Ferrus Manus
Everything posted by Ferrus Manus
  1. Now that the rigging of masts is complete, we can start in on the yards. Yes, you saw right. The main yard is 1.5x the LOA of THE SHIP. Each individual one of the spars that are tied together to make the yard are individually as long as the distance between the bottom of the keel and the top of the flagpole. It also might be an issue that i'm not using the plastic kit-provided "sails", because the mizzen yard is the second or third flimsiest yard i've ever received in a kit. I just got done painting the rest of the blocks and will begin stropping them at some point today.
  2. Just save yourself some time and sanity like I did, and junk the shroud loom. However, you could very well make it work and prove us all wrong.
  3. I also plan to use toggles on the vangs and braces for both sails, 8 lines in total.
  4. For being the most complex shrouds i have ever rigged (looks can be deceiving!) I like the overall appearance. I agree with your assessment, however, from a distance it isn't really seen. 1441 exactly? The open flame technique worked miserably on the Golden Hinde, breaking several lines, and i never tried it again. I am open to the waxing technique though, i bought several pots of finger-apply lip balm just for this. I have never used it as lip balm.
  5. These are the rest of the components for the shrouds: If you think you'll ever find a painting of any medieval ship that's accurate and detailed, just throw in the towel and go home. However, we think we know how late medieval shrouds were attached to the mast. This is a picture painted by our wonderful friend Vittore Carpaccio in 1490. Look at the top of the mizzen mast of the first carrack closest to us. It seems as though the shrouds were attached the normal way, then wrapped with lashings around the mast, probably as preventers.
  6. That plank was found to be suffering from dry-rot before the voyage, and was replaced, hence the cleaner appearance.
  7. The structure of the shrouds are, from top to bottom, the shroud line itself, the toggle with a loop around it, the upper block with a loop slightly bigger, the lanyard, and the looped lower block.
  8. The lower shroud blocks are made up of a loop tied around the block, then tied to the rail.
  9. Alright, today i finished the deck fittings for the Sao Paulo. The scratch-built pieces on the deck are the main halyard knight, the windlass, and the pumps. If you are wondering about the reasoning behind me using a block for the mizzen halyard instead of a knight, this is because a knight would have to extend all the way down to at least the main deck, and that isn't possible as anything extending down past the level of the quarterdeck aft of the mast would foul the tiller. This is the mechanism that was used on ships in the 16th century. On the ship is a more realistic solution for the 15th century handle. Now the next issue. Neither mast is properly stepped. For this reason, i can choose any rake i want for both. The mainmast is stepped considerably aft of what i think is reasonable, but i have a solution. Almost all the caravels in this map from 1513 show the mainmast raked significantly forward. This is likely following a tradition in earlier caravels, and the even earlier Mediterranean tradition of 12th-13th century fore-and-aft rigs.
  10. The shroud loom that Heller gives you is worthless, and the deadeyes are absolutely unusable. Buy aftermarket deadeyes and rig the shrouds and ratlines using techniques on MSW.
  11. This is why i decided to add the tackles. The reason i know (or at least highly suspect) tiller tackles were used on carracks is due to their massive size- controlling the rudder without them would be impossible. I guess if there's one part of the ship that won't be destroyed in a storm, it's the tiller. Also, owing to the Mediterranean tradition of brightly painting ships (that still exists today!), you'd think that the idea of at least some caravels being brightly painted is plausible. This is the steering tackle: I also rigged the preventer for the rudder: It would be nice if that stayed on the ship.
  12. The tiller on this model is very long. So long, in fact, that on the real ship, it would be no more than six inches away from fouling on the mizzen mast and being rendered entirely nonfunctional. At 1/1 scale, the tiller would also be about 6 inches square at the tip. This begs the question: Is there any evidence for the use of tiller gear on caravels in the 15th century? I am tending toward adding it on this build, owing to the impracticality of not having it. We also know it was used on carracks, which adds credence to the "yes" route.
  13. The more i think about it, Heller is probably the reason we can't have good, historically accurate plastic models of 15th century carracks. They ruined that with their ridiculous hull-reuse stunts and horrendously inaccurate reconstructions.
  14. My decision to paint the upper works a blue-green color comes from the other plastic models i have seen constructed of 15th-century Iberian vessels. There is likely no evidence for or against the use of this practice on the real ships, but this is kind of a little homage. The paint i applied to the model was more blue than the examples i have seen. This is probably the only thing on this model that doesn't have a clear origin in the Middle Ages. However, there are remnants of paint on the Mataro Carrack. Granted, that paint was red and in a different place.
  15. Can't tell if this is good or bad. Anyway... Fun fact: This model has a grand total of six (6) locator pins. By far the most common complaint i read about this kit was in regard to part misalignment. That being said, the alignment of parts was not worse than most of the ships i've built, and significantly better than some. Even the upper works, which were to be aligned entirely by eye, fit together well. The transom, which is the most ridiculously challenging part to fit on any plastic model ship, went on without a major issue. With that exception out of the way, the other two most common complaints i read were that the model had almost no detail, and looked more like a toy than a model when completed. Both of these issues could be resolved with any amount of effort put into the paintwork:
  16. Bingo! The sterns on the ZHL 1/48 model and the Model Shipyard kit, available in either 1/78 or 1/60, are identical. SHAMEFUL!!
  17. This is a screenie from ZHL's actual site showing the frames of the ship. @chris watton This looks like something you would design. Have you ever designed a Surprise, regardless of scale? They may have scaled it up.
  18. Someone on Ships of Scale bought the ZHL kit and from looking at it, it's likely that they stole it from AL. There are a couple differences, like in how the parts are laid out, and a couple parts are different, so it might be a different kit. The guy's name on SoS is Jweb.
  19. Steven, i (as a severe type A hemophiliac) find your new signature quote very fitting. It really isn't a ship model until you've bled on it, and it really isn't a ship modeling tool until it's caused you to bleed. The worst offenders are my xacto knife (obviously) and, get this, my pin vise.
