Charter33
Members-
Everything posted by Charter33
Impressive work Craig, especially the challenging task of marking, cutting and lining those gun ports! As you said in your first post, filler and sanding is definitely often your friend and has certainly helped me out on numerous occasions. Coming up with jigs and other aids to assist in achieving accuracy is an aspect of model making that I enjoy. I'm currently thinking through a way of drilling the two holes above each gun port for the supporting ropes. Unfortunately I no longer have any access to those well equipped workshops, and in particular the software and laser cutter that I used to make many of those simple tools.... but I have a plan..... I'm getting closer to finishing my home workshop at the bottom of the garden. The insulation arrived last week, the electrical supply has been planned and the fittings etc. are being sourced as funds become available. I have also successfully experimented with a way to clad the internal walls using recycled (and free!) wood. I'll be updating the build log for this in 'Shore leave' when a bit more progress has been made. In the meantime there's plenty of prep work to keep me busy on Victory. Looking forward to watching your build, you've clearly made excellent progress so far 👏😁
Hi Craig, Covid certainly changed things and its impact on you clearly brings its impact into perspective. Sorry to hear you lost your business! From a personal point of view it caused me to make the difficult decision to retire earlier than planned from the rewarding 44 year plus career I loved. With no proven medical solutions at the time, some students idea of meeting safety protocols being to rub their hands together to give the impression that they had sanitized on their way onto the school site as they bypassed the measures provided for their protection, and the stress of trying to deliver a genuinely high standard of education in my chosen field of Design Technology and Product Design remotely when classes were 'closed' and isolated due to infection, I relented and accepted the Admiral's advice to put my own health first for once and to hang up my workshop apron a year earlier than expected. Teaching a practical subject when the workshop facilities were unavailable, lessons were delivered in classrooms normally used from anything Science to Geography or Music definitely had an adverse impact on mental health. As for retirement, it's definitely not as expected and I still look forward to the time when I can fully enjoy it.... I can honestly say that I have never been so busy! Grandchildren, and the Admiral's house and garden projects make me long for those happy halcyon days when returning to work on Monday morning brought an illusionary opportunity to relax a bit! But we move on, the world has definitely changed. The photo in your post is impressive and intriguing and I look forward to hearing and seeing more with eager anticipation....... no pressure 😄 Cheers, Graham
Thanks for following my contributions and giving them a 'thumbs up'..... Robert, it is a great motivation seeing the inspirational work of the master craftsmen on this site whose build logs have helped me through many of the challenges that have arisen. It certainly pushes me to try and improve my own skills. It is really important to study the plans Ron, those brackets aren't the only instance where the written instructions don't give the whole story. It just happens that it was the case with the next task I tackled. On the same plan sheet (5) there are details of the decorations on the outside of the bulwarks. I cannot see any reference to how these are constructed in the manual. The parts manual shows parts 412 and 413 listing them as Moulding 90 degree and Moulding termination foot respectively. They are on the second sheet of 1.5 mm walnut. There is no information on what to use to use with them. I assume it should be 1.5 x 1.5 walnut strip. When I added the inner bulwark decorations I used copper wire scavenged from a bit of twin and earth electrical cable (post #84), and I decided to go the same way here, discarding the wood for metal. This took me back to those lockdown days when I made the inner decorations. Travelling to a modelshop for materials at that time was impossible so a bit of improvisation was called for. First stage was to file the 1.7 mm dia. copper wire to profile, three flat sides and one, the outward facing surface, left curved. The final thickness is 1 mm. Next step, after annealing, was flaring and tapering the ends in preparation for making the termination feet followed by shaping Pieces were then cut, bent and soft soldered as required. After cleaning up these were glued in place. All this work needs to be painted next. Currently awaiting a delivery of Dull Black and Yellow Ochre from Cornwall Model Boats as my stock, purchased along with the kit many years ago, is showing its age.... In the meantime I'll get those support brackets cut from the PE frames and prepared for fitting. Cheers, Graham.
Hi David, Did you use an on-line photo hosting site for your pictures? I used to, it was free and allowed me to crop, rotate and manipulate the data size of images before uploading them into my build log. When they changed their conditions of use and required a subscription payment I stopped using them, and could no longer access the pictures I had saved with them. There were then problems with photos I'd previously added to my build log through that provider. Just a thought...... Cheers, Graham
- 439 replies
- victory
- caldercraft
This picture shows my first attempt at the decorative scrolls, refered to as moulding swirls in the manual, that enhance the hull decorations. The method that the kit provides is a bit lacking and many builders have come up with alternative improvements. My plan was to try and replicate the way these scrolls flow from the straight sections of brass profile. This first attempt is very rough but in terms of developing the technique and proving the concept it taught me alot. The first step was to use a piercing saw fitted with a 0/4 blade to cut 20 mm up the brass strip following the two thinest sections The second cut then turned out to remove the bottom piece The two remaining pieces were carefully spread apart wide enough to allow a needle file to access the inner sufaces to smooth them off. 8 mm was then cut off the centre section and the outer sides filed to tapered points One lesson learned from the test piece was not to anneal the strip until all the cutting and filing was completed. Once these two 'fingers' were annealled round nosed pliers were used to roll the centre of the scroll The top section was then bent around the centre The excess length was cut off and this piece pushed into place These pictures shows the scrolls in place and includes the larger scroll at the stern. This one was made the same way, the only difference being those two saw cuts which were made 25 mm long, and the tightness of the scrolls. Having the channels still removable at this stage made adding these brass strips more manageable, I certainly wouldn't want to have had to work around them! A word of warning relating to the channels. Looking at plan sheet 5 there are vertical lines shown under the three main sections which turned out to be PE support brackets (Part 626). I've looked through the manual but cannot see any written reference to them. Glad I spotted this now before adding the chainplate assemblies. Just a few more sections of brass profile to add to this side, then I can tackle the port side of the hull. Cheers, Graham
Coming along nicely Chris. Background research and hunting down that extra detail to enhance a model kit is a very satisfying and rewarding aspect of any field of modelling, especially when you are committing so much time and effort to a project like this one. I regularly refer to my copies of Longbridge and McKay, but wasn't aware of Alan McGowan's book. I am now. Just found a copy - I'll have it by the weekend......thanks for bringing it to my attention! 👍😉 Cheers, Graham
Thank you for the likes and kind and encouraging comments. Robert, I still visit your build log for inspiration. Have you managed to get your Victory mounted on that intriguing base that you were working on? I look forward to seeing it done...... First step with the channels, once they had been cut from the sheet and cleaned up, was to fit some mounting/location pins. These were made from fine brass lace makers pins with the heads cut off. Next the pin positions on the hull were marked and drilled with a 0.5 mm drill bit. Deadeyes were slotted into strops and the nib joint soldered, self locking tweezers keeping things together. A small hole at the bottom of each cut out in the channels acted as locating aids before the covering strip was glued in place. The white metal castings for the studding sail boom bracket and the support were filed to appear closer to the shape shown in Longbridge's illustration (page 94)...... ... the 'waist' just inboard of the ends achieved with a half round needle file and a simple jig constructed from matches.. Once glued in place, to simulate the method these components are fixed to the channel, the pin heads previously cut off were literally pressed into service. All the assemblies were painted... These are just dry fitted at the moment. I've decided to add the brass decorations to the hull first, and the advice is that it could also aid the fitting of the top row of gun ports - thanks Robert!😄 Cheers, Graham.
If you're thinking of using a PVA adhesive for the second planking layer you might get away with giving the hull's filler a brushed coat of watered down PVA. A little tip about viewing pictures on this site - when using a touch screen cell phone to look at build logs if you tap a picture it comes up in a format the lets you zoom in. On a PC try clicking on a picture, it can than be enlarged in the usual way. Good luck! Graham
Good progress Chris. There's a steep learning curve with this kit, but patience and perseverance pays off in the end. I found those quarter galleries a challenge too, and commented in my own build log on there were times when having as many arms as an octopus would help 🤣. Planking the middle deck is a great opportunity to practice the skills you need for later in the build, and your work here looks impressive - well done! The filler has done the trick on the first planking. Are you planning to seal the filler surface in any way to aid the bonding of the second layer of planks? Graham.
Welcome Chris, from another Caldercraft Victory builder. You've certainly got off to a flying start! It's a challenging model, but lots of enjoyable and rewarding tasks lay ahead. It may seem way ahead in the future, but it might be worth considering how you are going to display the model once complete. I mention this as some methods need a bit of preparation such as pre-drilling holes in the bottom of the keel etc. before progress with the hull construction interferes or makes the task more difficult. One technique I wish I had used, because at that time I was unaware of it, is the infilling of the spaces between some of the bulkheads, notably at the bow and stern, with a soft and carvable wood to help with the construction of the first planking. As you say, there are some truly inspirational build logs here on this site and time spent reading through them is genuinely time well spent. I always refer to the work of these very skilled builders together with the comprehensive instructions provided by Caldercraft. My build is only my second model ship. The first was nearly 40 years ago followed by long period of absence while a growing family took precedence. Good luck, I'll be following your progress with much interest. Cheers, Graham.
Woodwork/Model making workshop. Scale 1:1
Charter33 replied to Charter33's topic in Non-ship/categorised builds
That's right - model making area at the far end, wood turning lathe on the right, and woodworking bench to the left at the near end. -
There are quite enough gun ports and gun muzzles on a model of Victory to last a lifetime, without adding more to the workshop itself, Ron 🤣 ....but the Admiral's input to the build was a request for a weather vane above the door, and you've now planted the seed of an idea..... and I love a challenge! -
Installing the floorboards started with a plan, much used throughout the build, and now well worn.... In keeping with the nautical flavour there was only one method guiding the laying, the four step butt planking pattern. Once a board was cut to an appropriate length fixing holes were pre-drilled with a 12 mm spade bit and each piece secured to the sub-floor. A 1/2" plug cutter was used to convert offcuts of boards into covers for the screws. Mixing metric and imperial tools in this way resulted in a nice tight fit. Once these plugs had been glued in place a sharp chisel made quick work of getting them level and flat. The floor after sanding - No, not quite treenails, but visible at this scale? Oh yes, but nice and subtle..... The first coat of finish has been applied, the second and final coat will go on tomorrow evening after a light sanding. Cheers, Graham -
Totally agree Rodger, and tool protection is very high on my prority list. I'll be looking to fit a de-humidifier in there, especially after seeing what happened to one of my friends last year when a freak temperature swing of over 12 degrees one night made his pre-fab concrete workshop look like it had rained inside. He was mopping up pools of water and had to spend days dealing with surface rust on tools and equipment. I started preping the floor area yesterday and this included laying a vapour barrier on top of the OSB sub- floor base. The softwood boards have had nearly a week to acclimatise, so I plan to escape to the bottom of the garden later and begin fitting them...... Cheers, Graham -
Reviewing the instruction manual for the hull I realized that I had missed one of the final steps on the bow, namely the brass moulding that runs from the base of the cat-heads to the upper bow rails. Before events temporarily halted progress I did get as far as annealing the strip of brass profile. Seems I'm not alone in this omission, this component is also conspicuous by its absence from the photograph of the otherwise completed hull example that adorns the front cover of the manual! 😄 First task was to make a card template to guide the shaping... The bending jig I made earlier in post #135 came in handy again After shaping the tricky job of marking out and then removing a section of wale to get the moulding to sit against the hull...... Dry fit.... Before painting the ends were filled with soft solder to be more in keeping with contemporary photographs Finally glued in place and after a bit of filler the paint work had its first touching up. I'll be checking it again under natural light tomorrow. A couple more views: Channels and chainplates next....... Cheers, Graham.
Wow - thanks for all those 'likes', very much appreciated. To be honest, Javlin, air conditioning hadn't occurred to me. Here in the UK it's not something that's usually found in domestic settings but I'll do a bit of research into it. Thanks for the suggestion. Once the flooring is down and sealed I'll be putting in insulation to help with heat retention and sound issues. At the same time the first fix for the electrics will be done. I was thinking of using an oil filled portable electric radiator that I have currently in storage for residual background heat. A good friend uses one of those diesel oil cab heaters for his workshop, but that's not really what I want. Did consider a small wood burning stove but decided it would be impractical. The building is tucked away and pretty much out of direct sunlight so I think using natural flow ventilation, from the french doors, porthole window and opening roof light will cope on hot sunny days.....🥵😄 -
With the worst of the winter weather behind us, and a bit of financial jugging, work on the workshop is underway again. Just taken delivery of the tongue and groove softwood flooring. Six bundles, fortunately well wrapped against damage and the rain, manhandled through the house and into the garden. The workshop can just be seen through the arch. This is a slightly clearer view, the best that it can be seen from the house, and benefitting from the jasmine over the wooden arch having had it's annual trim. Another soggy day! The final addition to the exterior, the white gable end, is just visible. The boards are now unwrapped and stacked inside to adjust to the humidity etc. for a few days before laying starts. Another opportunity to add to the nautical aesthetic of the build perhaps.....we'll see! 😄 Cheers, Graham. -
Your comment is much appreciated Ron. With reference to decoration on the figurehead, I based it on photographs found on the internet of the current design, a research source I also used for the stern decoration and the entry ports. Unfortunately there is often confusion and disparity when comparing contemporary images to earlier historic pictures. So much has changed over the years, and this includes styles of carving etc. as much as application of colour! The point I'm trying to make here is that it may not be an accurate rendition of what was there in the past, but hopefully it's close enough 😉
Thanks for the likes and comments. Bit of a hick-up with the 1:1 workshop build at the moment. The main cause of my absence from the shipyard last year was the Admiral's garden project. It went a bit over budget so funds for the shed were diverted. Soon be back on track though, and I'll update both related threads in Shore Leave for anyone interested later.....
Back in the shipyard, and picking up from where I had got to on the Victory build. The first step was to get the white metal components for the two entry ports painted. These later additions to the vessel didn't exist when the ship was launched, neither were they fitted at the battle of Trafalgar. The models castings appear a little different to those shown in my 'go to' reference sources so I relied heavily on internet images. Tricky to achieve the result I had in mind, especially the line of rivets/studs under the front and side edges if the canopy. The colour of the sheathing on this first attempt was way out, so I had a go at mixing my own version of what I guess is lead from my small stock of enamels. These decorations were fixed in place with epoxy glue. An unexpected task next, and totally self inflicted. Sorting out the various parts that form the steps up to, around and above the port I found that the two steps immediately below the ports had gone AWOL. I think they had become detached from their walnut sheet back when I was tackling the belfry. Classic mistake - I put them somewhere 'safe'..... and they disappeared into another dimension. Eventually solved by converting a scrap piece of stock to the required profile and then deducing their length from the remnants of the hole where they once resided when originally machined. Masking tape helped align the steps and a couple of scaps of redundant planking made a simple 2 mm spacer for the gaps between them. Finally the fenders and chesstrees were painted and added. The three 'Victory' copper plates I mentioned back in posts #12 and #42 can be seen under each entry port. Good to be back at the work bench. Cheers. Graham
