filler that can be sanded and even scribed, have you considered using CA glue mixed with talc powder? Best regards, Dan -
Russian T-62A Tank by CDW - Tamiya - 1/35 Scale FINISHED
Danstream replied to CDW's topic in Non-ship/categorised builds
Finely crafted and finished model! I am not an expert of these vehicles, but I can recognize that. By the way, I read today that this old type was just deployed by Russia in Dnepr. Congrats for the nice result, Dan -
Good to see you back in action. Good move on replacing the gun ports although not trivial surgery. I am wondering whether it something could be planned at this stage for their finish. I mean, they have typically a shiny metal finish which stands out from the rest of the aluminium finish, hence could it be convenient to cover them with a kind of kitchen or tape foil now, before inserting them in their squared hole? Just a speculation, I never did it before. Best regards, Dan -
Hi, a small update that concludes the application of the camouflage of the main airframe. I masked again the metallic panels in view of the final coating of matt clear varnish. In fact, I want to retain the shiny finish of the metallic panels: After spraying a thinned layer of Tamiya matt (doped with some drops of gloss), after long time, I can remove all the masking tapes also from the canopy: I am pleased with the variety of finishes of the metallic parts and painted surfaces: Now I will concentrate of the huge drop tanks and on the missiles. Best regards, Dan
Hi, some progress on my F-15. Similarly to the upper side, the panel lines of the underside of the fuselage were treated with Payne's Grey oil color, while the wings were left natural with the exception of the control surface gaps. I might come back later to the panel lines of the leading edge. Then the jet nozzles were glued on and some stains were added by putting some black oil color dots on panel junctions and smearing them with a flat brush. Also the nozzles were drybrushed with black oil color. The underside engine area of F-15's might get really dirty by gases leaking from the junctions, but I prefer to keep the weathering quite limited. The engine area seen from the above will remain cleaner: A rear quarter view of the jet nozzles area: The jet exhausts of the kit are quite simplified, but I preferred not to replace them and get the best I could by playing with paints and oils. On the upper surface, I added some streaks of color from the hinge lines of the surfaces as suggested by some pictures. Finally, I sprayed a transparent layer of Tamiya Smoke and clear yellow on the underside of the engine area to mimic the discoloration of this area as seen in pictures: That's all for now, I hope you like my weathering effects. Best regards, Dan
Hi, After having applied (almost) all the decals onto the fuselage, I sprayed the last coat of gloss to seal them. Then, the diluted oil color was liberally brushed on the panel lines of the upper side. This operation is always a bit frightening to me: After 20 minutes, I removed the wash with a cloth damped with white spirit: Next, the underside fuselage will be similarly treated. Meanwhile, I restarted working on the exhaust jet pipes because they will be glued on soon. With a fine brush, I picked few details with aluminium metallic paint and Tamiya panel liner, then I sprayed a mist of flat brown to mute down the contrast of the metallic parts: Best regards, Dan
Thank you Alan, I am happy that you like the work done on the LG. As you might have noticed, there were quite a number of steps involved (i.e. a number of different coatings), but, eventually, it is easy to obtain a satisfactorily result. Actually, if the mould is good, most of the job is done by the wash 🙂. Presently, I am repeating all the coatings with the wheels. I have just finished decaling the fuselage, omitting some of the many stencils. King regards and thanks for all the 'like's! Dan
Hi, while going on with decaling, I tackled the modeling of the landing gears. The kit provides a fair, quite accurate representation of the main structural parts. The legs were provided split in half and you have to insert a metallic rod in the vertical element before closing the halves. One end of the metallic rod inside the forward leg protrudes outside and it is supposed to get clamped into the wheel. This is the first time I see such a feature. The first step was to add few lead wires to busy up a bit the parts: Then, I sprayed a light coat of primer followed by a satin white and I glued on the landing lights. To render the shiny struts of the shock absorbers and the oleo, I used a strip of thin self adhesive aluminium foil. The placards are made with small pieces of decal. After that, I painted black some portions of the wires and sealed everything with a coat of gloss clear varnish. At this point, details can be picked up by applying a black wash (Tamiya panel liner): That's all for now, Thanks for following, Dan
Hi, I had little time for the hobby lately and I am posting just few images to show that the build is going on. From the images above, I noted a blemish in the filler located next to the cannon opening which I could not ignore and hence had to be corrected. Then, after a light wet sanding of everything, I sprayed a second layer of gloss clear to prepare the surfaces for the decals: I sourced a decal sheet that contained the service stencils and one for the insignias of the 32nd Squadron which was based in the Netherlands since the early 50's at the Soesterberg Air Base. The squadron was under Royal Netherlands Air Force control, therefore it was the only American Squadron that was under the command of a foreign nation. The role of the 32nd TFS was to guard the West-European air space which stretched right up to the Iron Curtain. Below, I just started to apply the decals: This is an early scheme which will display the high-visibility stencils as I found in some pictures on the web (note: I find strange that the diagram around the fueling port is so larger than the outline of the port, but I do not have other options). That's all for the moment, best regards, Dan
Hi all, some little work done over the weekend, painted the control surfaces and posed together with the main body to see the effect. Then a first light coat of Tamiya gloss followed by a light wet sanding. Before a second coat, I masked some details to get a metallic paint on the cannon opening and on the largest dorsal grilles: I sprayed on these details a coat if Vallejo metallic 'steel' obtaining some points of interest on the large upper surface. The simplified cannon opening gained a bit of detail: Meanwhile, waiting for the gloss coat, I started to work on the landing gears. That's all for now, kind regards, Dan
OK, beside 'talent' which is a big word and I do not consider applicable to me, the other two ingredients are correct. I started with brush painting (my other hobby is actually... 'brush painting') and then I moved to airbrush. However, I soon realized that the time spent in airbrushing models was too short, too insufficient to learn reasonably the basic techniques and, in addition, it needed a long preparation in building the model before I could get into action with it. Hence, I started to spray paint on scrap cardboard and the like trying several effects that I wanted to reproduce. This way, I could get some of the 'time' and the 'experience' that were needed. Excuse me for this unsolicited long digression and thanks to all of you that offered benevolent comments and 'likes' 🙂, cheers, Dan
