Some Idea
Everything posted by Some Idea
  1. 🤣 Hi Chris - This "name" dates back to when I first thought about having a go at a scratch build. I was looking through this forum and some books and realised I had no idea at what I was looking at. I didn't understand the terminology, drawings, techniques and skills required. Forward a few years and I now understand the terminology and techniques - however the drawings still take me months and months to get a bit of an understanding of how things all fit together. So until someone offers to be my drawing mentor - I still often have no idea 🤣 However I'll change my name to some idea if I can work out how to do it
  2. More done - I started off by making the hatch surround which sits in the cabin. This will be the third one of these I've made and I have always enjoyed their construction. Next it's pretty much been an assembly of many parts that I had previously made. This did take me quite a long time as so many joints are meeting each other which ties everything together. I have to say though this has probably been one of the most satisfying parts of my build for me so far. When it all comes together and the joints are where they should be. I also made the carlings which pretty much finishes the quarter deck bar the finer details. Here's a few pictures. I did make a couple of errors - I forgot to cut the 4 recesses into the hatch surround to allow the hatch cover to sit flush and I also forgot to put the nails in the beam supports but its too late now. Next I need to make and fit the upper moulded rail that sits flush with the waterway. I can then finish the planking on the outside - but first I need to solve a problem of my own making. I cut the planking too short at the end of the final tall frame which the gunwale runs down too. I'm not sure how to cure this issue yet but I'll get my thinking cap on. I can see me having to carve and mill a solid piece for both sides of the ship - I don't know but I'll keep you updated. Thanks for all of the support - Mark
  3. Hi Mike - thanks very much for the reply. I'm looking forward to getting the books
  4. I don't know if this helps but when I intend to plank a hull I spend several days drawing all of the planks on the hull. This is done by a combination of all of the tutorials above and a bit of experience. I think that if I can draw them - I can make them. The fitting does take literally weeks and many abandoned pieces but hey what's the rush.
  5. I too would like to get a rough idea of when they will go back into print. I did buy the ebooks but I did this pretty much to reserve a physical copy.
  6. Thanks Tony A bit more work done this week - I have made the 2 beds. One is for the Master of the ship and the other for the Master Gunner who was on board when Le Rochefort carried its cargo of gunpowder. I made the recesses in the door and the lower part of the bed in the same way I made the door into the cabin. I just like the way this method looks when finished. Next was the cupboard walls and the base of the bed The pair of beds and the bulkhead with hinges and handles fitted. The parts now fitted into the hull - it's the fitting that takes the longest time just trying to get a tight a fit to the hull as possible. So I'm pretty sure that once I've made the hatch surround, fitted the beams and made the carlings that will be the quarter deck finished. Those tasks will be my next jobs. Cheers Mark
  7. Wow sorry to hear this Chuck - and people wonder why model companies go under. Disgraceful behaviour and I believe it was right for you to share.
  8. Thanks Kevin - I'm not planking the decks which is why I'm trying to get it as good as possible. When the ship is finished I'll still be able to look inside and see the detail
  9. Thanks JacquesCousteau - The shiplap planks are really simple to make on a table saw but I find them difficult to glue together so that they lay flat. I have to be honest the whole assembly did fit better than I thought it would and yea - I did look at it and think you lucky fella that looks nice 🤣 Sorry for the late replies - I'm now starting on the 2 beds which for this ship are quite elaborate in detail and I need to work out how to make them.
  10. Hi all Back from our lovely holiday and straight back onto Le Rochefort I'm now working on the crews quarters below the quarter deck and have started with the bulkhead which has a double entry door. This is quite a feature on this ship so I want to get it as good as possible. I started by making the shiplap planks that form the walls which I then glued together to make the actual walls. Next was to look at the doors themselves - I usually just get a solid piece of wood and then mill out the features to make them look like doors. In this instance I thought that I would try a new exercise for me and make them from individual parts and include all of the relevant joints as they possibly would have been made originally. Each frame is made of 5 pieces which then require 4 inserts in each door. Milling out the rebates to fit the 0.7mm inserts Sorry I should have taken more pictures but here are how the doors turned out. Assembling the parts actually proved to be one of the hardest parts. Next I needed to make the door frame uprights which have 2 rebates cut into them and also the base rebate that the walls slot into. It all took a little bit of fettling to get all of the parts to fit correctly but I'm just about there now. I did have one issue and that was with the door frame uprights which stopped the whole assembly from sitting flush with the beam. This maybe because I miss read the drawings but to get around this issue I cut some rebates into the beam which actually makes the whole thing stronger and more stable It's all still a work in progress but I'm getting there with this particular part of the build. Mark
  11. Silver solder on brass really needs tight joints to get a good joint. By the time it's been filed or sanded down it's almost invisible anyway. Jewellers use silver solder on gold and you cannot see the joint so I guess the secret is to take your time and have as little silver filler in the joint as possible
  12. They say that every day is a school day and this is one of mine. I would never have thought of that and my wife has an A3 light box for her art! I reckon that its going to spend more time in my workshop now - thanks Greg!
  13. Hi Mike - it's a trick of the camera! The gantry is separate from the height gauge in front of the of it. This is the gauge that I use - I use this to measure so much as my datum for the build is the bottom of the keel. I didn't have this tool when I began building but I wish that I had.
  14. druxey, dvm27 and SaltyScot - thanks for the comments! It's nice to know that it's not just me that has had to resolve earlier issues. After I built the quarter deck I was surprised just how much it changes the entire look of the ship. It just looks so much more complete and solid which was just another piece of encouragement to move forward. Mark
  15. Thanks Jacques that really means a lot to me - Since starting Le Rochefort I have bought a few monographs which has made me appreciate just how good the monograph by Gerard really is. I also have to remember that this is my first POF build too! My shipyard is obviously on the sketchy side 🤣 but we get things done! Thanks Chris - We fly out next Sunday for a much needed 2 week holiday in the sun.
  16. Hi Keith what a really nice comment - I also told Lorraine about your birthday wishes and she said thank you very much Cheers mate!
  17. Hi All I've not posted in a while as I found an issue with my build that began 3 1/2 years ago when my building skills and general ship understanding were very much in their infancy I guess. I first noticed this problem when I fitted the stern timbers and stern windows. I could see that the counter timbers did not go fully to the top of the stern timbers and the quarter deck rear beam seemed far too close to the top of the windows. The issue is - I have set the counter timbers at the wrong angle which to correct at this stage would be very difficult indeed. I felt that this would be the end of the build as I have tried my very best to keep as accurately to the plans as possible. I decided just to have a break and come back to it later with a fresh outlook and see how I felt about the problem. So with a renewed outlook I took loads of measurements of the entire ship. I discovered that everything forward of the stern post is fine. I also discovered that everything rearward of the stern post is 5mm out of spec. So I have a ship that is 5mm longer than it should be and the issues that accompany it. Upwards and onwards - The build continues but first I had to address a couple of problems. I would need to lift the rear beam upwards to the correct height and the quarter deck would have to be bespoke behind the stern post. So firstly the rear beam - Rather than remove the beam I have just made it 1.5mm thicker by adding a piece on. Next I made the beams - here's a few pictures of the process that I use. Just rough cut on the band saw I prefer to sand the inner curve first but I'm sure it makes no difference Then the outer Next I cut the dovetail joints - I really like doing this part its so satisfying Then I cut them into the clamps using a height gauge to make sure that they are at the correct height. I also sense check the alignment with a steel rule as they must be level with the stern post. Then I made the beam supports Finally I made the waterways which sit nicely on the level of the planksheer So although I'm not exactly to the plans anymore I think I've pulled it back enough to get away with it. I do have knock on issues such as the taff rail will be longer etc etc.... but I've got my head around what needs to be done. On the positive side you are getting 5mm more ship for your buck!!! Also stepping away sometimes is a very good thing to do! I'm very much back into it now - A slight delay though as it's my wife's 60th birthday next week so we are off to Crete for a fortnight to celebrate. I can now remove all of the beams and start some of the interior detail. Mark
  18. Albert your work is simply amazing and very inspiring too
