Everything posted by Ferrus Manus
The last few days' worth of progress includes the ship's stempost, a stop cleat, two timberheads, the fore belaying rails, the windlass, and the ship's only ladder. I am also working on a solution for the ship's anchor setup.
Does anyone know what this rigging is called?
Ferrus Manus replied to RobMann79's topic in Masting, rigging and sails
In my experience rigging galleons, I have rigged crowsfeet an extensive number of times. However, I have never seen or used crowsfeet in this way. The way I understand them to be used is to distribute tension. It could be that this is a special application of crowsfeet, or that their function had completely changed by the 18th century. I could be wrong in my initial assessment in this case, and if I am, please disregard my initial reply. -
Those are called crowsfeet, and they are intended to balance out the tension on various lines. In this case, the crowsfeet are used to equally distribute the tension from the stay across the fighting top. -
The three additions to the model in the new year are the mizzenmast, the mizzen shrouds, and the two fore timber heads. These timber heads will be important when we discuss the anchor arrangement later. The only other part of the bow that needs to be made is the stempost, which will come next. Apart from that, the only other pieces of deck furniture that have yet to go on the ship are the windlass, ladders, and mizzen halyard/parrel block arrangement.
That's pretty much exactly what I did. The lip balm I use to wax line is derived from beeswax.
Having nothing else to do for New Year's, I did the shrouds. Despite my best efforts, the lines remain hairy. It gets less visible the further away you get from the rope. I attempted to design the blocks and tackles to be as close to the Mataro model as reasonably achievable, and I think I did a pretty good job. In fact, I'd say that disregarding the quality of the line itself, this is one of my better shroud setups.
I made up the parts for the mainmast rigging, having made the decision (in the absence of Steven's input) to make whip-and-tackle shrouds. These are the closest I can get at this scale to "true" Medieval blocks. I also made and put in the rope loops for the toggles. Each shroud will have two toggles, one at the base of the whip and the other at the lower block for the tackle. The placement of toggles is intended to ensure the shrouds can be disconnected from the hull easily and from deck level. Much to my dissatisfaction, the only thread I have in the correct diameter for the rope loops is the crappy "thread" (if you can even call it that) supplied in a 60's Revell kit. Despite me having stained and heavily waxed it, it remains ridiculously hairy. You can't see it in the picture.
Now that it's nearly time to get started on the standing rigging, do we think whip-and-tackle shrouds would be reasonable for a mid-15th century Iberian lateener?
I have done a significant amount of work on the caravel in the last few days. For one, I have made up the main calcet and flagpole, and both masts. Both masts are currently resting in their intended final positions on the model. I also glued the rudder in, and got both castle decks painted and glued into place. The only modifications were supporting timbers under both decks, and partners for the mizzen mast. Looking back, both of those injector pin holes are in such horrible places, and probably wouldn't have been too hard to fill. Let's just chalk it up to shipworm.
Here's the rudder that I modified to fix some of the issues I experienced last time. First off, I solved the problem of potential preventer ropes by attaching two ringbolts to the rudder, one on each side. Secondly, the tiller was unrealistically fat and long. So, I shaved the tiller down a good 8 inches at scale, slimmed it down the same way, and attached a handle that a crew member could actually get his hand around.
I made and fitted the mainmast halyard knight, the parrel knight, and the ship's pump. I also made the bottom of the hull look a little more disgusting and painted gloss on the hull and deck where water would be. I think I might leave the pump handle off until the rigging is done as I might accidentally break it off.
I fixed and repainted the stern railings, then I temporarily put in everything I could for this picture- the mast, quarterdeck, and forecastle deck. Previously, I installed the two main belaying rails for the ship, on both sides of the amidships section. I will install another, smaller pair immediately behind the forecastle. I want to discuss the arrangement of the deck furniture before moving on to potential shroud arrangements. Firstly, I used the two futtock riders that were supposed to go at the break of the quarterdeck to create a set of guiding rails for the mainmast. That way, I could adjust the rake of the mast while ensuring proper alignment. I did not intend to use the pieces as intended, so I reused them. Secondly, I want to talk about the two holes in the deck. There are two holes on either side of the mast partners that were originally intended to accommodate a pin rail. This obviously wouldn't have existed on a mid-15th century caravel, or any lateener for that matter. Anyway, I need a way to cover them up, and I came up with several options. Firstly, I could install two bilge pumps over them. My only issue with this is that the ship would likely only need one. Secondly, I could offset the halyard knight to cover one of the holes, and make a smaller knight for the parrel tackle to cover the other hole. The offset of the halyard knight would make no sense in the absence of a mizzen stay, so I compromised between the two. Over the port side hole will go the ship's single bilge pump, and over the other will go the parrel knight. The halyard knight will go between the aft hatch and the mast partners, on the center line. While the rigging of the ship is a long way off, I would like to at least discuss the shroud arrangements, as they will affect the deck arrangement. The only issue is that contemporary depictions of shroud lines on caravels do not show the tackles. Most of what we know about caravel shrouds come from lateeners before and since, and contemporary square-rigged ships. Last time, I simply went with the standard lateener shroud tackle approach. There would be no issue with doing it that way this time, but I might want something more interesting. Should I go with the standard approach, there would be no need for deck ringbolts to accept a whip. Should I decide on two pairs of whip-and-tackle shrouds, there would need to be four ringbolts on the deck. I'm sure Steven has some answers as to whether that seems reasonable in light of archaeological and pictorial evidence. I'm sure caravel rigging was not standardized at that point.
At some point before the introduction of the quarterdeck I will have to go back and fill/sand the injector pin marks in the stern railings.
The painting of the ship continues... I kind of wanted to make it look like the Mataro Carrack, minus about 400 years' worth of aging.
Minor progress, but enough to warrant a post. I made and glued in the ring bolts, and glued the hatch assemblies and the mast planks into place. Moving on, we will be starting on the hull painting. I would like to expand on the actual paintwork present on Late Medieval caravels and other Mediterranean lateeners. For clarification, Santa Sofia will be essentially a work boat (mostly fishing) and will not bear the colors of Portugal on either flags or sails. The vessels owned by a monarch/state could reasonably be assumed to have been a minority in any waters of any time period.
The hatches and mast planks are resting atop the kit-supplied deck. Everything is painted in its (mostly) finalized form. I might add some more grime around the edges of the deck. If I can continue pulling off this level of painting, we might have a halfway presentable and halfway accurate model by the end of this. I actually remember being halfway done with the hull of my Sao Paulo by this time in the build.
In the past few days, I painted the cargo hatch and made up the second, crew hatch and rectified Heller's lousy excuse for mast partners. The planks for the secondary hatch lie on a flat plane, instead of one that is slightly curved.
Steven, this is why I will neither die nor rest until an intact carrack wreck is found, or at least one that sank fully on its side, preserving at least half of it. I wouldn't be surprised if everyone's idea of what a medieval ship's hatch looks like is completely based on later ships: No solutions come from the Gribshunden or Okant Skepp wrecks either- I place more faith in the Okant Skepp to yield results mostly down to how perfectly preserved the ship is.
Hi @Doreltomin, your assessment on the Mataro hatch cover is 100% correct. From that angle, it becomes apparent that the hatch cover is carved from a single piece of wood. While the structure of my hatch is almost identical to the structure of the Mataro Carrack's hatch, the hatch cover is entirely different. This is the hatch cover I designed: The six interior planks comprise two panels that are held together by two cross-planks apiece. Lifting each hatch cover panel would be akin to lifting a heavy household door- doable via a two-man effort. The four holes will accept ringbolts for the panels. My guess is that one of three things are true about the Mataro's hatch cover: 1. The carved piece over the hatch is meant to represent a tarpaulin. 2. The carved piece is an inaccurate repair from centuries later. 3. The shipwright who made the model didn't care about depicting the hatch cover accurately. My guess is either 1 or 2 are correct, as the shipwright went to otherwise great lengths to ensure the construction of the ship was accurate to a real carrack. Either way, a single-piece carved hatch cover would have been impossible to lift by less than 6-8 men without using tackles. Depictions of medieval ship hatches (and other deck details in general) are unbelievably rare. Here's one that's just a hole in the deck: That being said, the idea of just making deck planks removable lends itself to the idea of multiple panels for the hatch cover. To be honest, I don't know where modern replicas/models/reconstructions of Medieval ships get their sources for the almost ubiquitous multi-plank hatch cover.
Time for another mid-15th century Medieval ship. This is, once again, going to be based around Heller's "Nina". This is actually from Heller's set of Columbus's ships, and is a special edition. However, it is the same exact kit I did in January. I managed to get it for only 10 dollars at the local hobby shop, because whoever had it before me glued the hull halves together (and actually glued them together perfectly, mind you!) However, that's all he did. Otherwise, the kit is complete and unstarted. I'm going to start this log off by saying there will be some significant modifications/additions to the kit. For one, I have some things I want to do with the deck fittings and anchors. Secondly, all the rigging will be of my own design (as always) and I have a desire to make all my own blocks. The masts and yards will be made from wooden dowels/skewers (I see you Steven) and there will be some other miscellaneous sprucing up of the kit. This includes cleats, rails and other belaying points. Here's the ship as she sits now: Let's start with the deck. The deck planks are a bit long and thin by Late Medieval standards, but as far as I'm concerned, acceptable. The hull planking is also like this. What isn't acceptable is the hatches. I've known since I cracked open the box for the first version of this kit that the hatches were inaccurate to what they would have looked like at the time (see the Mataro Carrack and the carrack from Botticelli's Judgement of Paris). At some point between my construction of the Elisabetta and now, I actually realized that the hatches aren't just inaccurate, they're unusable. It's obvious that each hatch consists of eight removable panels, and in between those are timbers integral to the hatch design. No one, not even a child, could fit in between those timbers at 1/75th scale (more on the scale later). So, I came up with this idea: The aft hatch is going to be for "people", and the forward hatch for "stuff". The "people" hatch will fit the contours of the kit-provided hatch mostly, and consist of two removable, longways panels and nothing in between. The "stuff" hatch will be covered with two longways panels consisting of three boards apiece, also with nothing in between. The frame of the "stuff" hatch: The Mataro model shows a similar arrangement, except the hatch is covered with a cloth:
Maybe after the Lomellina? What else is on your bucket list?
- 176 replies
- la reale de france
- heller
Thanks Steven, but I bought the kit last week. Definitely going to be some modifications though, as I think I can do even better than last time. I decided about a month ago that after the Reale, I wanted to do another lateener.
- 176 replies
- heller
The reason I have not taken that idea up is that I might want to make this build able to actually float in a pool, something that was Don's idea. A single-piece hull would certainly make this a possibility, whereas a wooden plank-on-bulkhead construction would carry significant complications. I entirely plan on coming up with my own deck arrangement and planking it myself, and likely doing significant modifications to the hull itself.
