ECK
NRG Member-
Everything posted by ECK
- 37 replies
Hull mostly done. Prow done, whales/deadeyes in. Last thing to do is assemble the guns. Here carriages lined up for airbrushing
- 37 replies
- 37 replies
Very nice indeed! Your castings have a lot more definition than Amati's
- 37 replies
Thanks. Unfortunately the quality of the castings is nothing compared to Vanguard's photo-printed ones.
- 37 replies
- 37 replies
Had been out of town last week and finally got back to the shipyard today. Finished the rails, various eyebolts, battens and sweep hatches.
- 37 replies
Thanks. Most of the fleet is anchored on our dining room table!
- 37 replies
- 37 replies
- 37 replies
After 4 rounds of filling, sanding, painting , repeat, lower hull finally painted. Now I can move on to the upper deck fittings. Also fitted the rudder
- 37 replies
Decided to next get the lower hull painted. Used Vanguard's gauge. Works well with ship on a lazy susan. Th Then taped and painted tape with poly to help seal it. Next I put the pintles on the rudder then clamped onto hull to mount hull pintles Will remove the rudder when I spray and fill the hull. Will paint it separately.
- 37 replies
- 37 replies
- 37 replies
Second planking complete. There was quite a variation in the wood color so I used the lighter ones for the upper areas that would be bare and the darker ones in the area to be painted. Not the best planking but paint is a wonderful thing. First pre sanding After sanding and filling Next wales added then taped off for painting as well as stern counter After pianting
- 37 replies
Second planking continues. For a change decided to plank the inner bulwark today. Plan to later spray paint then place lower edge to bulwark
- 37 replies
Before I started the second planking I soaked and bent several pieces so would put less tension on the cyano when gluing. Then the planking commenced, remembering to carve out the gunports and sweep holes. Also glued lower stern counter .
- 37 replies
- 37 replies
Planked and painted for'castle bulkhead and will put a door in the middle later. Plans actually say nothing about what to do with this area. Then started planking I then realized that with sternpost in place as per the instructions, planking would not blend in well. Remembered with Vanguard stern is usually filed down then planked then sternpost added. I removed part of the post and feathered it down.
- 37 replies
Looks great! I think you can easily do more complex ships and rigging. Sometimes easier as you have more space to work with.
- 146 replies
- Adder
- Vanguard Models
Since finishing HM Adder decided to do HM Granada. Interested in mortar ships since reading about them in the Hornblower novel The Commodore. where he used them in the Baltic. Had to move my Vanguard collection( to small for fleet but maybe squadron or flotilla?). First step involves gluing the false keel to the frame I was spoiled with the Vanguard kits as the instructions were excellent. Here, lots of vagueness at times and some areas not explained making me look at the box photos for help Next inserting the ribs and lower deck Next upper decks. Lots of clamps involved
- 37 replies
Very well done! I usually have a clamp on the other line as I am belaying one side. I do not glue anything until the end when everything look aligned. Await your next project.
- 146 replies
- Adder
- Vanguard Models
Watch out for those anchors, they are a bit delicate. It is the only issue I find with the laser printed ones.
- 66 replies
- Adder
- Vanguard Models
The secret is an empty nest but no grand kids yet !
- 66 replies
- Adder
- Vanguard Models
Well, another completed. Fun project with challenge being the very rounded prow. Note the lowered center boards Now for the next project, unfortunately I think I have done all of Vanguard's projects that are not similar to each other. I like doing larger vessels. So until Chris can get the 1:64 Victory somehow, I will do one of his older projects from Amati. I am interested in doing a mortar ship ever since I read about their use in my youth in the C.S Forrester Hornblower series book The Commodore where Hornblower uses a mortar ship in the Baltic.
- 66 replies
- Adder
- Vanguard Models
