Lieste
Everything posted by Lieste
  1. While gun of this type are never sleeved, it should be noted that the 1830s 8" shell gun of 9ft 65cwt was relined with a wrought iron (MkI, MkII) or steel (MkIII) inner of 6.3" which was proofed to swage the liner, then engraved with grooves for the 64pdr bolts and ogive shell. The bore diameter was chosen to match that of the 32pdr light guns of 25cwt and 32cwt (and the end-of-era, rebored 17cwt carronade, which had started as a 6.25" bore), permitting access to the huge supply of shot, common shell and spherical case in naval stores for the obsolescent 32pdr guns. There are also other examples of ex-SBML also converted to RML or RBL some of which processes use the cast iron or bronze of the original bore, and others line the bore (and possibly also hoop the reinforce) To be clear this particular article is not one of those recorded types but they do exist.
  2. Boudriot, and some of the period sources (from memory, perhaps "Installations des vaisseau" https://gallica.bnf.fr/ark:/12148/bpt6k8596353/f1.item.r=Installation des vaisseaux, par Édouard Burgues, but I have read around a dozen recently so could be mistaken - a text worth snaffling in any case from Gallica BNF), indicate that it was common to open a pair of ports somewhere forward and aft on the windward side to produce a draft flow. While it is possible to have all guns run out, the lower deck is fairly low to the water, and would strongly limit the maximum press of sail which could be carried - those in the bow and stern are somewhat higher, and the bow wave is followed by a trough, the position of which would be drier than at other points along the hull. Only have a few ports opens also limits the amount of water shipped, if they are immersed, and the lower part of the port can be closed by a 'half-port' slid into a channel increasing the freeboard by some 18+" while still keeping some ventilation. (Middle (where present) and enclosed upper deck and quartedeck ports can be open and the guns run out, these can also be half-ports sometimes with the gun passing through a hole in the port, for those which are high enough to not be a flooding risk, even in heavy seas... those on the weatherdeck and exposed usually either have no port covers at all). When facing storm weather which you are not expecting action, the safest is to run the guns alongside the hull side/fore-aft, where the gun is enclosed, or it can be left run out with tompions in on those on a weatherdeck or through a pierced portlid. In fair weather or where an action might be imminent, those guns which can be worked should be secured at their ports, with either the piece run out (especially through a half port), or braced against the upper cill or spirketing. Leeside lower deck guns may have insufficient freeboard in a sea, and even a weather side gun may be difficult to use (with recoil 'downhill' and with waves being steepened and heightened on the weather side of the ship. Lighter gun calibres, with a frequently proportionately heavier gun mass have a lighter recoil which presents less stress to the hull and are mounted higher where the ship should be less wet... this may not be as convenient for larger calibre light guns which have recoil fairly consistent with the full-gun (32pdr carronade ~ 24pdr gun have similar recoil, and medium guns tend to follow that trend too, being close to either their own full gun or one a calibre lighter at most.) In prospect of *very* severe weather the guns, or at least a proportion of them can be struck down into the hold, and if room their carriages as well, as well as striking to the deck such of the top-hamper not required for storm canvas.
  3. Also a safer option similar to the 'braced against the upper cill'. It uses a wooden brace against the frame and oak spirketing below the lower cill and the front of the carriage cheeks, as well as the outhaul and inhaul tackle arranged to give a few inches gap between the suspended muzzle and the upper cill. It is faster to return to action as there is less tying of the various tackles and breeching together.
  4. There was a transport board requirement for vessels under hire to carry 'at least 6 guns of at least 6lbs' or 'of a smaller calibre according to the rating of the vessel' (sic). Or after the 1780s these guns could be exchanged for carronades of 'at least 12lbs'. These minimums were associated with an allowance of £5 per gun to carry additional ordnance at the master's option. Similar rules for ships operating on foreign trade (along with imposed convoying) were made by Lloyds of London and other notable maritime insurers for the same reasons that the transport board preferred *some* armament on their hired vessels. Those serious about their trade might seek out a 'real' ordnance able to fight off an opponent of similar scale of arms, in retreat at least when the chasing vessel is also only able to engage with it's own chase ordnance - or to take, sink or burn in a close engagement with a small vessel armed with guns if fitted with carronades. Those merely complying with the regulation might opt for the cheapest 'cutt' which complies with the letter of the requirement. Companies such as Carron offered guns to the ordnance board according to the establishment of guns in place at the time (when not banned for proof failures), but they also offered 'medium guns' and guns similar to the ordnance regulation guns and carronades to those who could pay (including exporting a gun-foundry to Russia, controversially. A half pound swivel would not qualify as a gun for the transport board requirement, but would be useful as a counter-boarding weapon before the advent of the *much* more effective carronades, and also served as armament for boats, with a small piece in the bows and 2-4 swivels mounted to the gunwales. Found in a river, a boat swivel seems more plausible than an insurance gun or transport board qualifier. YMMV Private companies, such as the HBC also manufactured their own ordnance to suit their needs, and it is possible it is from such a source, rather than a private sale from a supplier to the ordnance board. An absence of government proof marks is expected from private company production and ordnance not supplied to the government for proofing, but offered for direct sale to merchant or private hire shipping.
  5. The station bill given in "installation des vaisseau" has fewer than 293 men even for the 'tacking under plain sail'. From a watch of 299, when in two watches, and below 201 men from 202 men when in three watches (with no idlers). All hands piped to stations would be required for sails and pumping, sails and anchor, or for action (when manoeuvring was 94 when fighting one board or 60 on both boards (with musketry reduced only to those on the tops)). The 'ordinary' watch system was two watches with idlers, but the use of a three watch system (which with more down time between watches, and smaller watch sizes had no idlers on the books - all 'seamen' and soldiers were assigned roles ~ though some of the simpler operations still didn't require all numbers to be active for that evolution. (Also the watches were Larboard and Starboard, (or Babord and Tribord for the French) - Port is a later modification of terms. "All hands" for routine sail evolutions is a nearly purely merchant navy procedure (plus to a lesser degree troop transport warships armed en-flute), where there were by Transport board requirements minimums for "hired vessels" of 6 men per 100 tuns (earlier 7 men per 100 tuns), giving crews around a third to a quarter of those of a warship of similar size - in order to provide the space needed for troops or cargo, and to reduce costs and cargo space used up by crew provisions.
  6. The tripping line is to trip the anchor, not the seaman. With the fluke biting in the bottom, and the cable running along the bottom, the initial pull of the cable when weighing anchor will tend to dig the flukes deeper, and if the bottom is shallow there may not be enough angle put on the hank to pull the flukes clear over a wide enough 'spread' to be able to hold that station. If instead of trying to solely pull the anchor from the hank, you trip the crown, the flukes come clear of the bottom, when intended and the anchor can be weighed more easily.
  7. Also long term endurance at the lower speed as the rowing can be shared out over time at a higher effort per group over a short time, followed by rest. This could be done by bank, by division or by files in an interleaved watch system. Those doing experimental archaeology with Danish/Norse warships have used various forms of watch system to provide long term rowing capability as well.
  8. The halyard is only bringing the yard down to the reefed height of the sail/in proximity to the tops/crosstrees, not all the way to the deck in the document referred to above, and this is the condition shown in various paintings and with the Constitution or modern Hermione's topgallants over set topsails in hundreds of videos and photographs, as well as a number of the early photographs of active ships. While the yard could be struck down, along with topmasts and royals (and this was sometimes done to secure the vessel before a storm), the procedure for reefing and making or taking in sail given in the manual doesn't describe unbending the sling, only lowering the yard on it's spar. The top is where the sheets and clews are handled when the sail is reefed, to neaten the canvas and to fold it into it's condition for reefing or furling. Lowering the yard also reduces the motion of the yard in a sea even if the vessel continues to pitch and roll at an undiminished amplitude - just a shorter arm for the motion. Keeping the furled sail at the tops/crosstrees, rather than hauled up makes getting men onto the yard from the top an easier and faster task, so the gaskets can be loosened more rapidly and the sail set and hauled more rapidly than if it were hauled to just below the cross trees above. Striking down the spars and yards is quite obviously a slower task again, with far more adjustment to the rig to get the relevant sail re-bent.
  9. Relevant section on reefing from the online textbook of seamanship: https://www.hnsa.org/manuals-documents/age-of-sail/textbook-of-seamanship/reefing/ also: https://www.hnsa.org/manuals-documents/age-of-sail/textbook-of-seamanship/making-and-taking-in-sail/
  10. One detail that seems is often not correctly implemented is the yards position for topsail and topgallants, if the sails are furled or removed. These would usually be lowered when the sails are not set, and hoisted as the sails are set. To my eye, the rig looks wrong if the yards are hoisted yet bare.
  11. The driver is rarely set, and tends to be most useful in wearing or tacking, where it can outhaul to push the tail end around. From what I have gathered, the foresails and mainsail would more or less balance the rig on most broad reach and beam seas, the mizzen topsail and topgallant might only be reefed, or left unset to give a fairly neutral helm. On other points of sail (or in different conditions of trim) more of the mizzen stack might be needed to have a neutral or slight tendency to fall off the wind. To bring the head smartly around setting more of the mizzen sails, and hauling the driver to windward will help the rudder drive the stern to the leeward and the head into the wind, with the pivot in forward motion being something like the 1/3rd of the WL length from the head - if the ship loses head-way during the tack, the helm is sent over, and the pivot shifts to closer to 1/3rd the way from the stern, which slightly reduces the effort the rear sails can impart to aid turning - if not already set the driver will be needed now if the vessel is not to miss stays. For maximum lift the sail should take an angle of attack of 'around' 20 degrees, if you can set it to closer to 90 degrees it will provide a greater force, but as a 'drag' force (which is strictly limited to zero when running at the wind speed) - the driver can be used in either mode to push or pull the stern as needed and as the angles of the wind and hull allow. I would start seeing how the sailing performance is without it, and the ability to hold a course with trimming the other yards, and reefing/clewing the other sails. Then try various strategies to drive the stern or pull the stern the way it needs to go for each planned point of sail it struggles to hold or attain. You also need to consider the sheeting strategy for the headsails to ease tacking and wearing, especially with lower speeds and lighter airs.
  12. For double banked barges and pinnaces the instructions for embarkation given in "Aide Memoire to the Military Sciences" are:
  13. The Saga Obesberg is a far better sailor than the built 'as displayed' Dronningen which drove under when tested under sail because of her 'too flat' keel sheer and the 'too narrow' thwarts in the damaged bow area of the museum article. With the original form approximated as closely as is possible using rigorous archaeology and practical model and modern and 'model' 3d reconstructions and simulation the Saga Oseberg is a much more successful sailer, capable of tacking with apparent ease, as well as riding on her own bow wave and semi-planing under sail at speed.
  14. A mm is an inch in scale... I would note that there is a considerable asymmetry in her lines, in excess of several inches for knees, and having a visibly different line for the wales port and starboard, as well as for the location of the knees relative to station lines. Get it fair and 'close' trying to be 'perfect' is unlikely to be 'more authentic' to the original building practice.
  15. Red Ochre for the lower deck spirketing and quickwork? I'd understood 'tweendecks as being whitewashed to enhance the light reflected from ports or the fighting lanterns, to make operating under conditions of smoke and minimal direct sunlight as easy as possible. Reds and Greens, or Yellow Ochre on the weatherdeck bulwarks seem to be common however. Is there a source for the red lower deck spirketing and quickwork?
  16. A document which includes a description of a British engineer proposal for baise stripes suspended from iron rods to conceal the embrasures, and a Russian use of rope in the same way (along with a mantlet of rope wound around the barrel (as a disk, tightly constructed) to prevent the heavy losses from canister and musketry. https://books.google.co.uk/books?id=KDZWAAAAYAAJ&pg=PA113&lpg=PA113&dq=rope+screen+embrasure&source=bl&ots=f6wpJySIsu&sig=ACfU3U3aYOyBuV2ZHjg3Fq6C5YDE-Lv_tg&hl=en&sa=X&ved=2ahUKEwjwieWC34P6AhWDg1wKHaIyAsgQ6AF6BAgWEAM#v=onepage&q=rope screen embrasure&f=false So the screen is as above suggested most probably for concealment, but a mantlet is also likely on the gun itself to give protection to the gunners.
  17. Maybe a counter to splinters of rock on near misses coming through the embrasure? Small, light rock shards are much heavier and sharper when shattered from a rock face than equally small splinters of wood - plenty to cause injury to crews - interfering with them with a screen of lines might significantly reduce the number and severity of injuries to a noticeable degree?
  18. The chandler is fixed into the top of the mounting timber - while it isn't proud 18" - it has some height of it's own.
  19. There are some gaillard perrier mounted on the Hermione Fregate de 12. I'm sure there are photographs somewhere in the huge number taken that include a crew member near one of these pieces.
  20. My mistake, it was the stern casemate ports for another 32pdr and the 30pdr parrot rifle.
  21. A bit larger than Peaquod (~330 tuns, vs 240 tuns), the Charles W Morgan has a 1/110 scale Revell plastic kit? Any use? There are also some other wooden kits of the CWM if you need a wooden kit to cut your teeth on. There are a few vintage solid hull models, as well as a more recent (and larger) plank on bulkhead offerings. Worth looking at ebay listings for a 'Scientific' model to see if it is what you are after IMO. (Not my listing, just poking around for what whaleship kits are available (relatively few, surprisingly).
  22. The 81lb ogive shot for the 42pdr rifles (84pdr James Rifle) were also shown in that same post of yours, with the cage around the base of the shot (originally covered by the lead skirt in an embiggened version of a minie ball.
  23. The museum model also has the front casement guns with the lower port pierced, rather than half and half (from your images). Edit: (I mistook the stern for the bow, the pierced lower ports are in fact the stern ports)
  24. The 30pdr is a rifle, firing ogive shot and shell, not round shot. Without looking up the specifics, I'd estimate it at having a bore diameter somewhere close to 12pdr/18pdr round shot (based on the 64pdr rifle having a 32pdr bore equivalent), so 4.5-5". I know that the correct diameter is listed in period articles, but don't have the US civil war data copied out into my own library of data. Quick checking: I underestimated the shell length - actually a 4.2" (9pdr bore equivalent) with a 29pdr ogive shell. The '42's are actually 84pdr "James Rifles" converted from Ml1841 42pdr smoothbores by cutting a set of shallow spiral grooves. You show the shot with the 'frame' around the rear portion, which would have had a lead sheet covering it, to be expanded into the rifling. This retains the ~7" bore of the 42pdr it was converted from. The shot was almost double the weight of the original round shot from the 42pdr at 81lbs, while the shell was ~64lbs. The 8" guns were smoothbore, and the examples you show seem to be mostly if not all shell - the fuse hole (and in a few cases a fuse body) can be seen between the two 'divots' used to handle the shell using a lifting tong. The shell is likely to be around 50-51lbs. The 32pdr is an intermediate weight light ordnance of relatively weak performance used to fill out the open port and to share out the more effective ordnance around the flotilla.
  25. Making a breach in a masonry wall, especially one covered by a glacis/ravelins etc is distinct from hulling a ship - one requires concentrated fire, ideally 'stitched' in horizontal and vertical bands to 'cut out' sections of masonry - the earlier technique hadn't yet developed the reduction of the wall 'intact' and instead pulverised much of the surface. Hulling a vessel merely requires a single hit with sufficient velocity to pass 3/4 of the way through the side (with the shock blowing out the rear face and relieving the resistance ahead of the shot (comparison of the shot passing through a thinner side compared to into a semi-infinite bulk of well assembled timbers - as discussed by Lafay/Helie, and further expanded on with the testing from Hocker et al of the Vasa light 24pdr ordnance and a section of Vasa's structure). Any single hit could potentially obtain the full effect of a hit - if it hits a large framing timber with sufficient force to break it it will throw large splinters - if it passes a thinner part of the side and into a carriage it can disable a gun. Hits between wind and water (common for fire in ricochet) is likely to lead to leaks and flooding (either continually, or periodically as the shot hole is immersed by wave action and motion in pitch and roll). While both a ship and a wall may be able to tolerate hundreds of hits, the difference in how they tolerate them is important - the wall is not reduced at all without considerable cumulative damage within a small section, and needs exponentially more ammunition to create a larger breach from a longer distance, especially if rubble collapses in front of the un-breached wall masking the footing from further fire. The presence of engineering works may require the advance of guns to the crest of the glacis in order to *see* the wall footing to engage it... and this is likely be the original cause of the close advance of the battery of breach, and the presence of said engineering works. Any single hit of the naval gun can cause a critical injury to a structural element, a piece of ordnance, a component of the rigging... the ship is a large structure with much redundancy in armament, structural elements and rigging stability and performance - so the small individual injuries to it while each 'significant' may need to be added to other individual 'significant' injury to cause a vessel to become crippled, to strike, burn or sink.
