Ferrus Manus
Everything posted by Ferrus Manus
  1. This is what i came up with: The flagpole is not glued in yet. (The martnets are supposed to be slack lines, so don't execute me for not gluing them)
  2. @kirill4 i found a way to rig the flagpole. However, there are not many sources for 4-masted galleons, so both ideas are likely equally plausible. Thanks for the CA glue trick!!
  3. LOOK at that!! Wow! What an incredible model.
  4. The bonaventure lateen sail is decently well on its way toward completion. However, one challenge has presented itself, that being how i am supposed to stick a long flagpole onto the stern of the ship on the starboard side. I have decided i would like to have it on the starboard side because of the way the wind is blowing. I would like the flag to be able to fly unopposed by the bonaventure sail or any of its rigging. On many of these paintings, the ship in question has an almost comically large stern flagpole, flying an equally large flag. However, these ships are very different to my vessel in one major way: They do not have bonaventure masts or sails. This is very important. The aft bulkhead on a four-masted galleon is an extremely crowded place, much more so than on a three-master. Thus, one must choose where the flag is to be flown at the stern. The crew must have actively transitioned the flag from port to starboard and vice versa, depending on the tack of the ship. Flying it in the center of the bulkhead would mean it would run seriously afoul of the bonaventure lateen's sheet. This problem did not present itself in Kirill's build owing to the fact that his ship's bonaventure sail was not tacked in any considerable way; mine is. I will have to figure out how long of a flagpole i can have without the flagpole truck fouling the top of the bonaventure lateen.
  5. Part of it is just the fact that that was just where the sail was sitting completely without reinforcement, just gravity.
  6. We already decided against that. The sail does not drag on the deck in that position, but that doesn't really matter as we collectively came to the conclusion that the sail will be properly set. Edit: upon looking at the pictures, it might actually drag on the deck.
  7. Your capstan is quite well constructed. Should i thank you for that, or Airfix? It seems that even at a 6:1 mechanical advantage, the capstan would be needed. These anchors weighed several tons apiece.
  8. So you're essentially saying this was an auxiliary device, and the real cat block had more sheaves?
  9. Therefore, i propose something like this for the bonaventure sail: Would that work, or should i haul it all the way up like the mizzen?
  10. Here we go. I would like to bring something to your attention. In period artworks featuring galleons, oftentimes the lateen sail at the aft is allowed to billow out and rub against the shrouds, and is also lowered about halfway instead of being raised to the top.
  11. The single cat block does seem pretty impractical. However, the line may have been attached to the capstan and raised that way. Where is the capstan on the Vasa?
  12. Please, stick around. I really want you to stay. You're a good friend, and an even better mentor. Even with the language barrier.
  13. Next build will be of a viking ship. That will be my playground to try out all your tips and tricks.
  14. Michael and Kirill, the build has progressed too far for me to just rip everything out and redo it. However, i can take tips on how to improve what i already have done.
  15. Same thing i used on the mizzen rigging. All lines will be the tiny white thread. That is what i have at my disposal.
  16. What types of thread do you use? are there any brands you like? I am using modelling thread, which is quite hairy. As i put together the bonaventure sail, i will use the CA technique. How would i go about painting threads, but not getting that paint on the sail and other threads?
  17. I am about to start on the bonaventure lateen sail. I have about four opportunities there to use CA to make really good crow's feet.
  18. I see it now! Thank you for showing me. A lot of times, i don't understand until someone tells me. I will do that with the bonaventure lateen sail.
  19. Oh, your build log! I think that got lost in translation. I looked there and found where you did the crow's feet for your mizzen lateen sail.
  20. At first i did not know where to find where you did your crow's feet, but then i searched and found it.
