Everything posted by oakheart
Gold solder for brass
oakheart replied to Richard Braithwaite's topic in Metal Work, Soldering and Metal Fittings
There is a brass ( sort of ) coloured silver solder in UK I can't remember where I got it so you will have to google for it Tim -
Really nice work BE, you really do inspire me, I think I need to add this detail to my cutters boat. Tim
- 332 replies
- Harpy
- Vanguard Models
So I measured the angle on Bills drawing and as far as I can tell its the same as the RMG drawing. That's assuming LWL means the water level. Here is my stand with a 10mm spacer that brings it up to the correct angle, I think this looks too steep. Probably half that would do it, I love tinkering until it looks right, all part of the build for me. Tim
OK. I have gone for a satin black base. I think this works, some of the contemporary models at RMG have black stands. @Thukydides Thanks for the comment, I have spaced them out further and the model is then not level, is that important? I suppose the mast needs to be vertical, but as its not yet fixed in place, difficult to tell as you say this is all down to a personal choice. Tim
Hi Christopher, my build which was inspired by this build by Thunder and is already nearly two years in the making. I wish I could have thanked Bill in person. It's great to have a relative of his on the forum. Do you make model ships as well? Tim
- 102 replies
- speedy
- model shipwright
Hi @Thukydides thanks for the positive feed back, I would have to agree on the spacing. I will have to do something about the heights of the pedestals to get the model level if I move them wider. On the wood front, I did find a bit of wildly grained parana pine but it looks a bit too goofey. Might even do a painted base. Tim
After remodeling the kitchen over winter now the garden has started up again. I did manage to get a stand made from a bit of mahogany I had, not sure if it works? It's a lot redder in real life. pleased with the brass fittings from Cornwall Model Boats, dulled down as they are bit bright otherwise. Comments please. Tim
Hi Craig Believe it or not, there are crazy peeps who make and fly things just like this from my local airstrip ( Shobdon ) Close up they look like they are made from ali. tent poles and ripstock with a brush cutter engine bolted on. Some even have cabins and windshields. I will stick to making my models 🙂 Tim
I don't know how I missed this build, great work, now I am here, you are inspiring me to get back to my build. Tim
- 1,214 replies
- sloop
- kingfisher
I second that it has to sound right, if I was musical I would give a note to aim for :-), it has to to be a 'ting' not a 'thunk' Also make sure the blade square to the table in all directions. Blade thickness can have an effect too, a thin blade will wander more that a thicker blade. On mine with a very narrow jewellers piercing saw blade I can cut along a printed line and get an accurate shape. with thicker blades cut as close as you feel comfortable with and sand back to the line. You probably know this, don't force the material through let the blade do the work. I have found that as the blade gets blunt it will wander more. When cutting acrylic, put Sellotape along the cut line, it acts as a lubricant. Tim
