ECK
NRG Member-
Everything posted by ECK
HMS Victory by ECK - OcCre - 1/87
ECK replied to ECK's topic in - Kit build logs for subjects built from 1751 - 1800
Last bit of work today, finished the channels then added the limited decking to the lowest gundeck. You can see how the 32 pounders will sit. -
Next completes the anchors and lanterns Followed by the catheads. Next were the channels. Although not called for, I drilled holes into the channels for pins Followed b y hole in the hull to glue and secure the channels a bit better. Things look pretty even. The instructions are a bit lean on placement relying on a lot of careful observations of the pictures. -
Finally finished ship's boats. Can finally get back to the hull. These boats were the last little jobs to do. -
Spent a few a few days building the 4 ship's boats. I prefer Vanguard's laser printed ones as the planking here is a pain. -
Finished up the bow railing/bulwark. Not as satisfying as a Vanguard model in terms of fit and finish of the parts, more rustic to me. -
Did the inner bulwarks, finished outer fret work, inserted windows to the stern, scroll work on bow and forecastle as well as flag locker and flagpole holder -
Carved and placed all the decorations above the gunports Took a week but finished all the gunports Installed the closed ports and the open ones will be done later so I don't keep catching them with clothing Then Started on the stern. Occre provides a tool to make the molding Then a bit of sanding sealer and poly for the patina Finally did all the hatches -
Congratulations on another lovely build! Look forward to following your Grecian project.
- 241 replies
- Vanguarrd Models
- Harpy
Finally, after 2 weeks the tedious process of making up all the guns is done. Of course more than 100 to do so was a bit of an assembly line First a jig is made up/ The holes allow the wires to be placed at varying positions depending on which gun carriage is being made. Then all the carriages were made Worked proceeded by adding the various parts . Finally painted with sanding sealer which gave a nice patina to the wood. Next tedious job will be to make up all the gunports and hinges. -
The completed Granado build can be seen on the forum. I have been replacing the blocks in my builds lately with more realistic ones unless already in the kits. The first time I read about bob ketches was in C.C Forrester's Lord Hornblower where he watches them being used in the baltic states.
- 66 replies
- Adder
- Vanguard Models
I used the kit pins and spray painted the hull
- 66 replies
- Adder
- Vanguard Models
Lovely work and I always learn something following your builds!
- 332 replies
- Harpy
- Vanguard Models
Strakes all done. Not perfect but not bad. At this point I will vary a bit from the instructions and cut the hull off the cradle and plant the port side. -
Took a week but all the openings are lined except for the 3 upper deck ones which will wait until I plank the inner hull at that deck. After more sanding, I sealed the wood. -
With the help of my little friends I completed opening the 110 openings on the ships hull. Next is the equally arduous task of lining all the openings. Unfortunately it did a number on the ribs which will need further trimming once the deck beams are in place. The drill saw help a lot in this process -
3 hrs of work, 16 ports done, 92 more openings to go. 5-8 ribs, depending on the deck , are cut or filed for the ports. I will need to remove the whole rib to deck level for the guns to fit later but until I start the lower planking, I need them in for support on the one side being planked. -
Yes it is really old school after so many Vanguard model I have done. -
For the gunports, Occre provides stencils to cut out and then trace out the ports. Upper stencils are supposed to line up with the lower ones but they ended by not aligning properly requiring some adjustments. The Occre video instructor also noted this problem. Once marked off you can see the work ahead. Took time to make sure things symmetrical . Next I used tape to run the lines of the ports and to decrease splintering of the edges. From an angle things look pretty aligned. I started the opening of the ports with the stern gunports. Then lined them with 1x3 strips. Once the glue dries overnight I will sand them flush. Still have like a hundred to go. Fortunately an electric drill helps things go a bit quicker. -
Thanks all. I will also plank one side of the lower hull which is an option (had to also buy the planks from them as not provided in the basic kit. -
Finished planking the upper hull. Here is pre-sanding After a preliminary sanding: Next the arduous task of doing the gunports
