Everything posted by Ferrus Manus
I fully expect the unabridged report when it becomes available, as do many of your other shipmates. Take it easy, and rest well.
- 56 replies
- Lindberg
- sternwheeler
Keith, another point- I hope your April 30th went well, and no drastic action was needed.
- 56 replies
- Lindberg
- sternwheeler
Keith, that thing is the work boat to end all work boats. While my interest lies mostly in the 1890's-1900's British sailing work boats, this is also incredibly interesting. It seems to be made from wood and cast parts. For something not much larger than my steamboat, it seems pretty expensive. I have done some significant work on my steamboat, with the middle deck in and some of the upper works partially painted and dry-fitted into place.
- 56 replies
- Lindberg
- sternwheeler
Today, I finished painting the upper works. These are in the characteristic French style of gold-on-blue. It is slightly more subtle than could be expected from French ships of previous decades, but still extremely prominent and would serve a very important purpose. As an anti-piracy vessel, this style of scrollwork and filigree detail would effectively scream "I'm from the French navy, halt in the name of the law!" from large distances. US Coast Guard vessels also have prominent livery for similar reasons.
In hindsight, tearing the whole beahkead section of the Requin and starting over was absolutely the right thing to do. After repairing and repainting all of the affected pieces, I reglued them onto the ship and filled, sanded and painted over the joint between the beakhead and the hull. The timbers need to be repainted again as the constant handling of the parts has worn down the paint. The next job will probably be painting the stern transom and fixing some of the paintwork on the hull, perhaps followed by the installation of the bowsprit.
One step forward, two steps back. Something many of you probably don't know is that scale modeling, on rare occasions, makes me angry enough to throw things. This time, after about five failed attempts to get the bow timbers mounted onto the beakhead, I tore the whole thing off of the model and threw it across the room. Here is the result: I am currently attempting to glue one of the timbers back onto the beakhead. Once all four timbers are on and painted, and the paint has been sufficiently cleaned up, I will attempt to mount the whole thing back onto the ship. This is probably what I should have done in the first place. The contact surfaces of all parts are caked in glue residue from nearly half a dozen failed attempts.
I promise you I haven't given up on this model, I've just temporarily transitioned toward another small model. I have gotten the gratings and hatch painted, with the larger grating modified to accept the anchor cables. Now, I have made an executive decision on this model. This model is being made for and is intended to be viewed by a non-expert. He is a personal friend who is also a college professor. I am a full-time college student (soon to be full-time university student this fall) and I also have a job. Hence, I do not have a ton of time or energy left for modeling. I am well aware of my capabilities as far as scale modeling is concerned. I do not think I will go all out on this model, but instead build it mostly out-of-box until we get to the rigging. That means no (or abridged) gun rigging, no gunport lids outhauls/inhauls, etc. The ship, however, will have a full and complete rig. I know this may come as a shock considering my modus operandi, but I feel like making this model a perfect replica of the real Requin, while possible, is not in the cards this time around. I know fully well that if I wanted to make this Requin a completely accurate model, I could. I choose to be happy with that.
#616 is now most of the way to being complete, minus the reconsideration of the oar positions and the stand. You see, when I built this little skiff, I encountered a problem I am all too familiar with when building at such a small size- the lesser the size of the contact area, the much less effective most adhesives become. When gluing a plastic (painted) oar to a metal oarlock, one of the only things that works is CA. Having broken off the oars from the oarlocks and the oarlocks from the hull several times, the CA began piling up into an unsightly mess that can be seen in the first few pictures. So, I took the oars off of the oarlocks, sanded and repainted the affected areas, and replaced the oarlocks. Here is the result of my efforts from yesterday and today:
- 56 replies
- Lindberg
- sternwheeler
I'm not quite done with 616, Eric. I plan to give the hull some disgust and abuse, give the bottom of the hull some gloss paint, and a little something special as well.
- 56 replies
- Lindberg
- sternwheeler
- 56 replies
- Lindberg
- sternwheeler
- 56 replies
- Lindberg
- sternwheeler
- 56 replies
- Lindberg
- sternwheeler
I have now made and added the inwales to the boat, and shaved down the frames to the correct height. Afterwards, I made the two thwarts for the boat. The forward thwart is the thwart from which rowing will be done, and its position has been decided on. However, the aft thwart can occupy one of two positions, as shown. Any input would be appreciated. Input regarding the thwarts would be appreciated. I know the boat looks terrible up close and personal, but it's naught but 2 and a half inches long and all inadequacies will disappear when painted. From what I understand, plastic is a much less forgiving medium than wood.
- 56 replies
- Lindberg
- sternwheeler
The vertical portions of the frames have been installed (I don't know the names) which must now be sanded down to the level of the gunwale. The inwales will be added afterwards, and then the boat will be painted. The thwarts will rest upon the inwales. I will fill and sand any ugly portions of the frames before any of this happens.
- 56 replies
- Lindberg
- sternwheeler
- 56 replies
- Lindberg
- sternwheeler
So, you made up the tradition and I am not to carve that into my boat? Gee, thanks. I thought you were full of facts, not fiction. 🤣
- 56 replies
- Lindberg
- sternwheeler
Eric, you are giving Lindberg far too much credit. That is the number 61, the part number of the boat. I will make the carving on the underside of the boat when it is finished.
- 56 replies
- Lindberg
- sternwheeler
Eric, all of your information has been extremely helpful and insightful, and I greatly appreciate your comments. None of them come off as anything other than informative and objective, and quite frankly, I would like to know more. Now, I think the completion of the ship's power train warrants a slight pivot to take a good look at the ship's skiff. here's the sorry excuse for a boat that they gave me, even though it looks fine on the outside. It is obvious that Lindberg never thought that some modelers would like to display their ship's boat somewhere other than upside down on the upper deck. Now, if you know me or have seen some of my logs, I usually want to display ship's boats separate from the actual model as a miniature piece. Let's see if we can build ourselves an interior for this boat.
- 56 replies
- Lindberg
- sternwheeler
@Keith Black @Cathead @Kenchington It seems as though the two inaccuracies in the boiler system actually cancel each other out. If the fireboxes were to be at the front, they would be at the front to increase airflow towards the extremely long chimneys (good to keep coal ashes away from a wooden boat) but the chimneys are abnormally short for this kind of boat. Now, this kit doesn't pretend to be an accurate depiction of any one boat, or even type of boat. Honestly, if I wanted a true-to-life representation, I would have just scratch-built my own steamboat as modifying the many inaccurate parts of this kit probably would have taken more effort. This kit, in its most basic form, is meant to be built as essentially a toy. I am choosing not to build it as such, obviously. At its core, despite its inaccuracies and failings, it is one of the least offensive offerings in either plastic or wood. Most of the other steamboat kits out there in either medium look very inaccurate, and honestly, quite ugly. Hence the large proportion of scratch built steamers on this forum.
- 56 replies
- Lindberg
- sternwheeler
Eric, I think the steam boilers in question might be based on land boilers used in steam tractors and locomotives. For one, there is this article that explains that the conflagration of coal gases run in a tube through the water in the boiler, heating it: There are also some images of steam tractors that show the firebox at the back and chimney at the front, which seems to have been the standard configuration at the time: Our boilers on the ship seem to be at least partially based on this steam tractor from 1920. Perhaps the designers of the kit misapplied the concepts of land boilers to their marine boiler design. This begs the question: if the coal box and chimney are both at the front of the boiler, how would the water be evenly heated?
- 56 replies
- Lindberg
- sternwheeler
Eric, as I primarily deal with sailing ships, I am well aware of the confounding terminology involved. With that said, I understand that this kit is not based on a real ship, but is instead designed to look like a relatively convincing replica as viewed by a non-expert. This kit puts the fireboxes at the back of the boilers- there are even doors molded onto them. Furthermore, the location of the fore bulkhead makes it impossible for a man to even access the fore of the boiler to shovel coal. While this is inaccurate, I am not willing to scratch-build new boilers on a boat that should only take a few weeks to build. In other news, I have gotten the boilers and chimneys painted.
- 56 replies
- Lindberg
- sternwheeler
I've now made up and painted the platform upon which the boilers sit, built the boiler assemblies, and I have them dry-fitted in place as well as the fore bulkhead and the second deck. Next step is painting and installing the steam boilers.
- 56 replies
- Lindberg
- sternwheeler
Kieth, I greatly appreciate being taught the terminology for a type of ship I know very little about. Anyway, yesterday I got the arms and other machinery hooked up to the sternwheel, and the siding for that section of the ship into place. As is relatively standard for my work boats, I made the weathering severe and nasty, indicating a long life for the ship. Next is the coal boilers and associated machinery. I have also decided on a name for this boat- Carol Ann. Maybe when Lula's rudders jam, Carol Ann can push the supply barge for the pile driver. (Seriously, Kieth, your Lula is a masterpiece that I couldn't hope to compete with as I build this kit. You should be proud of her.)
- 56 replies
- Lindberg
- sternwheeler
The process of finishing up the sternwheel involved entirely disassembling the wheel assembly and associated machinery, realigning and repainting the wheel and machinery, and gluing the paddles to the wheels. The process of assembling the paddle wheel: The paddles were attached five at a time. After they were all in place, I repainted any areas that were scuffed up by the assembly process, and sprayed the wheel in a clear sealant. This is to protect the wheel from further scuffing and to simulate the wheel being wet from the water it revolves around in. Here is the wheel as it sits tonight: Tomorrow evening, I will assemble the rest of the stern machinery.
- 56 replies
- Lindberg
- sternwheeler
