OllieS
NRG Member-
Everything posted by OllieS
One thing to consider is how much time you want to spend doing this. Even a simpler model is hundreds of hours, a desirable model like the Victory or the Cutty Sark would be well over 1000. Occre is a good place to start (I am now on my third one). For the most help in making an excellent model you could consider one of the Vanguard fishing boats.
I couldn't find a difference either, some strips have a sort of barred horizontal pattern but it is very variable: it's a less or more thing rather than yes or no. I ended up using the least barred for the deck which was just stained and the others for everything else where it would be less obvious. By the way the OcCre Beagle has a lot of details and a lot of scope for (easy) improvements. It is an excellent choice!
I have used a black fine liner pen .1mm You just lightly dab to make the smallest of marks. And it is quick and easy, 'dab dab dab dab' where two planks meet. To me this looks fine but I don't actually know how accurate an approximation it is. I also worry about the width of planks, the standard 5mm strip seems too wide to me and I have experimented with cutting them in half.
I think maybe you have misunderstood that this kit hobby is just approximate, really don't worry too much. Try to flatten the keel: a little weight overnight. Then build anyway. It is a small deviation that you can easily correct later particularly with two plankings. I had a much worse distortion in another OcCre kit which I noticed when I placed the deck. And I simply forgot, I put it on a things to sort out list. Really you wouldn't notice it in the finished model. The level of precision you think is required does exist and you may get there, but most don't and they live happily anyway
There is no thumbs down option on comments and questions on MSW. It's that kind of place. Don't disregard OcCre. They're my first three builds and an excellent starting point.
Easy way to reference a topic
OllieS replied to OllieS's topic in How to use the MSW forum - **NO MODELING CONTENT**
I found this very useful tip to reference a post in another topic: how to refer to a post There are instructions on how to link to any page or site. The useful extra, specific to msw is further down. -
I get around the problem by using shorter planks. Using Sappelli for the second planking on my OcCre revenge (I have not reached the modelling level of replacing everything in a kit yet ) I cut the strips into 7.5 cm lengths which is 1/8 of a strip which scales to 18 feet. Using contact glue you can then make a close enough fit to the next row of planks adjusting the cut ends slightly to fit. Also tapering where needed. In effect you can make Jaager's S shaped plank out of several short sections even though you don't have the width to cut the shape out of one plank. It looks like this
Yes like that would be fine; better would be using a quote in the same way as when you reply to something within a topic. Just like this reply. -
Wood to wood PVA is best; CA is convenient and not as strong. The good news is channels generally pull in the direction they are stuck in. ( Using the mechanical principle that rigging works ). Danish Oil is not something I would expect to be able to glue to at all, if I had to I would be epoxy and pins probably. As far as the steps are concerned I would PVA and eyeball it.- If you can: I just had to reposition some posts I carelessly placed with my close work glasses on.
I use a simple cheat for this which makes life easier: You don't use the pin like you would in real life, instead you thread the line through the hole in the pin board from the top. And again. Then fix it with the peg. This is then adjustable (and you will need to square everything up at the finish). When you are happy with everything you can then glue in the peg and trim the line. Finally fix a hank of line over the peg and set it in a realistic shape with glue and it looks fine. Nobody will see the difference. I have to tell you that the OcCre pin diagram and the Anatomy of the Ship diagram are rather different (and there are more lines in reality than in the kit) so really don't worry too much, it will still look great !
Well I don't know, a sailor or boy scout might . But there would have to be some simple solution to not having pin boards and belaying pins. The post or rail would certainly provide the robust fixing for a line under tension to work against in several distinct positions so it would be easy to choose the right line when you needed to. My interest is limited to making a model that I'm happy with, so I will make something up at the time having decided not to fit the provided pin boards. For example:
Thank you both Mark P and allanyed for your immediate and excellent responses. I have since found your more detailed posts on this subject. This became a problem when I considered the belaying pins I got with my OcCre Revenge kit. They scale to the adult human leg; so I was considering something in wire less than half that size, when I half remembered a comment which meant that they shouldn't be used at all. When I read your replies, a light bulb lit over my head and the fog lifted. I now think I understand the 'post and rail fences' (fore and aft) that dominated sailed ships up to the end of the sixteenth century: They could be an 'Array' of belaying points that one could easily use in any situation. As far as the Revenge is concerned, I now have to rebuild the OcCre version because I will need more belaying points i.e.. posts under the mizzen deck taffrail. Hey ho, I will post it there. As and when. There is a separate issue which has not been addressed, as far as I know, which is the evolution of the belaying pin into its modern form which is that sometime (probably... 1600ish...) it becomes a removable object not just another belaying point. I do wonder whether some of the confusion is because a fixed pin in a convenient position (like the prow) looks very much like its evolved cousin a tapered pin with a handle which you could remove in an emergency, or for convenience. By 1750 it was lauded, but I lost that quote in the MSW sea.
Please can anyone tell me what the alternative to pln boards and belaying pins were in the 16th century? Like cleats under the rails or something? KIts avoid this problem by simply ignoring it as far as I can tell.
My stupid probably. But surely a deck you don't have to plank should be a luxurious choice not a requirement.
Correct Glue
OllieS replied to Blacklab's topic in Painting, finishing and weathering products and techniques
For staining I use Colron: Light Oak; Dark Oak; Medium Georgian Oak plus others. Staining works well but can only be done effectively before gluing anything. Acrylic varnish after. -
I apologize for annoying you with a casual remark, but it is often the case in any large scale project (a road; a bridge; a film etc) that is mystifyingly delayed that the reason is that the money isn't in place and everyone is waiting for a thumbs up from the decision maker. That's all. Not scurrilous just normal. Having now looked through this thread I can see how annoying this whole thing is for you. That said if you still have 12-18 months to run on this when you resume then everyone is jumping the gun by a couple of years and should leave you alone I think.
Presumably you have seen there is now a new release of the Santa Ana. How it compares to the original kit I couldn't say but it does have the strange lack of printed plans which is how things are at Artesania Latina these days. That's enough to put me off and I don't think I'm the only one.
