Wxchsr
Posts posted by Wxchsr
Still moving along. Had to take the summer off but now that it's turning colder, I'm back in my "office" and back to working on the model. Starboard is done for the time being. Port is planked above the wales. I need to sand that area, plank a row below it, then add and paint the second layer and black strake as I did on the port. I also need to do a little cleanup around the gunport openings where I see the cuts varied a little. Overall very happy with the progress!
- Diver, FrankWouts, Steve20 and 9 others
12
On 2/26/2023 at 10:09 AM, glbarlow said:
So important to get this stage right, looks like you’re doing well on getting it done. Nice work.
Thanks! Going super slow. Still framing and fairing. Rechecking and fairing more
started on the stern frames but really taking time to check things from every possible angle and lighting!
1 hour ago, Chuck said:
Very nice progress...
Thank you Chuck!
- Steve20, Edwardkenway, Chuck and 7 others
10
On 2/23/2023 at 9:27 AM, FrankWouts said:
That looks like a nice relaxed curve with no bumps or weird tensioned humps following your batten. How does it look from bow to stern looking throughone nearly closed eye?
Can you make a picture of that? Does one edge of the batten follow the tick marks exactly and/or is it averaging them?Frank.
Hi frank!
sorry I saw this a day late. I removed the batten yesterday after marking the top. I would say it lines up with most. About one out of every 3-4 would be up to a mm high or low, in which case the new mark is what makes it smooth. Then I did the other side and did my best to make sure it matched. This photo is ugly because I haven’t faired the framing yet (makes some look crooked), but the top, of the bottom row, is where the top of the batten was.
- scrubbyj427, Ryland Craze, Chuck and 4 others
7
On 2/15/2023 at 2:24 PM, Chuck said:
Be careful.....that could be deadly!!!
Totally agree!!
- Edwardkenway, Ryland Craze, James G and 3 others
6
I’ve been really happy with the progress this far and have already learned a ton. I’ve decided to do a partial restart now that I have the equipment to make things better from the start. My former has a slight curve in it along the horizontal axis. much harder to deal with than the vertical axis which the framing would likely take care of. Even with that it has a slight twist, subtle, but now I know I can do better. The knee and keel are good and I should be able to reuse that, so this will only be a week or so delay, I just want it cleaner from the start. Certainly would have come out ahead $ wise just getting the laser cut parts! There always the part of me that wants to do as much as I technically can though, so I’m good with that
Bottom row of port framing is almost done. Had to remove the plywood supports as a couple we apparently slightly to big/small and was knocking it ever so slightly out of square. I spent a lot more time with these ensuring they were evenly spaced and squared. After putting in the last couple I’ll do the final touches on fairing.
- Matt D, Edwardkenway, scrubbyj427 and 1 other
4
Its all in the monograph chapters....just read through it....Carefully.
Thank you Chuck! I'll scan ahead and find that!
I plan on using the monofilament method for the "nails" on the ship. Can anyone advise on the size they used for this specific ship? I see some forum posts here and there (I think Glenn, you used "20 weight for the capstan partners and 15 for the fore and main partners," do you recall what you used/are using on the deck planks and hull planks? I was thinking of using 12# for the deck and 20# for the hull. I'm probably splitting less than hairs here (literally), but am just curious what others used. TIA!
One more gut check after the previous alignment to make myself sleep better. This was low tech but did prove it out. I ran some painters tape over the keel and along the bulkhead, pulled tight so it didn’t touch the whole thing and past the parks for the batten. I then marked on the tape where my marks from the previous step were. After I did this to all of them, I took the tape off one section at a time and folded it in half using the keep mark as the center. The marks from each side all lined up within 1mm, most were exact or +/- 1/2mm. I wouldn’t trust that as the only way to measure as the bulkhead could also be off and give a false match, but in this case I was content. After this I noticed I still have a little fairing to do on the bow that I’ll deal with tomorrow before moving on to the port framing.
- James G, Edwardkenway, Matt D and 2 others
5
Finished most of the fairing. A little fine tuning to do yet at the bow, but wanted to get the battens on so I can mark the sides before framing. Feeling very OCD trying to get this right. Leveled the desk first, then used a few squares were accessible to square the ship to the table. I don’t trust the build board to hold it exactly upright because I can’t verify it with a square. I have the batten where I want it on the right (as you see it here) and will use a speed square to transfer the level of the top of the batten on the right to the left. Left is roughly lined up already using the reference marks, but I want to be certain. Ps the knee looks warped here but it’s an optical illusion:)
- Matt D, Edwardkenway, James G and 4 others
7
Simple trick that’ll maybe help someone. It’s tough to focus on one bulkhead at a time when fairing and trying to make sure both sides are even. I cut a slot in a piece of paper and slid it over the keel between each bulkhead one at a time, starting at the bow and working to the stern. Made it really easy to spot and adjust any differences side to side.
- FrankWouts, Diver, James G and 2 others
5
1 minute ago, glbarlow said:
Much better. You need a long 1/64th batten, gives a better look at the fairing being easy to bend and follow the run. For me the curve between the first and third bullhead was the biggest challenge, why many use balsa filler at the bow to help out with the run of planking.
Good call, I'll make one of those for that purpose. I was pondering the balsa wood there as well just for that reason. Thanks again!
Thanks again for the guidance yesterday! I took more time today and just “went for it.” I was being too hesitant to not remove too much. I took a substitute plank and bent it to roughly match what the real ones will be and layed it across the bulkheads. I think I have this pretty close now, but will do the other side before any finishing touches.
- Vladimir_Wairoa, Steve20, FrankWouts and 1 other
4
It needs to go in much much more, more than your line. A batten should notch into the rabbet and smoothly run through the first three bulkheads and continue on from there. As you can see from the plank you're holding it would never notch into the rabbet as it is. This is the toughest and along with the stern the most critical part of the build at this stage. Look at all the build logs and I think you'll see what I mean.
Thank you Glenn! I'll dig into more of the build logs for some images. I'll get more aggressive and maybe post an "almost final" shape in the next day or so. Take care!
Just looking for a little input on fairing the bow portion. I thought I’d ask before I go too far. I looked at a bunch of other logs and it seems that the planing comes in close to perpendicular than a 45 from the last bulkhead but I can’t really tell from the edge on photos. I’ll took a couple images looking straight down. I know it’s different along the whole edge but that’s the point where I’m wondering about. I darkened the edges in the one photo so it’d be easier to see where I stopped for now. I drew a little bit of a like as a starting point of reference to ask everyone their thoughts on the correct approach to the bow the line isn’t perfect as it’s not a flat surface coming from that bulkhead, does it take a bit of an aggressive turn in for a flatter bow, or, more of a straight in approach with a shorter bend to get to the rabbet? Sorry if I missed an on obvious answer somewhere. Thanks in advance!
- FrankWouts and Edwardkenway
2
- Edwardkenway, FrankWouts, Chuck and 2 others
5
After I had the knee, keel and false keel installed, I wasn’t happy with the knee. I had to alter the bottom too much so it was far smaller than it should have been (over sanded), thus the joint between that and the first keel piece looked ok, but not spec. I also sanded the false keep too thin. It was a good practice run
I removed all three of those components, and luckily the rabbet stayed in place. I spent yesterday and today redoing them and am much happier with the result! I have to slot the knee yet (just have the two holes drilled as end points, but that was no problem last time. Will add tree nails at some point, but I’m not settled on which material I want to use for that yet. Regardless it’s going great! Will be fairing the next several days, so hopefully still going great after that
Thinking I might put in even some temporary bracing to ensure the bulkheads are still true to the former before I start sanding.
- glbarlow, scrubbyj427, FrankWouts and 1 other
4
3 hours ago, glbarlow said:
The stern frames, the port sills, transition from stern post to counter, and the gallery framing are the ones I was most referring to, those are still ahead of you.
Sounds like you're on great track, glad you're enjoying the project from the start. Lots of fun awaits.
AH...Noted. I'm going to go highlight those in the manual before advancing. Not that I don't want to be precise on everything, but some things, as you noted, may be imperative. Thank you for that info!
HMS Winchelsea 1764 by Wxchsr - 1:48
in Member Build logs for the HMS Winchelsea
Thank you Chuck!
