kenr
Members-
Everything posted by kenr
Hi Brian The plan just says " light green " ?? Regards Ken
- 287 replies
- niagara
- Model Shipways
Brett Jotika/Caldercraft plans/instructions are probably as good as you can get For one thing they are originally written in English, not translated Ken
Hi Brett I like a lot of others are building the Niagara from Model Expo Whatever you decide you will need to order from the US or UK which works when you pay by credit card The Niagara requires more carpentry than some Here is some strip wood go build it !! Also the plans are in imperial measurements I tend to use a scale rule and measure off the plan The Caldercraft Endeavour is another good choice I don't think you need to buy practicums The 2 models I mentioned come with good instructions. But your best option is to start a build log and tap into the experience and skills here Good luck with it Regards Ken
Hi Laxet Re the " other end " of the anchor rope I ran them along the outside of the hull to the hawse pipe holes Then in through them and at present have them running down the deck Regards Ken
- 468 replies
- niagara
- model shipways
plywood bulwarks
kenr replied to djs's topic in Building, Framing, Planking and plating a ships hull and deck
Hi Dennis I don't know whether twisting and bending bulwarks is a good idea Can you cut slots into your deck to accommodate them Some pictures would be helpfull Regards Ken -
Saettia Genoese by maurino
kenr replied to maurino's topic in - Subjects built Up to and including 1500 AD
i Mauro I am sure there are maritime museums in Genova But there is a small museum in Camogli which has models and documents which may be of help to you Regards Ken -
Hi Laxet I installed the spanker sheet horse I used a piece of shaped wire Checking my old damaged Niagara I can see it is used for attaching rigging Regards Ken
- 468 replies
- niagara
- model shipways
Hi Laxet Nice work You saved me I was going to install the anchor chafing blocks on the outside of the hull Regards Ken
- 468 replies
- niagara
- model shipways
Hi Laxet Are you going to paint the masts cheeks and tops? Regards Ken
- 468 replies
- niagara
- model shipways
Hi Laxet I may have missed the reason earlier in your log but why make all the cleats. The kit comes with 40 white metal cleats No sheaves that I can see but certainly cleats Regards ken
- 468 replies
- niagara
- model shipways
Laxet I have the benefit of an older damaged Niagara to refer back to I attached the jibboom outhaul tackle to one of the belaying pins on the bow pin rail Regards Ken
- 468 replies
- niagara
- model shipways
Hi Vossy Have a look at Caldercraft / Victory models Regards Ken
Hi Laxet I run black line through my forefinger and thumb nail That seems to take some of the extra curl and kinks out of the line Regards Ken
- 468 replies
- niagara
- model shipways
Hi Laxet I wondered why my bilge pump and bell tower looked much bigger than the rest of the fittings All the fitting drawings are at 1 to 1 EXCEPT the bilge pump and bell tower which are at 3/8 to the inch So I had to go back and completely rebuild Another trap for beginners !! Regards Ken
- 468 replies
- niagara
- model shipways
Hi Laxet Nice work I am not that far behind you so this will be useful Regards Ken
- 468 replies
- niagara
- model shipways
Tony and Richard Would you at least sand the laser burn off before fitting ? Regards Ken
- 20 replies
- gorch fock
- mantua
