Scottish Guy
Everything posted by Scottish Guy
  1. Get you there and a ken, but unfortunately we did the opposite way, we moved into a 3 bedroom bungalow with garage (my wife is disabled and can´t use steps anymore) so it`s hard to stop collecting LEGO lol, she even supports me in it. I buy them and fix them / restore them, all my cameras are working or were working once (have not the time to check on them regulary) but some of the older ones I use frequently. For daily use I have a Canon EOS 70D, a 5D Mark III and a Canon EOS 3 SLR and a PowerShot G7X Mark III for video (YouTube).
  2. Hi Glen, that would explain a lot lol, not sure but I think I found this article too, but it looked a bit "dodgy" in my opinion. I was even looking if there is any chance that the name was different, but there are not many 3 mast schooners at all around that time leaving The Isle of Wight in 1822. There have been some ships around 1820 to 1823 but not many three mast schooner and definitely none with the Name "Jenny". The funny fact is, even the whaler "Hope" brings only very strange results. There was a Scottish Whaler which left Peterhead in 1802 sailing to the Greenland but never had a Captain with the name "Brighton". The "Hope" was lost in 1830 in the Davis Strait (roughly 8,900 miles away from the Drake Passage) beside 17 other fishing vessels in this area. Funnily 1823 another 14 vessels were lost around Greenland. So with all that uncertainty I could chose somehow any three mast schooner to "create" my own "Jenny"? Not sure if there are any wooden models out there or plans for a three-mast schooner. The only one that comes in mind is the "Atlantic" and maybe the Virginia (which I don´t like because of the canon).
  3. Tell me, I have tons of LEGO in the house as well, was thinking (dreaming) of building Stormwind (World of Warcraft) of LEGO, but I realised that this might need 200 times more LEGO as I own right now... but still tons of LEGO here and won´t sell it, even if the prices are increasing (I´m a bit of a vintage collector with old Commodore C64s, Amiga and Atari computers, cameras from 1872 till nowadays and such stuff - my wife gave up to kill me lol)... Micha
  4. Now then you have to tell me the brand because mine don´t have an RFID built in ^^ Gladly building a boat doesn´t just take a week or it could become an expensive thingy ^^
  5. May I ask where you found the plans / patterns for the boat? I tried to find something about it, except the funny small notation on Google and Wikipedia I can´t really find anything about that ship. Tried to find it in a register of all built ships around that year but still nothing. Sounds like a really good story for a scaled diarama (maybe not that small but a bit bigger ^^ Micha
  6. These broken drill bits can be a pain, wish they would find something that would solve this issue. I try most times to use my Dremel Workstation to do really small drills. Unfortunately not always possible... Micha
  7. The wheel on top is running in a bearing and cna even be exchanged to change the force onto the flat top or ball on the bottom part. The size of the wheel somehow specifies the curve diameter you try to archive (that is why I stated you need training and experience - to know which wheel used for what archivement). It might be a one time job and even for USD 200.00 I´m pretty sure the size of even the benchtop English Wheels is not worth it. The storage of the device is quiet space intense. Also even USD 200.00 for a one time job is quiet expensive. If you doubt you can do it with a ball / flat top anvil then try to find a metal worker near you that might do the job for some small money (we have here a garage that has done a bigger job for me for GBP 20.00 to the coffee jar). I personally would advise to try first the anvil / hammer method, this is for small parts the way to go though, except you do such jobs every week and maybe even in bigger scales. If you would work on parts bigger than 2ft (60 cm) then the benchtop device would be advised because that can become quiet hard to handle manually by using en anvil and hammer and holding the part to work on all at the same time, but as long as the benchtop devise is not pneumatic powered it also needs some talent to work it with only two hands. The English Wheel we had during apprenticeship was a pneumatic machine, so you have a foot switch to start the hammering, which gives you both hands to handle the part. Micha
  8. Like the way to prepare for the build Micha
  9. That´s the way to go my friend Greetings from the North (East Coast) to the East Coast
  10. Same here in good old Scotland ^^ but what are you doing with the Branston Pickles? Hopefully eating Micha
  11. I use a mini bench clamp vice and put my dowel / mast in there (to have it nicely fixed and not rolling when sanding) and then use a file or sanding block (often on blocks to keep a steady height). Then I turn the dowel / mast by 90 degress and go on with the same procedure. The benchtop clamp vice was (years ago) a tenner... so not breaking the bank but a nice helper for sure. Micha
  12. That should also work well Frank. Micha
  13. Tbh, I did this in the past (don´t build plastic models anymore even if there are still some Star Trek models unbuild in my shelf) but it works fine when the gap is not more than 1-2 mm (pls don´t ask me about inch ), then some good superglue will do the job. If the gap is up to 3-4 mm I used plastic cut offs (the little stuff that comes of when clipping of edges and cleaning the cut outs) or I used some cling foil to strengthen the glue. But be aware that it can become a pain in the butt to sand the glue off, it often ruins your soft files (the nailing fails for women) and also your normal files, so you have to clean them after the use. You can find plastic sheets of 1 mm on Amazon or use the punch pockets from Amazon which come in different thickness (here 30 microns) but I know you get them also in 50-80 microns (more expensive). Micha
  14. When you check out the link to the book it states "C.S.S. Alabama" on the book. I think the guy that sells / sold it just misspelled it in the description. There is no reference or detail found about a C.M.S. Alabama, only about the C.S.S. Alabama. Funnily even to see in the auction itself I don´t even know any reference about American ships with the CMS. AT this time there were only three prefixes known USS - United States Ship (for commissioned ships of the "United States") CSS - Confederate States Ship (for commissioned ships of the Confederate States / Southern States) MCS - Military Sealift Command (civilian manned ship "in service" and not in "commission") That´s all I could find and please, I´m not a historian or American, so this statemaents are made in the belief that all might be historical correct but it is not my onw knowledge but what information I found online. Micha
  15. Welcome to MSW @Diddlysquat, hope you find the answers you are looking for and learn the tricks of the trade you still need or want. Micha
  16. When I chose this one, they only charge EUR 9.00 for shipping (which I doubt when I enter a UK address) and there is no customs fee included yet. But I´m considering it since form the US they don´t send it to me or with double the price of the book (also customs fees not included yet).
  17. Indeed it is available in the US but still not available for me lol It seems sometimes a bit odd that in a "global" world there are still restrictions, despite the cost of postage and customs, to send items around the world. I found this many times with US items but since Brexit more and more often also with European items. I also collect model cars / diecast models (especially Ford CVN in various police versions) but nowadays (since the 2000s most US shops don´t send them over anymore - before that they often sent them even for really low prices but postage took up to 6 weeks). So far about "global" world, we are growing closer...
  18. I know and I like to remember the old times (not only because of shipping costs - a lot of things have been more nice in the past but that is another topic) but I agree, since everything is via air freight the costs increased dramatically. I agree again, another bad thing that happened is Brexit which makes for us now the prices for items from Europe as well expensive since we are no longer part of the EU. On top there is the tax and customs fees. That might be indeed a possibility I have to sound out since a German friend of mine is visiting me in July, he has to travel via France, but maybe the book is even available in Germany and he could just bring it over
  19. I know of the difference, unfortunately the search in the UK Amazon doesn´t bring up any results for the name of the author "Bernard Frohlich" nor under the name "Bernard Fröhlich". When I put in the name of the book I only get the result that it "currently is unavailable".
  20. Hi @Bob Cleek, you see me a bit confused. I only can see the quote of my own posting but not your comment?
  21. Unfortunately no version of the book available in the UK. All I found are in the USA and the postage is ridiculous high, some are more than the book itself, so useless. I don´t pay USD 37.00 and then another USD 50.00 to get it to the UK and when the seller forgets about tax papers and custom papers I pay another load on top of that (had this experience with something from Germany where I paid almost three times the price of the item itself) No version available here in the UK, not on Amazon nor on eBay
  22. Unfortunately "currently not available" here in the UK but the expected price of GBP 99 I think is also a bit... overpriced. I always thought there is a pricebinding to books, at least in Europe it should be...
  23. Hi Todd, then we are somehow on the same route. For my scratch model I only would use fiberglass because the origin is made of fiberglass and I want it as authentic as possible and I maybe will do more than one copy of it (depending on the outcome - how accurate and authentic the model becomes). Micha
  24. I get where you are going, but do you not think this is wasted time and material? I can smoothen wood the same way as I could do fibreglass, just with a lot less work and effort. Especially when using putty which would be the same as using putty in the first place with the wood? Micha
