ECK
NRG Member-
Everything posted by ECK
- 73 replies
- Harpy
- Vanguard Models
- 73 replies
- Harpy
- Vanguard Models
As I am waiting for the rings I purchased to come in to complete the hatch covers, I, like Glenn UK decided to do a few other repetitive tasks that need to be done. I decided to assemble the carronades and long guns. First a lot of char removal as it is hard to cover when airbrushing. Although made easier by this nice tool Next came sticking them on my painting board and finally a good airbrushing, a bit out of focus. The final assembly with eyebolts and rings done. Total time to do all the guns about 6 hrs.
- 73 replies
- Harpy
- Vanguard Models
Spent a bit of time preparing the beams. First scraping the majority of the char with a scalpel then sanding As I painted the lower bulwarks, I decided also to paint the beams, similar to the Indy. Then inserting them into place
- 73 replies
- Harpy
- Vanguard Models
After seeing Glenn -UK's paint job of the lower deck, I decided to do the same. As I had already glued things, had do do a lot of taping before spraying. Unfortunately slight seepage requiring some scraping and sanding. Also recived the door handles and hinges from Syren and installed them.
- 73 replies
- Harpy
- Vanguard Models
Did the same thing ordering the handles and then had to order the hinges. Fortunately being in the US shipping takes a bit less time.
- 241 replies
- Vanguarrd Models
- Harpy
Next ,although not required, painted hatches and capstan base Next sail locker, really need to clap on veneers to prevent curls. Also orient veneers so plank lines align around Blue Ensin and Glenn UK took photos of brick pavers to print a base. As I do not have a color printer decided to do something different. Used scrap base then cut out wood bricks from some 1x3. Then glued them in staggered pattern. Filled with wood filler Then painted red and rubbed down Added white wash for mortar lines and rubbed again then light rubbing again with red paint Next painted stove and added metallic filings to age it and mounted on faux brick base Of course did not glue stove pipe chimney, that comes much later
- 73 replies
- Harpy
- Vanguard Models
You and Blue Ensign giving me many thing to think of. I already got the door fittings from Syren Ship Models
- 241 replies
- Vanguarrd Models
- Harpy
I have yet to use copper tape. I opted for full copper tiles when I did Indy. Tape is easy to cut, trim and attach, no glue getting on the tiles. You do have to cut hundreds of pieces so you need a cutter seen below to make it easier and standardized. Also if you want the appearance of nails you would have to scribe 4 sides of each tile with the tool below. Problem with the real thing is harder to trim (especially around the rudder) and use a lot of cyano. Occasionally falling off and needing to be reglued. To me, the real copper tiles just look better as seen on my Indy build below
- 73 replies
- Harpy
- Vanguard Models
I agree the wood is soft so I tape over bulwarks on second planking . Also when using clamps usually put some scrap wood so no direct pressure on the veneers.
- 332 replies
- Harpy
- Vanguard Models
Lost of assembly work today. First the cradle Next faring the ribs. In this kit for the first time a line is provided so as not to over do it Next assembling the hull structure. Everything interlocks so no glue until the end Then the reinforcing keels Locking inserts At this point gluing the etched decks to the underdeck. Lots of clamps to keep the thin etched deck from curling up. Followed by inserting them and locking them into place Bow fillers sanded to line and can see when together pretty symmetric Inserted into placed then capped Last for the day are the cabin assemblies on the stern made of multiple pieces Have to remember to make mirror images of each other Finally slotted into place A At this point brushing with wood glue permissible
- 73 replies
- Harpy
- Vanguard Models
Finally had the time to start unpacking the kit. A Few others have started so I can follow along as well. Ki, as all Vanguard ones, come in a pleasing box. All elements nicely packed Brass, copper and book up top. You can see I unwrapped the printed ship's boats and stove as well as opened the boxes containing rigging thread and various other pieces Lower layers of the box contain the laser etched parts Thought I would get the copper tape but was pleased when I saw actual copper plates
- 73 replies
- Harpy
- Vanguard Models
Finally completed HMS Granado, one of Chris's early works with Amati. I think the way I finshed it it looks a lot like a Vanguard model. Next project will be Chris Watton's latest addition the brig HM Harpy. Stay tuned.
- 37 replies
Mizzen rigging done. Main bowlines done. To finish main braces and sheets and tack as well as spritsail braces. Anchors the finishing touch.
- 37 replies
- 37 replies
- 37 replies
- 37 replies
- 37 replies
Yards all rigged and pinned. I will finish attaching them this week then start on the shrouds. I like to get the yards on at this pint as access is much easier. Will attach the bowsprit once all the shrouds done.
- 37 replies
- 37 replies
- 37 replies
- 37 replies
- 37 replies
