Craigie65
Everything posted by Craigie65
  1. Lovely! Well done for persevering and overcoming the challenges you faced. I will follow along on your Speedy build.
  2. Wow, you certainly churn these out. The finished product always looks first class. You need to share your secret!
  3. Good progress Robin. Ratlines are time consuming. Watered down PVA glue is fine for securing the ratlines. I like to get them all square and evenly spaced before committing to glue. Just protect your deck from any splashes!
  4. Your approach to the tuck worked well. Looks good with a coat of varnish.👍
  5. Sorry to hear about your broken fingers, hope you are on the mend. You are on the right track using an electric drill/screwdriver to help shape the yards. Just take your time avoiding putting too much pressure on the yard arm nearest the screwdriver chuck. Once you get the taper close to where you want it, just proceed by hand using sandpaper.
  6. Andrew, Sorry to hear about your health, hope you are on the mend. Please take care of yourself. I am sure the warmer weather is just around the corner, and you will be back in your shipyard soon. 😁
  7. Really taking shape now, Robin. We have all been there with snapped drill bits. It’s fun digging them out 😡 The fine bits cannot take a lot of lateral pressure. Apparently HSS bits are stronger than the tungsten carbide ones, although the former are more expensive. You should be able to source suitably sized walnut dowel to replace the stock you used on the pumps.In the UK Cornwall Model Boat stocks various sizes. I am sure you will find somewhere closer to home.
  8. Glenn, Ouch!! Paul’s tubing idea made me think that you could “fish” the mast and call it a battle damage repair!
  9. Excellent job on the second planking, nice symmetry to your work.
  10. Andrew, Learning a lot from your build. Those really are mighty tight curves, hope you have enough spare planks to complete. Would be a shame to hide the excellent job you have done with the planking under a coat of paint.
  11. Thanks Andrew, Anything that makes planking easier is an asset! I am a bit of a sucker for tools, sometime I forget it is the model that is more important. If you are anything like me you will have a drawer (or 2) of little/unused tools.
  12. Looking good Andrew. Interested in your use of the proportional dividers. How well do the proportional dividers handle the curve of the hull? Or can you only use them on relatively flat areas?
  13. Hi Robin, Sorry I have not looked in for a while, life eh? You are making great progress, you should find the rest of the build straight forward. I am sure you will have learned a lot from persevering with this build. Looking forward to the next update?
  14. Andrew, What a good job you have done on the first planking, as Ronald has pointed out those are pretty tight curves! Will you use CA for the second planking?
  15. Might be known as methylated spirits, or even just meths. Hardware stores and even amazon will sell it. I use isopropyl alcohol rubbing alcohol. It works well on PVA but can strip acrylic paint!
  16. Hi Robin, I think you have a bit more sanding to do, fun eh? Run your finger down the hull, if it feels a bump, catch or a depression you need to fix it, otherwise the second planking will show every imperfection.
  17. Robin, I would not use pins for the second planking if at all possible. You don’t want pin holes to fill! Sorry should have said earlier. Some use thick CA for the second planking, but I find it too unforgiving! I use Titebond PVA and a bit of patience👨🏼‍🦳
  18. Hey Robin, That is great progress! Sanding and filling will get you a good base for the second planking. The pear planks are slightly thinner and I found these a bit easier to work with. As you say most of it will be under a coat of paint but still good practice! It is a great feeling to finish the hull and start kiting her out. For the nails have you thought about a pin pusher? Vanguard sells this one.
  19. Depends if biggest means heaviest or the longest. The Iowa class is lighter but longer than the Yamato class😉
