TJM
Members-
Everything posted by TJM
Log entry 30 Rigging of the bowsprit is now complete: It went well overall, though it is difficult to get to some part of it! How @Thukydides and others manage to make such beautiful knots and splices at this scale is beyond me! Hats off to you! But from a few feet away, I am happy with how my efforts are turning out. Now, on with the yards. BR TJM
- 152 replies
- Flirt
- Vanguard Models
Log entry 29 The cutter is now completed and installed on the deck. I am really happy with the decision to add this, and to me it was definitely worth the time and effort. As you see, Cochrane has also gotten some colours. I am severely out of practice when it comes to miniature painting at this scale. Faces and eyes are never easy at this scale, but I used to be able to do better! 10 years ago... Anyways, he is just there for scale, so this will have to do. Now I can continue with the bowsprit boom and rigging. BR TJM
- 152 replies
- Flirt
- Vanguard Models
Now that changes the looks! Really nice! 👍
- 95 replies
- flirt
- vanguard models
Log entry 28 the cutter is close to completion. I am missing the top bulwark (if that is the correct term....), painting and attaching the rudder and the oars. Cochrane paid a visit to inspect the progress (though he is still in a... pale state himself!). It is not perfect and the macro shots are harsh on it! From a reasonable viewing distance, I think it looks ok. It will make for a great upgrade to the deck of Flirt, for sure! BR TJM
- 152 replies
- Flirt
- Vanguard Models
Log entry 27 Just a small update on the cutter. The outside has been sanded an the temporary bulkheads removed without issues, much to my relief! Now to decide how much cleaning on the inside to do. It is very difficult to sand properly and the material is very thin already... TJM
- 152 replies
- Flirt
- Vanguard Models
For what it is worth, I think it looks great! 👍
- 422 replies
- Vanguard Models
- Sphinx
Log entry 26 I have continued to work on the 18 foot cutter. Bending an fitting the tiny planks proved to be easier than I expected! Here are some pictures of the finished hull before sanding: I am quite happy with how it looks so far and with a little more taper of the first 3-4 planks it would have been possible to avoid using stealers altogether. I managed with just two. The plan is to paint the hull below the waterline as per the instructions, so it matters little anyway. This is a really nice little mini project within the bigger build! BR TJM
- 152 replies
- Flirt
- Vanguard Models
Well done! You are overtaking me now 😅! I think your ratlines look fine, btw. BR TJM
- 95 replies
- flirt
- vanguard models
Log entry 25 All the ratlines are now done! Progress has been slow, as I have not had many sessions in the workshop lately - I was away during Easter. I am a bit relieved that this part of the build is done. On one hand, I find that I don't mind doing the ratlines while I do them, but it does take a very long time and it feels like not much overall progress i made while working on them I had thought to continue with the yards, but as you may have spotted, I have ordered and received the 18 foot cutter from Vanguard Models. So now I will take a quick detour with that for a while! The first few planks are on already. BR TJM
- 152 replies
- Flirt
- Vanguard Models
Absolutely fantastic! Your work is a huge inspiration! TJM
- 648 replies
- Indefatigable
- Vanguard Models
Log entry 24 All of the lower ratlines have been completed! Not much else to say - on with the top ones! BR TJM
- 152 replies
- Flirt
- Vanguard Models
Great, thanks! Both to @allanyed and @Thukydides!
- 152 replies
- Flirt
- Vanguard Models
Hi Allan, Thank you for your comment! Do I understand correctly that the one hole in the blocks should be closest to where the block is attached? So that when the line runs down, it would appear to go over the (imaginary) sheave inside the block?
- 152 replies
- Flirt
- Vanguard Models
Log entry 23 I have now completed all the mast shrouds - milestone reached! I estimate that I need another 4-5 evening sessions to do the remaining ratlines. But after that I get to continue with the yards! The topgallant shrouds visually adds some much needed bulk to the top of the model, so I was very pleased with the improved look after yesterdays work! BR TJM
- 152 replies
- Flirt
- Vanguard Models
Log entry 23 I am still here! I have just had very few days where I have been able to get any work done in the workshop. I have completed the ratlines on lower main mast shrouds and sre working on the upper mizzen shrouds. My plan is to complete all shrouds and ratlines and then do the yards before continuing with the stays. BR TJM
- 152 replies
- Flirt
- Vanguard Models
I found this hard as well! So many, so small, so much re-touching! And in the end , I could not for the life of me get the thick ropes for the guns through eyes and will have to live without them on my model 🙄. I think it could be done by attaching the ropes before fixing the eyebolts to the bulwark, but I did not have the heart to rip them out and re-do it all.... I have seen many people make it work, but my fingers did not cooperate and after 2 hours of struggling on one cannon, I gave up. Next time!
- 95 replies
- flirt
- vanguard models
Log entry 22 A bit of progress. I have completed the lower shrouds and spent a couple of evenings with the futtock staves and shrouds. Up close, it is not the neatest work - I find it quite difficult to deal with the thin thread! From a little distance, it looks alright to me. The manual says to wait with the backstays until the yards are fitted, but I had a slight tilt to one side from the topgallant and up on the main mast, so I wanted to temporarily attach the backstays to correct this while I work on the topgallant shrouds. If I can work around them, I will leave them in place and otherwise it is not very much work to detach them and re-do the two lanyards. BR TJM
- 152 replies
- Flirt
- Vanguard Models
HMS Flirt by ECK - Vanguard Models - 1:64
TJM replied to ECK's topic in - Kit build logs for subjects built from 1751 - 1800
You are progressing unbelievably fast! Looking great as well!! -
Log entry 21 This is just a small update, as I continue to affix the shrouds. Not that much has happened, but mostly due to me being away all of last week so the progress only reflects a couple of evenings work. When I took the pictures, I had not noticed that Cochrane were lying at the back - guess he had a tad to much from a certain barrel... But it is very satisfying to see the shrouds I have completed on the model. I think it really moves the visual impression up another level. TJM
- 152 replies
- Flirt
- Vanguard Models
Thank you for the comments and the answers to my question! @Thukydides, what a great resource! At first I could not make sense of your numbers, until I realised that the 5in and 1in were circumferences! That will indeed give only around 8 mm i diameter, which is really quite thin! It also fits well with @chris watton's comment that the actual thread size is slightly larger than 0.1 mm. I was never actually in doubt that the kit is correctly designed, I just couldn't understand how thin these ratlines were - it is so great to have the creator of the kit explain, so thank you for that. And thanks @glbarlow, it is clear that 0.1 mm is good fit, it is just much thinner than I thought (based on no experience 😅). And I totally agree, the time spent matters not at all, as long as it is fun time - and it is! I just can't help gathering this kind of data for my own amusement and though perhaps other newcomers to the hobby might be interested. I don't think I shall keep this kind of track on hours spent on future projects. TJM
- 152 replies
- Flirt
- Vanguard Models
