Everything posted by Craigie65
I think you are secretly holding out for the Indy 😉 I will pull up the proverbial chair and follow along.
- 15 replies
- Lady Eleanor
- Vanguard Models
Not sure how I missed this log, following now. Very neat indeed. That’s the hard part over, the rest is pretty straight forward.
- 88 replies
- Erycina
- Vanguard Models
Well done! What’s next - a three master with all those lovely ratlines? 😀
- 38 replies
- Nisha
- Vanguard Models
The plain seizing looks fine. I tie the top of the shrouds off the model using a piece of appropriately sized dowel. You need to play around a bit with the build sequence but it works for me. Ratlines will be done in no time, only three knots per ratline😎; compared to a three mast-er an absolute doddle. You will have your Nisha launched in two shakes.
- 38 replies
- Nisha
- Vanguard Models
Andy, I am catching up on your build. You have done a grand job!
- 32 replies
- Nisha
- Vanguard Models
Ouch, but you are not alone. I know I have had problems with decal when going to far. Sometime it is difficult to know when to stop playing with them, until it is too late. Fingers crossed the dry transfers fix you problem Sewing sails sounds too hard! I think I will stick to the pre made beauties from Mr Watton.
- 38 replies
- Nisha
- Vanguard Models
Thank you for the continued support. Fit out of the deck in now well under way. The gypsy and main winches are now in place with both hatches fitted. I decided to continue with the dark colour scheme, it contrasts well with the lighter deck. The windlasses are dark green to match the bulwarks. I am guessing that gloss paint would have been standard, however I much prefer flat colours. Looks as if the winches are misaligned but they look fine when I look straight on from the bows - think it must be the angle of from which the picture is taken. Nearly snapped the fair leading post with too much pressure in trying to get it seated properly. Just got away with it! I tried to add a bit of depth to the grab ropes on the hatches rather than flat to the hatch. The deck house, steam winch and various other bits of deck furniture have been sprayed with first coat, or primed if metal. So while the paint dries I can update the log. Thank goodness for the spare door hinges in the kit. Cut out 4 pieces and place them on the pear sheet that contains the deck house doors. Glued the first hinge on, then stupidly lifted the sheet to turn it round and tipped the three other hinges on the floor. Luckily the carpet monster only ate one of the three, as when I went to lift up a replacement it pinged off into the ether!
Lovely photos. Briefly thought of converting Erycina but chickened out. Also did not like the colour scheme, its a bit garish. I think I took some pictures of her or Pilgrim around a decade ago when holidaying in Torquay. We need to try and find them
- 62 replies
- Nisha
- Vanguard Models
Hi Glomar, Really good to see you are still progressing. I like the paint scheme. I have never used Plastcote - although I have seen a few rants about it! I think it is just the black that needs touched up, the bit at the waterline looks to be in the black section. If you hand brush you will see there is a difference. My instinct would be to re tape and spray the black , but it is your call. Don’t forget the bowsprit hole😉 looking forward to seeing the next pics.
A good weekend for progress on Erycina. Timber heads, capping rails and wales all added. Paint work needs a bit of a touch up, especially at the rear below the wales where I have green showing. But that is for another day. Had to do a bit of surgery on the rear capping rails to get the transom rail to sit well. Of course this was after I had painted and glued it in position. However it was relatively straight forward, although I may fettle the rear a little. We will see. Some shots of work done
Time to get the timber heads done. After much procrastination I decided to paint them in green to match the bulwark. I held each part in a clip to sand the char and gate. Couple of swift passes and each is done. A bit tedious but a chance to zone out with some music. Could not find any double sided tape in the house so used masking tape to hold the pieces for spraying. Need to remember not to cover the letters or I will never remember the order!
I think they will be a nice contrast to the dark hull, Jonathan. Looking forward to seeing this one completed.
- 38 replies
- Nisha
- Vanguard Models
Looking good Jonathan! What colour are you doing the capping rail? looks as if you will have this all done before the summer.
- 38 replies
- Nisha
- Vanguard Models
A bit more progress with the colour scheme added. I used Vallejo paints, sprayed on with my airbrush. I wanted a very dark overall scheme, so the green I plumped for is German Cam. Dark Green. The black is well black. The red is Vallejo’s Mecha Range dark red with a few drops of cavalry brown. Decided to paint the inner bulwark green and now need to decide if the timber heads will be black, green or left in natural wood. The capping rails will be black so that might make the choice of colour for the timber heads for me.
Thank you for all the encouragement and likes. Dan, I have never seen that photo before. Amazing how cluttered the deck looks. I might be tempted to add the navigation lights to the shrouds. As to weathering that is way beyond my skill levels. I truly admire the artistic talent that can pull this off.
Beautiful build Dan. You should be very proud of her! Like the alternative rigging. I am guessing Chris simplified it for beginners. Looking forward to seeing your build of Erycina.
- 62 replies
- Nisha
- Vanguard Models
Jonathan, I think you have it right there. I played about with the build sequence to get a decent fit at the stern. As you say how do you know how much to sand by to get a decent fit. From memory I was seeing how the frame fitted against the counter before fitting the final engraved counter. I was worried the counter would be too far forward and create a gap or too far back and need a lot of sanding. I had a lot of sanding on the top of stern to get a flat fit to the frame. Even then I ended up with a gap.
- 38 replies
- Nisha
- Vanguard Models
