Everything posted by SaltyScot
A sight to behold for sure. Very nice work, Glen.
- 301 replies
- Constitution
- Bluejacket Shipcrafters
To be honest, Trevor, those floor planks look quite good. They look natural in a haphazard, random kind of way. I guess the look you were going for was nice and neat with straight lines?
- 167 replies
- Norwegian Sailing Pram
- Model Shipways
What a rewarding project. It helps enormously when the standard of the part is as good as this is. It looks good, Phil.
- 433 replies
- minesweeper
- Cape
For some reason I cannot explain, I prefer the run-in option too. Cleaner, unbroken line of sight along the outside of the hull maybe. It just feels kinda right 🤔
- 332 replies
- Harpy
- Vanguard Models
Good call, Glenn. It wasn't worth pounding through a frustrating situation like that where there was no solution in sight.
- 241 replies
- Vanguarrd Models
- Harpy
Yes, I like that natural look as well, Trevor. As you know, the first coat of any oil on "new wood" does tend to soak in quite quickly and not really give a true example of the final look. Once this dries completely you will have a better idea as to the necessity of adding another coat or not. She looks good on that stand too.
- 167 replies
- Model Shipways
BR-18 Locomotive by Greg Davis - OcCre - 1/32
SaltyScot replied to Greg Davis's topic in Non-ship/categorised builds
The measurements are so precise, Greg, and (so far) everything seems to fit very nicely. This is a nice kit! -
That just looks so very nice, Trevor. Nice job on those thwarts (I thought they were called seats......... 😉)
- 167 replies
- Model Shipways
Hi Folks, here is my latest update on the current build. As a side note, the sale of my mother-in-law's house is eating up a lot of our time right now, despite being ready to go on the market we always seem to have stuff still to do, hence my absence here and there (sometimes unexpectedly). I decided to remake the rudder out of solid wood. I didn't really trust the brittle plywood to accept the nails I will be putting into it later on when the rudder gets mounted. I made it out of a nice piece of acacia wood that I had left over from a butcher block counter top we installed a few months ago: I started work on the sheer strakes too. The tricky thing with this build is that the bulkhead "tips" will be cut off flush with the deck once the planking is complete. Because of this, I didn't want to glue the sheer strakes in place right away. I planned on putting the first 4 rows on and securing them with nails then, once the planks got below deck level, I would start gluing them on. The strakes above would be removed and then glued down onto the fixed ones below deck level, if that makes any sense. It was really the only way I know how to get them secure and in the right place: The plank bending iron worked like a charm. I used it to shape the end of the first glued plank so that it would fit nicely in the rabbet: I had to add temporary bracers across the first two bulkheads because (as I mentioned earlier) the plywood is not of the best quality and they were suffering when I knocked the support nails in, despite me holding them: I hope to make more progress tomorrow
- 257 replies
Yes, I was going to make a similar suggestion, Glenn, wipe the backs with an alcohol solvent. I wouldn't put WOP on there either, but that is just my preference, not based on any experience.
- 241 replies
- Vanguarrd Models
- Harpy
Tag, Wolle. You were right when you said it was a fiddly job! It is looking good though.
- 35 replies
- Britannia
- Mountfleet Models
Thanks! Those CAD skills will be put to good use on my Endurance build. I intend to enhance the model with some 3D designed and printed parts (I have some wood PLA here at home for the purpose).
I find it quite frustrating trying to hold mini pieces like that securely enough to be able to sand them properly. You had several to do I see, a true test of patience, Trevor. I don't think it turned out all that bad, it looks nice and neat to me.
- 167 replies
- Model Shipways
Thank you, John. I am very pleased with how she turned out. I have friends in Germany who I sent pics to who want me to make a full size one now..... 🤭
Steve, I had actually made a different stand but was not happy with it because it was too short. This one does have a certain dynamic about it, doesn't it. Thank you for your comments sir, they are truly appreciated.
That is a nice "tutorial" on how it should be done there, Glen. Thank you, sir.
- 301 replies
- Constitution
