Posts posted by achuck49
Good day,
I am starting to work on a model of a schooner. On one side of the keel is a printed set of lines indicating rabbit lines, placement of other parts and information of this sort. How can I accurately transfer this information to the reverse side of the keel which is blank?
TIA
A couple of more questions.
Example only
I have fastened a block to a 'rope' that is 8" long. I put the block in the alligator clamp, but how do l handle the other 8"???
If I use a second clamp then the excessive rope winds and it gets twisted into a mess.
So confused
Example only
So confused
I am bidding on this model now and am reviewing your log with interest.
Why didn't you plank the deck before installing the bullworks?
- popeye the sailor, Elijah and captgino
3
Thanks!!!
Doing it now
- Canute and thibaultron
2
Good Afternoon,
S
In a week or two I plan on building a plastic paddle wheel model. I believe that this is the correct order for painting
wash all of the parts in something like Dawn dish soap
spray primer over everything
remove pieces as necessary, assemble, and then paint.
Have I got it right???
Should I paint the parts while still attached to the (forgot the word) large collection of parts, then assemble?
Is enamel paint better/same/worse then acrylic?
Should I get a bunch of rattle cans containing the appropriate color paint?
Chuck
- reklein and thibaultron
2
Glad to see you posting again, will start on mine in a few months.
According to a Wikipedia article...
Niagara was constructed from 1812 to 1813 to protect the vulnerable American coastline on Lake Erie from the British and played a pivotal role in the battle for the lake. Along with most warships that served in the war, Niagara was sunk for preservation on Presque Isle in 1820. Raised in 1913, it was rebuilt for the centennial of the Battle of Lake Erie.
I would never have thought that a ship this size could have been built in one year given the conditions of the time.
Chuck A
Thanks for the information.
I will abandon latex...except for those special evenings.
Chuck A
- Captain Slog, mtaylor and Canute
3
Confusion continues for this novice.
In another section in this category, I asked about using paint samples from Lowes or Home Depot. I received several answers describing that paint pigment's will be to large and cover detail. I specifically mentioned latex, which is also mentioned above. Does thinning reduce pigment size?
Chuck A
Off topic but congratulations on hanging in long to retire. Thanks for your service.
- SWOHammer, mtaylor and thibaultron
3
I've posted odd questions before, so I feel comfortable posting another one.
Hardware stores can replicate nearly any color paint and sell small sample containers. So why not use latex paint?
Maybe everyone is and I am the last to figure it out.
To all
Thanks for the info.
I absolutely have the wrong chisels, payday is next week. I will get what is required to keep the tools sharp.
I will book mark this section and use the photos to help with rigging.
As far as securing goes, I spent a large part of the day trying to find anything to attach to the bottom of the hull so that I could use a vise. We are moving to Oklahoma City which means that stuff is getting packed or my Commander in Chief tossed stuff out. I did consider sawing a small piece broom handle, but feared that if caught the boss would make me use it.
Thanks the advice will be used.
ChuckA
- thibaultron, Canute, coxswain and 3 others
6
I hope you can see from the photos there are areas that a Dremel cannot handle. The bow needs to be thined, how?
This is between decks. I believe the distance between decks is 2mm.
There is an area at the end of hull that requires the same type of work. (Photo will not upload)
I hope that I am clear inow my request for knowledge.
Chuck A
- thibaultron, mtaylor, coxswain and 1 other
4
Will do, should have thought of that earlier.
- thibaultron and Canute
2
Preprinted lines
in Building, Framing, Planking and plating a ships hull and deck
Sincere thanks for the incredible responses. I should have waited but had an idea and proceeded.
I have some clear 'Gorilla' tape which I lightly applied to the keel. This type of tape is thicker than usual. I used a sharp blade and traced a line, moved the cut tape to some heavy paper and cut again. I had a good copy, placed the paper against the keel and with a sharp pencil copied the line. Repeat process and mission accomplished.
I do want to thank everyone
Chuck
