Srenner
Everything posted by Srenner
  1. First planking is complete, only some random sanding and filling to do. I ran into a small issue where I ran out of the strip supplied with the kit and had to purchase some from a model shop but of course it was 2mm thick instead of 1.5 so that requires more sanding in that area... and also my measurements were a bit off so I just got a bit frustrated and planked off the final parts as quickly as possible. The issue was the spacing near the bow. I was pleased with the hard bend of the timber around the foredeck. Soaked for 24 hours then used a can and bent them around and held down with some tape and a g clamp. Put in the stern timber
  2. Planking is well on the way to be finished... 5 planks left to go. As always your technique improves as you progress now edge bending with an iron is second nature and the planks going fairly easily. This book arrived in the mail today and also the order has gone in for the 3d printer so I'm to print alot of things the the kit provides but are crude by comparison. Of course learning to use it is a hobby in itself so that will be interesting. Have a good idea for the figurehead which replaces the boring semi naked lady... if I can design it and print it well
  3. Hi... I've taken the plunge today and pressed the purchase button on below. In terms of software will be Inkscape and blender before taking it to a slicer... hoping my software skills will improve alot as I plan to 3d print all the decorations for the 1720 royal navy ship, ships windows etc, figure heads that sort of thing. Exciting but also quite daunting
  4. So in this build I wanted to show a warts and all process for planking with a small scale ship. Yes its not pretty but the unsanded and un smoothed hull for first plank is still part of the journey. I seem to have run out of lime for this... so will have to buy some extra from a shop in christchurch. One side getting closer to closed in before sanding. A few mistakes along the way to fix up with filler. My first drop strake coming into the bow will be the only correction strake on this first planking.
  5. After reading and reading again the planking primers in the database and measuring with the tailors tape etc I can get my head around the bottom third of the hull with a splitter strake... seems easy and it was... The iron technique worked awesomely with just a quick dab with a paint brush dipped in water... very good will do that again. I just can't get my head around how to do the middle third... I know I need a drop strake in there but can't work out the angles and things... will do the top third next then worry about that later.
  6. Thanks... how did you take the cast of the rearing lion and the unicorn?
  7. I'm starting to prep for planking and been doing the calcs for planks based on the flow lines attached. Calculated one drop plank at the bow and one split plank at the stern. Garboard strike is in. Also this lovely book arrived from Amazon and the other book on 1719 establishment also in the mail... such awesome models including HMS Lizard, a sixth rate ship... but the decoration is a bit ott.
  8. Hi hamilton I have never liked the metal parts of this kit... you have inspired me to pull out those bits and replace with some 0.7mm basswood and paint red colour. My thoughts as always turn to the horrible stern piece...
  9. Another wet Sunday in our summer here in nz... this time a tropical cyclone coming down from the tropics... but good modelling weather again! I'm making progress with the walnut strips and lime around the gun ports. The really tricky part is the hard bends at the bow. I've tried soaking them and bending them without heat which works well with the walnut but not with the lime... on one of the photos you can see the outer fires of the timber strip has cracked... im thinking just sand it off and there could be some filler in around there. The instructions aren't very clear where the second planking goes... I think that plank will be covered with 1mm walnut but not sure. The other thing is the cutting out of the ribs from the inside to make the rail thinner.. final scale thickness will still be 500mm which is massive. I'm contemplating trying to sand it down to 400mm scale (4mm) only because the rail timber I have is 4mm.. or I could cut some new rails from mahogany I have.... need to think on that.
  10. Have you got your belaying plan clear ? On my jolie brise the running rigging for the gaff needed to be threaded through the same side as the belaying point and through the shrouds.
  11. I am loving having time this long weekend to do some modelling..... its way nicer to sit down for a good 6-8 hour session and make some good progress. The bow curved sections of the inner rail were not as hard as I thought... I soaked the pieces for a good 1 hour and carefully bent them using my fingers and a pair of pliers. I also tried the plank bender but being only 1mm thick there was a danger of cutting into them too much. Once I glued them into place with pva I used the heat gun to dry the wood out faster and also to get the glue going off faster... as it was awkward to clamp up near the bow. I have also cut one rib out from the inside to see how difficult that would be but also pretty easy with a dremel and cutting wheel and then a bit of dremel sanding and looking pretty good. Happy with that result so will continue with rest of ribs same way.
  12. I'm trying to work out how to bend 1.5mm mahogany strips around the bow... soaking and heat gun has been tried but it still wants to crack. You just need to be very careful when you bend it. Would a jig help or not? As a result I am building up the timber above the gunports in parts and gluing together. Later on I'm going to cut back the bulkheads from the inside and then do the final horizontal strips of mahogany on the inside. It's taking time waiting for glue to set but they say patience is a virtue.
  13. After screwing in a steel bracing element and gluing all the spine is not too bad... pretty straight and level. I've done all I wanted in terms of mast seating blocks and getting the bulkheads all even at the bottom so I've gone ahead and glued the deck down with some pins to hold it all together while it glues. I will just grind the heads off when I lay the decking. Painted the frames black so that when I put the hold covers on you won't see any lighter colour in there. Going to build the timber upto the rail from the outside in and then cut off the thick ribs and deck over the stumps.
  14. I have bigger problems right now I was working in several things.. slots for rods for display going into the spine, rebating the rabit line with the dremel, that's nerve wracking and then I stupidly leant on the spine with my elbow and snap! It broke in half... So right now it is being glued back together with blocks of wood over the break line and a ton of pva... lucky it was quite a jagged break and the bits slotted back together well... Once all the planking on and the deck glued down it will be back to a strong structure but you don't need hassles like this with a fiddly build.
  15. Good idea.. maybe you can even not glue them on to the frames just pin them and then build the inner timbers as the part that glue it all together then cut the ends of the frame off and close the gaps.
  16. Am I doing the scale conversion wrong? 2.25 inches is 56mm divided by 100 is 0.56mm ?!? Off the model plans the 4mm x 100 is 400mm which is 16 inches approx scaled up?
  17. Yikes I just read on in the instructions and it's very scant on the details around the area of in and around the gun ports and the railings and it took me 20 minutes to work out the diameter of the bowsprit dowel... 6mm if you want to know. And then the bowsprit won't fit in so I'm going to have to drill and ream out a space in around the bow for that lucky I haven't glued it yet. The rails are 4mm and that means I need to take the ribs very thin indeed to fit in... will think on that one.
  18. I plan to go 6th rate, 5th rate scratch build down to first rate all RN around 1700ish I'm only going with what the kit gives me... will look at the rail timber and scale it off that. They will be lined on the inside as well as the outside.. good catch though
  19. Dry fitting continues and happy with how things going. Fitted some filler blocks at the bow and still working on tweaking the pre cut pieces here and there. I'm not going to rush to glue pieces in until I'm happy with the hull lines, the fairing and cut the line the planks fit into. One question was putting a camber into the plywood veneer deck. I can see it will bend slightly so I took some slices out of the bottom side to help with bending but should I glue it down and nail it with the panel pins then remove the pins once the glue dries? Or wet the plywood bend it and then dry it again like planks of wood and then glue?
  20. You know what I'm pretty happy with how my blender adjusted bulkheads came out... I printed them off and cut them out of basswood first and that wasn't as satisfactory as using plywood... its pretty soft and bendy and so I printed another copy of the bulkheads and cut them out from 3mm plywood instead. I cut on the outside of the line so I can fair them in with the rest of the bulkheads and I'm happy they all line up at the bottom by the imaginary rabit line. I've been trying some bits of planking and testing the natural lines and think I can work with them as I fair it all in. The decking plywood needed some filing of the precut holes but that all fitting now too. So this is all dry fitted at the moment. Will be time soon to cut the rabit line and then do all the fairing and make sure the deck looks OK. I'm think I should put in any filler blocks I want now before doing the fairing? Need to square up bulkhead 4 so it's vertical.
  21. Now I'm mostly moved I have started to set up my workshop so I can start hms greyhound. I know what I need to do to fix bulkheads 9 and 10 so I will glue a paper copy onto a piece of 3mm plywood and cut them out separately before dry fitting. All the other pieces weren't cut out that exactly and needed a bit of filing to get them to fit frim the manufacturer. I can see bulkhead 11 and 12 need to move down 2mm and than I will need to bend the deck they provided into a slight dish... Do all ships decks camber and bend like a u? Because it looks like mahogany its going to be very brittle to bend and the ribs dont line up with the holes precut.
  22. I would have said for a one off project just printing them out and sticking them onto the plywood and then cut by scroll saw would be easy enough. But the costs of hobbyist 2d plotters with laser say in the 20 to 30w range would be enough to cut 5mm plywood.. I saw someone on this forum who has 40w laser and that cut one sided... almost too strong it burnt it quite a lot .. or you flip it and get less powerful laser. The motor controls on the 2d plotter and width of laser dot would be considations.
  23. So now I have a mesh I was happy with, I wanted to export it back to Inkscape and overlay it with my traced bulkheads 9 and 10. Not as easy as I thought. The way I did was the following: 1. Selected curve 9 and took a duplicate. 2. Separated that duplicate from the mesh 3. Converted it to a grease pencil with width 0.1 which is 1mm 4. Exported the selected grease pencil as a grease pencil svg 5. Imported the svg back to Inkscape The hard bit is to keep the aspect ratio so I was careful while overlaying to only use the corner sizer and I was aiming to get the width the same as the bulkhead width. The resized depth then is the outline of a new bulkhead I can print out and cut out from basswood on the scroll saw. I exported the file on a4 format so easy to print out at work. I also checked in with the actual pieces from the kits remeasuring and seeing if my resized bulkheads look OK. I now also have a theoretical rabbit line I can use to position all the bulkheads too and that may require some trimming and stuff when I dry fit them. I can't do any actual building I am moving in two weeks and need to reset up the workshop... then all my theory can become practice. A good learning experience... the first steps in 3d modelling.
  24. So into blender I went with my frames. There is a nice video done by krutis under the computer threads and my thread on what is easier on how I created a mesh over the top of the frame. Essentially you convert each frame into a curve and then duplicate a plan on each curve. I made my plans 1mm high so that increased the smoothing. Then you join the end loops together. Creating the mesh you see on the attached. You can edit individual vertices and edges to do further smoothing. I fixed up the mesh around bulkhead 9 and 10.
  25. So I used the directions and everything worked out well.. I liked flying through the mesh and plucking vertices and moving them slightly to get a better smoothing... that was fun and even did some vertices merging and adding bits on. That was fun first attempt. The hard part seems to be exporting in svg, the only option is through the grease pencil which seems a bit odd. Anyway I enjoyed the process and the learning over the past 2.5 days
