Mike Collier
Everything posted by Mike Collier
  1. I’m surprised that the plans did say to cross plank the bottom. Your doing a real good job.
  2. I’m on my third Wye River model the Box Stern. Also did the skiff and crab Scraper. The two plans sheets on the box stren don’t seem to match. I cut the deck out from the plans and it way to big. Yes these are like making scratch built boats , but I like them. Good luck and take your time. Do you have a scroll saw? It will help cutting everything out.
  3. It’s looking good! I will follow this build. I myself like to build work boats, mostly from Chesapeake Bay.
  4. Finished my Smith Island Crab Scraper. It was a lot of fun, I learned a lot about building wood models.
  5. I just bought Mirco Marks small drill press with a drill press vise all under $300. I set it up and drilled 2 holes in 1/4 “ square wood stock and it worked very nice. So far I like it.
  6. Yes, it’s really looking great! Where did you get the long black clamps?
  7. Painted the inside of the boat, glued on the decks , built engine box, transmission box and fuel tank. Installed the propeller and rudder.
  8. Today’s work, I have all of the decking supports in and the motor mounts in. I sanded and sprayed shellac inside of boat to seal it. Tomorrow I’ll spray the interior light green and build the motor and transmission boxes.
  9. This build is going nicely, I like it. The long blue clamps where did you buy them?
  10. Looks great! I’m going to have brake out my daughters sewing machine and learn how to use it.
  11. Still working on the bottom planking, slow progress but will get it done. Some of the areas near the front and back the planks need to be slightly twist, so I cut the planks to length soaked in hot water until the planks could be twisted then I used CA glue and held the planks down until the CA sets. Seems to work ok.
