Maciek
Posts posted by Maciek
- Auger, ccoyle, KARAVOKIRIS and 2 others
5
Hi
next step finished, secund planking is ready.
big mistake, i used ca glue sometimes in points just not to hold plank till pva sets an i have some marks :(, I thought it will disappear when varnish will be applied but it's still visible. I don't worry to much, bottom will be painted, upper part partially too, then some addins will cover come of remaining
i didn't have enough of pear wood so bottom is striped
it will be painted, no worry
BONUS:
I have test printed canon for Endeavour
Best regards
Maciek
- vossiewulf, davec, KARAVOKIRIS and 2 others
5
Hi
works slowly progressing. First planking is completed but in this episod i want to show You deck and the way i choose to make tree nails effect.
first, photos of final effect
to achieve this I choose very simple method that could be describe in 3 steps
1. make a hole
2. take a wax for wood repairing
3. scrape excess wax, it comes off very easily
before and after I covered the deck with clear varnish
I know, tree nails should be in wood color but for artistic reasons I chose darker for contrast.
thats all for today, till the next time
- dkuehn and KARAVOKIRIS
2
Hello
time to start build log of the HMB Endeavour by Caldercraft.
I am planning to make her as detailed as I can, using all source of information i can find. For now I have only Anatomy of the Ship that should be good start.
Quality of parts is very good, but blocks i will change for aftermarket one
fit is tight but everything fit perfectly
now time to start planking
Best,
Maciek
- Jim Lad, ccoyle, KARAVOKIRIS and 1 other
4
- Thukydides, VTHokiEE and ccoyle
3
Thank You Allan,
I think You right
When modeling the emblem I took picture from book 'anatomy of the ship - alert' because it was more precise for me to model on it than the one for endavours book. I didn't realise that the small ornament on the left was in fact a number 2. I compared it with drwaings for endavour and this ornament looks like like 3 there. If I decide to print it some changes will be made ;). Thanks!
48 minutes ago, ccoyle said:
Are you talking about the forestays, or the need to run some of the running rigging through the ratlines/shrouds?
I am talking about forestays. As You can see on the picture above, forestay blocks rotation angle of the yard. I think i shoulden't deform forestays by increasind tention on yard. Mayby i need to move yard foreward away from the mast?
Dear All, I need some advice.
I'm at the stage of mounting the yard and sails. I would like to mount squer sails as if they were catching side wind. something like that
but, when i try to position the lowest yard it colides with shrouds.
I couldent find any good picture how it works in real. Any ideas?
Amati didn't provide any gun tackle plans, so I took them form 'Anatomy of the Ship - The Naval Cutter Alert 1777' due to both ship are the same class and period.
On 12/14/2023 at 1:05 PM, allanyed said:used only single blocks, not doubles on both the running out tackle and train tackle.
Maybe it's not clearly visible in previous photos but blocks configuration is single and double.
Thank you! I will remember this for future projects
- catopower, Gregory, Thukydides and 1 other
4
Hello,
it's time to make some sails! Unfortunately I don't have access to sewing machine so my sails are glued.
To imitate seam on sail I followed Olha Batchvarov built relation ( www.youtube.com/watch?v=Pj8D0VNMRAE&t=958s ) that is, pulling the colored thread out of the fabric to achieve result like this
finished sail has doubel seam and glued on reinforcements on ends
two sails installed, and template for third is fitted. A lot of loose line everywhere at this point
Cheers
Maciek
- Mr Whippy, AJohnson, whitejamest and 7 others
10
- AJohnson, GrandpaPhil, Mr Whippy and 1 other
4
Welcome to my first building log!
Over a year ago i started building Lady Nelson from Amati. It is my second attempt to build wooden ship. Bit late but anyway I decided to share building progress with You. Unfortunately I haven't documented early stages of construction. First photos I made below. The hull is ready and painted.
I like detail so first of them that I have made to this stage: rudder
Maciek
- ccoyle, Mr Whippy, GrandpaPhil and 2 others
5
Cześć!
Greetings from my shipyard in Warsaw suburbs. I don't have long history with ship modeling, just one finished during lockdown (Amati Albion), bat with models in general almost all my life (36). So many hours spent on this formu looking for information to make my next built as good and detailed as I am able to. And soon i hope to share results of my work. For now some pictures of my first ship from her better days (before hit by books
HMB Endeavour by Maciek - Caldercraft - 1/64
Hi,
have anyone tried 3d printed pulleys before? I have just testprinted few of main design. I am very happy with results and planning tu use them.
I have tried also other things and have ideas on more
