Wintergreen
Everything posted by Wintergreen
  1. I agree @wefalck, if you haven't already, look up the Tally Ho rebuild on youtube. The documentation is superb and I was especially impressed when one of the shipwrights drilled holes for the fastenings for the chainplates. All holes were at different angles and he managed to hit spot on every time. I learned from a fellow of mine, his job is to drill in concrete, that using drill bits (or augers) with four flanges(?) makes for straighter holes. Which confirms your thesis also.
  2. That's a quote from the Swedish alpin legendar Ingemar Stenmark, who upon the question why he always seemed to be "lucky" ie not bailing out during runs and so, replied with "I know nothing about luck. But the more I practice the more luck I seem to have". 🙂
  3. John, part lucky, part preparation and part a long true, sharp drillbit. With the jig I got a good aim longitudinally. Elevated aim could have been better as it shows. But I am not too concerned about that.
  4. Practise, we all need it 😉 Good light and magnification devices are also crucial. But hey, do what works for you Alan.
  5. I discussed shortly my notching experience in the second post here. The first one shows the main hatch.
  6. Thank you @Mark Pearse, too kind 🙂 So, drilling for the prop shaft then... or probably arboring, right? It seemed from the plans that the shaft is parallell to the keel. That's convenient. So I dreamed up a small contraption to get hight and angle (mostly) right. With a sharp drill bit I bore away. It came almost at right height. Lucky me I'm not installing an engine. The surface where it surfaced is the mizzen mast step. There was a neat little cavity to step the mast in. That cavity is a fair bit bigger now, and makes for easier stepping. You have to look on the bright side of life 😉 If you think that the interior has somekind of shine to it, it is correct. I brushed on a layer of lacquer, water based. Another thing you can admire is the tight to no gaps between the planks. It seems I made something right during planking 😄 (no, I am not being humble today. This cold I got really doesnt wanna give in, so I trying my best to keep the spirits high. No @KeithAug , not THOSE spirits!) Pax et bonum
  7. Just like druxey described. Mark the width of the notch with the favourite no11, then carefully chip away. My mini chisels are 2, 3, 4 mm wide. We are probably addressing different kind of nothces also. I'm mostly thinking of the carlings. Since it is hard to the eye if they are not i straight lines. Notches for knees and stuff are another matter. For them I guess it is not the same visual eyesore if they are slightly out of plumb (or whichever angle they are)
  8. Looks good from here 🙂 When I laid the deck on my current build I installed all the beams first, then notched for carlings and stuff. My mind found it easier that way to get straight lines for carlings and deck openings. But as they say, whatever works for you, my mate! Keep it up!
  9. Calling in sick has its advantages on modelling time... but it does not help the revenue, so I'll go back to work tomorrow. Feeling way better today than yesterday. I even fell asleep mid-day yesterday. I normally don't do that. "What so special about that? I do that every day", I hear you say. Well, I'm not THAT old yet. 😄 Thanks for all the likes in my humble build log. Wisky plank is in! And all treenails are in. Hull i sanded, painted, and sanded down through 100/120/180/240 grit. Yes, there are seams still open. Yes, you can see individual planks. Yes, it is not a museum quality piece. In fact, I will try to weather it a bit to go with the less than meticisously perfect hull. And I thought this image looked cool: Look @KeithAug, I did not turn it into a lamp-shade material! Next up... hm, two things, 1. rudder shaft and rudder. Need to find the drawing and print according to scale. And 2. Drill for prop shaft. Needless to say, they will be done in reverse order... Pax et bonum!
  10. What everyone else said about the build, Keith! About our spouses thoughts of our mental state. I just heard that, when you retire and don't have the day-to-day job that keeps you occupied, you need something that gives you purpose to wake up, roll the legs over the side of the bed and get up. Just for fun, paint the idea to the Admiral of you just sitting in your couch all day, watching TV-shop and silly as h*** game shows asking when the coffee's ready or when is lunch. "Would that be better?" you ask. "Now at least, I'm not in your way all the time hunny" 😉
  11. @KeithAug, the planks are 2.1 mm, plenty of wood before the fallback to lampshade needs to be engaged. And about the cabinet, I can glad you then that the current state of the cabinet is 1x Irish and 4x Scottish plus a couple of VSOP brandies for the wintery days. No Islay malts as long as the eye can see. However, despite your own experiences I like a decade old Bowmore. But head-ache you say, could it be the weather? In Sweden we (not me, not fond of it) have theses "Kräftfest" (cray fish parties) in August. On the menu is the Aqua vit, crayfish and white bread (like the french baguette). The funny thing is that people seriously blame the headache on the crayfish, not remebembering how many "snaps" they downed 😄
  12. To answer you other question @KeithAug, yes, the temperature has risen above freezing. It is that glorious 2-5 Celcius, with mostly overcast sky. Perfect weather for cranking up the heat and do some modelling. I called in sick today as well. Not very common standard by me. But I have one of those high demand IT-jobs and thought it better if I just called it quits instead of messing something up. To draw bamboo for treenails doesn't take that much thinking 😉
  13. That would of course be nice. But at £140 it is slightly over budget... I'll search the liqouer cabinet for something appropriate instead. There is a selection of blended and single malts actually 😉 Btw, has NHS validated that recomendation? Just curious 😄
  14. Thanks John! Yes, it feels good. The wisky-plank goes in tomorrow. I caught a bit of a cold, so it is not only the sandpaper that's partially clogged up at the moment. 😕 Otherwise it would have been done today.
  15. Finally, the end is near! For the planking, that is. I am not a doomesday vigilante... The wisky plank will soon go in. Yay! 🙂 Port side is sanded, which the sharp eyed viewer can see. I thought that by painting the hull prior to sanding it would be easy to see the progress. That turned out to be true. However, I did not dilute the acrylic paint very much and used it quite generously. Bad choice. It led to clogging up the sandpaper. Of course; I probably could have thought that out before hand. But I didn't. So, when sanding the starboard side, I will not paint until the very end. With diluted paint.
  16. That's okay. As long as you don't classify me as a complete idiot I'm fine. Let's blame it on my English skills. Nuances are hard to express in writing even in you primary language. Oh, and please don't cross-reference the idiot-thing with my Admiral. She thinks I am a total dork sometimes... Back to building 😉
  17. Alan, I am sorry! I do not question the fixed blocks or anything. Just tried to be funny about the temporary strings you held the masts with. Apologies if it came out wrong. Not my intention at all. I like your build, primarly for the scale you are building in, 1:64. I don't have place for big ships in 1:48 and hence follow your build to see how it can be done in that smaller scale. Kind regards Håkan
  18. Alan, I'm not entirely sure about those lower shrouds. They look a bit over-sized and the angle doesn't look really right. Sorry, couldn't help myself. 😄 You're doing good! Nice touch with the coin 🙂 Keep it up!
  19. Oh, the close ups are always a menace. But you are doing well! That minor chipping will not be visible from a regular inspecting distance later on. Keep it up!
  20. Thanks Andy 🙂 No aqua vit for me thanks. I prefer the strong distilled yelloish beverage from the highlands or the green island any day of the week. Althoug I've tasted aqua vit a couple of times, it is no joy in drinking that stuff. I mean, just take a look at Will Ferrell explaining Swedish Xmas and singing "Helan går" (quick song to down the drink): https://youtu.be/wjcGAKU23Q That said, it's the wisky plank for me. But it will have to wait until startboard side is done. Cheers!
  21. Thanks John! That's about correct re the clothing. And at -10 we dig out our long-johns and ponder wether we should take the overcoat or just stay with the hoody 😄 The thing with Sweden is, it is a looong country. So people up in the north usually think the rest of us ar sissies when we complain about the snow being 2" deep. It is of course complicated. One thing is that people down south are not used to drive in snow, so when it actually snows they are all over the roads and beyond. Where I live we get snow every winter more or less, and I enjoy driving in snow with the occasional corner drifting. Now I'm driving a new Toyota RAV4 and it is bullet proof when it comes to slippery roads. It makes other cars and drivers look like road snails ( there is probably a better english term than that). Don't be fooled though, I do drive carefully and seldom above my ability. Haha.
