Jim Lad
Moderators
Posts posted by Jim Lad
  1. Remco,
    There's certainly no doubt about the two labels 'Galley' and 'Chimney', so that would seem clear.
    I can't quite make out the writing on the other opening, but it does look rather like a coaming.
    I've tried to enhance the contrast two of your pictures but I still can't make out the writing - perhaps you'll have better luck.
    John
  2. Bugger!!! :angry:   I'm such a genius of a model maker that I only need to mark one face of my frames on my plan; so naturally when I marked out the forward cant frames I measured from the wrong side of the frame and the rabbets I cut were all 1/8" too far aft, so I've had to re-do them and the rabbets are now twice as wide as they should be.  The mistake will be hidden once the model is planked, and all I have to do is to make sure the cant frames are hard against the forward edge of the rabbets when I fit them, but it's still really annoying!!!
    Here are my extra wide cant frame rabbets (just don't tell anyone I'm such a muppet!)
    At least I've got some more frame blanks cut out.  Very soon I'm going to have to make up a framing jig and start cutting out and fitting frames.
    The frame blanks that I've made so far.
    John
  3. There are no rules laid down for the width or length of hull planks on British merchant ships - only the thickness and the spacing of the plank butts.  In practice, a plank width averaging about 8 inches would be OK - this would be about 4mm at your scale.  Remember that the planks on a ship are not parallel sided, but vary considerably with the shape of the hull.  The widest planks will normally be found at the stern and the narrowest at the bow.  With an average 4mm wide plank you should aim for no more than about 6mm for the widest planking and narrowing to no less than about 2mm.  The average plank length would be no more than 25 to 30 feet in real practice, which would equate to roughly 150 to 180 mm on you model.  When planking the 'shift of butts', you should try and plan for a minimum plank length of about 6 feet, or about 36mm on the model.
    John
