Everything posted by pirozzi
The fore topmast stay rigged in place. I made some little rope coils for where it belays to the bowsprit. I took some suggestions from modelers of this forum for making the coils and they came out great. I never had much luck with them before. I mixed some wood glue and water to make it real thin. Then wound the coils on a tapered wood dowel, soaked them in the glue, peeled them off the dowel and let them dry. I put a weight on top of them to keep them flat . Perfect. Vince P.
- 264 replies
- sovereign of the seas
- mantua
Hi Denis, This is e test message. Vince
- 555 replies
- mantua
I have started with the standing rigging. The lower forestays for the foremast and a hand rope along the bowsprit. The heavy rope for the stays only comes in tan, so I colored it using black beeswax. That great idea came from my fellow modeller Denis Pink from New Zealand. Vince P.
- 264 replies
- mantua
The foremast is set on the ship. Now the fun part comes with the standing and running rigging for the mast and bowsprit. Vince P.
- 264 replies
- mantua
Hi David. Thanks. She will be about 40 inches high. It is going to so big, I will have to come up with someplace to put her. The glass case I bought is big enough to sleep in. Vince
- 264 replies
- mantua
- 264 replies
- mantua
Completing the blocks and lashings on the bowsprit prior to starting the standing rigging and placing the foremast. There is quite a bit of rigging in this area and it will get congested, so I will have to figure out just what order to do each line in order to make access easier. Vince P.
- 264 replies
- mantua
Hi Frank, Putting a small metal pin in the center of the yard and drilling a hole in the mast or bowsprit is the way to go. It makes it simple to hold it in place so you can lash it. Vince P.
- 389 replies
- supply
- caldercraft
The fore royal yard mounted and rigged. After hanging and rigging the sail, comes a big part of the build. The mast will be set on the ship and all of the standing rigging for it and the bowsprit will be completed. Vince P.
- 264 replies
- mantua
Hi Ed, I used CA glue. The middle thickness works best. One thing, since most of the ornaments are placed on painted surfaces, make sure to scratch off a little paint where the contact with the glue will be made. I had a little trouble with them staying on until I figured this out. Good luck on your build. Let me know how it goes. It is definately a fun project. Vince P.
- 264 replies
- mantua
Fore topgallant sail set and rigged. As you can see, the amount of rigging lines going down to the deck is getting impressive and I have not even set the royal yet. It is a good thing I inceased the amount of belaying pins and cleets from what the kit recommended. There is no way there would have been enough and I may even get close anyway. Vince
- 264 replies
- mantua
I actually tried to bend them too by hammering them. They are too thick. I finnaly just put them in without bending them at all and they look OK as is. Vince P.
- 264 replies
- mantua
Hi Denis, I sure does look like it shrunk some. That is why I was afraid to soak mine. The color is nice but shrinking might be an issue when hanging them. Vince P.
- 555 replies
- mantua
Probably so. I guess that is why they added them later on. I certainly wouldn't go out on those yards, especially in heavy seas. Vince P.
- 264 replies
- mantua
Fore top gallant yard in place. Still have to lash it to mast and then hang sail. According to the rigging manual, there were no foot ropes on these upper yards. Vince P.
- 264 replies
- mantua
Hi Tim, I found using colored bees wax works best. You should wax the lines anyway. I found both brown and black bees wax. Just run your rope through the wax until you like the color. It works very well. Vince P.
What is the best order of adding sails and spars???
pirozzi replied to Modeler12's topic in Masting, rigging and sails
I find it easier to place the yards on the masts before setting the mast on the ship. Add all of the blocks and footropes etc. first before attaching to mast. One the yard is set on the mast, then hang the sail and add the running rigging. If you place the sail before adding the yard to the mast, it puts more weight to the yard and makes it harder to secure it to the yard. Vince P. -
Question about 17th century spritsail topmast
pirozzi replied to Ilhan Gokcay's topic in Masting, rigging and sails
You are correct. Jibs and Staysails came after the Spritsail era. Vince P. -
Hi Gary, The sails are the kit I bought from Mantua. I am using the book by R. C. Anderson for the rigging. The SOS was built around 1637 and modified and redesigned several times after that. It mentions using footropes on the lower and top masts. There are some great websites with photos of completed models. I am taking some info from them as well. Thanks, Vince
- 264 replies
- mantua
Fore topsail with running rigging at the sail completed. ** OK, my build log is up to date again. The postings will come slower now because I have to do some building between posts. Vince P.
- 264 replies
- mantua
- 264 replies
- mantua
- 264 replies
- mantua
- 264 replies
- mantua
Hi Gary, I have several books, but rely on two mostly. "Anatomy of Nelson's ships" which has much info on English ships in general, and "The Rigging of Ships in the Days of the Spritsail Topmast, 1600-1720" by R.C. Anderson. This book has all you will ever need to rig a ship in the pewriod of the SOS. It even makes reference to the actual SOS itself. I am using this for the main references for making the rigging as complete and accurate as possible. Vince P.
- 264 replies
- mantua
